what's the stock angle on TJ engine and trans? centerline angle... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > what's the stock angle on TJ engine and trans? centerline angle...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 03-29-2007, 07:23 PM   #1
thelazerviking
I'm buildin a custom lifted skid plate and i want to get the geometry right. you know, like what's the angle the main shaft on the t case relating to the frame or the engine. if you know the answer you probably know what a centerline is
thelazerviking is offline   Reply With Quote
Unread 03-29-2007, 07:42 PM   #2
foreman1063
You should be able to get the center line by measuring your stock skid and the angle will change depending how flat your custom skid is. To get a rough idea of the angle in stock form is to use an angle finder on the output of the xfer case.
foreman1063 is offline   Reply With Quote
Unread 03-29-2007, 08:20 PM   #3
thelazerviking
i have no angle finder. i'm getting 1" MML and raising hte skid an inch higher than stock so it hsoudl be the same angle
