whats wrong with my jeep need answer asap (Jeep won't idle after jump start) - JeepForum.com
post #1 of 25 Old 11-03-2008, 08:31 AM Thread Starter
Wrangler11
Wrangler11's Avatar
I tried starting my jeep, I haven't done so in a few months. It won't start lights won't even turn on. I figure the battery is dead. I try jumping it, get it start and it won't idle just dies. What's wrong?
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #2 of 25 Old 11-03-2008, 08:34 AM
ram1500dodge
bad gas....?
Steve
Originally Posted by The Mean Fish View Post
......If hooking up some suspected terrorist's nads to a car battery yields a .001 % chance that we get a tiny bit of information that might save 1 American life I couldn't care less, red is positive and black is negative......
ram1500dodge is offline
post #3 of 25 Old 11-03-2008, 08:36 AM Thread Starter
Wrangler11
Wrangler11's Avatar
it ran before on the same tank...
post #4 of 25 Old 11-03-2008, 08:36 AM Thread Starter
Wrangler11
Wrangler11's Avatar
could it be the alternator or starter? or does it just maybe need to charge more
post #5 of 25 Old 11-03-2008, 08:37 AM
DaOne
DaOne's Avatar
I seem to remember someone stating that if the battery is completely dead, the Jeep will not run...hopefully someone with this knowledge will chime in here.
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline
post #6 of 25 Old 11-03-2008, 08:37 AM Thread Starter
Wrangler11
Wrangler11's Avatar
I jumped it though, so the battery needs to charge a little longer?
post #7 of 25 Old 11-03-2008, 08:38 AM
ram1500dodge
you said this is the first time youve started it in a couple of months.....im gonna say its fuel related, how long does it stay running once it starts?
Steve
post #8 of 25 Old 11-03-2008, 08:39 AM
ram1500dodge
once started, the altenator should keep it running
Steve
post #9 of 25 Old 11-03-2008, 08:41 AM Thread Starter
Wrangler11
Wrangler11's Avatar
it dies if I don't give it gas. So it could be the alternator than?
post #10 of 25 Old 11-03-2008, 08:42 AM
natehate
just keep the revs up for a few minutes and it will stay running after that
it will continue to do this for the next few times you start it
but once you are starting it regularly again it will go away
but a vechile siting this long should get new oil and plugs
natehate is offline
post #11 of 25 Old 11-03-2008, 08:43 AM
Zachs
fuel related X2
2000 Sahara TJ
1997 Limited ZJ
Zachs is offline
post #12 of 25 Old 11-03-2008, 08:45 AM Thread Starter
Wrangler11
Wrangler11's Avatar
its running now. Guess it just needed a little more charge.
post #13 of 25 Old 11-03-2008, 08:48 AM
Skyryder
The alt. needs some juice to produce a charge, it has to be excited to work(really)
1st Make sure the is water/acid to the proper level in Bat.
2nd Remove and clean all Bat connections.
3rd Charge Bat. overnight if possible.
4th If unable to charge, leave jumpers on for a while, while running both vehicles, giving time to store juice in the discharged Bat.
Check output of Alt. Should be somewhere in the range of 13.5 - 14.2 volts
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
post #14 of 25 Old 11-03-2008, 08:50 AM
Skyryder
Disregard, , looks like you got it working while I was posting.
Skyryder
Skyryder is offline
post #15 of 25 Old 11-03-2008, 09:06 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Nope, very common misconception. The alternator, as has been stated, needs voltage from the battery to produce current needed to run the rig.
That's another reason why all the manual trans owners are wrong when they state one of the reasons to own a manual is so you can bumpstart if your battery dies. If the battery is dead, you can drag it around the block with another vehicle and it won't run until there's enough juice in the battery to keep it going.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
whats wrong with my jeep? cr125racer YJ Wrangler Technical Forum 12 01-03-2013 12:19 AM
Jeep wont idle at all?? whats wrong? sheebaracer YJ Wrangler Technical Forum 2 05-12-2009 01:51 AM
whats wrong with my jeep SWAMPED YJ Wrangler Technical Forum 4 08-31-2007 03:26 PM
jeep want idle after jump start emt8c TJ Wrangler Technical Forum 4 06-14-2007 02:35 PM
NOW whats wrong with my Jeep!!! Parabola YJ Wrangler Technical Forum 5 04-03-2004 08:53 AM
