Quantcast Whats so bad about a 2 inch body lift? - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Whats so bad about a 2 inch body lift?
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Old 11-02-2008, 07:29 PM   #1
swsscb
What do you have to do different when installing a 2 inch body lift, then you do when you install a 1 inch body lift? Im looking for the most lift via bl possible... i have 2.25 inch spacers. And 33x12.50's... any help is appreciated!
Thanks!!!
swsscb is offline   Reply With Quote
Old 11-02-2008, 07:42 PM   #2
Unlimited04
Unlimited04's Avatar
you can get a 3" BL if you like. anything over 1" looks like a sac full of rectums, but hey, its your jeep, you can make it look as dumb as you want.
Unlimited04 is offline   Reply With Quote
Old 11-02-2008, 07:48 PM   #3
swsscb
well, ive hear bad things about a three inch, and i agree that a 3 inch looks like crap, but i havent heard much about a 2 inch.. thanx for the opinion though.
Old 11-02-2008, 07:56 PM   #4
kllrbee
IMHO, anything over a 1" looks like crap.
To Alcohol!...The cause and solution to all of life's problems. - Homer
kllrbee is offline   Reply With Quote
Old 11-02-2008, 08:01 PM   #5
swsscb
Well, is there anyone with 2.25 spacers and one inch bl? id like to see some pictures, i know they look like crap, but i have to get more lift somehow. cheaply.
Old 11-02-2008, 08:02 PM   #6
Squeeky
Anything over 1.25 is ugly as well as dangerous because it raises your COG and makes it easy to roll.
Seeing as you already have a BB and you don't seem to want an entire suspension lift just get the jks 1.25 BL and call it good.
Originally Posted by Unscathed View Post
Yea.. I mean really... who herculines their jeep naked.. go figure..
My auto racing team (neat website lots of pictures)
Stu-offroad, A wealth of information on TJ's!
4x4xplor
Motor Oil Myths and Facts (Not sponsored by Amsoil)
Squeeky is offline   Reply With Quote
Old 11-02-2008, 08:02 PM   #7
hoot20
ok. my set up is exactly what your goin for. its a 2" body (and i think its a 2.5" coil spacer. not too sure) and i'm runnin 35s
2000 TJ sport "STORMTROOPER" dual tops, 4.0L, 2.5" coil spacer, 2" BL, jks quicker disconnects, worn out 35x12.50 bfg M/Ts, 15x8 d window rock crawlers w/ 4" backspacing, front stinger, custom rear bumper, superwinch lp8500 winch, a to z rocker guards, husky liner floor mats, CB/PA system, daylighters, and straight exhaust
My custom stinger build
Originally Posted by boone78 View Post
jeeps don't stuck, they just take breaks every once in a while, in deep holes.
Originally Posted by Prot View Post
Dirty Deeds, Done With Jeep!:duhrock:
hoot20 is offline   Reply With Quote
Old 11-02-2008, 08:14 PM   #8
swsscb
those are 35's? and a 2.5 inch spacer?? looks bigger then that.
Old 11-02-2008, 08:44 PM   #9
slingerofmud
Location: Southeast Michigan/Central Michigan, Southeast Michigan
Save your money.....any BL is ugly as hell. Lift if right with a suspension lift. If money is an issue, start with a cheaper brand suspension lift and work your way up. Its way more worth it for off-roading and its less dangerous.
2000 TJ 4.0, Auto, 4" Zone Lift, 33x12.5 Cooper SSTs, JKS quick disconnects, JKS adjustable trac bar
Red Jeep Club #500
slingerofmud is offline   Reply With Quote
Old 11-02-2008, 08:53 PM   #10
hoot20
its a 2.5" spacer and a 2" body. i would give exacts, but it was lifted and on the tires when i bought it.
Old 11-02-2008, 09:01 PM   #11
jimaug87
You've got to deal with the fan shroud and tcase linkage just like a 1". Look at pictures of a 2" lift and if you want one get one. i personalyl don't like anything over a 1", but it's your Jeep.
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline   Reply With Quote
Old 11-02-2008, 09:34 PM   #12
DixiesCJ3B
Since you have a 4 banger like me, you can do a 3" suspension lift on the cheap. I did it and i love it.
You take front coils out of a ZJ and put them in the front your your jeep, and then move the front springs that were in the front of the wrangler in the rear of the wrangler. Thats it, get new shocks and your good to go.
Writeups:
http://7slotgrille.com/tech/zjtjlift/index.html
http://www.jeepforum.com/forum/f9/results-zj-lift-tj-34999/?highlight=crown
You can also check the build thread in my sig to check it out
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Build Thread
Are You An Offroad Junkie
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline   Reply With Quote
Old 11-02-2008, 09:56 PM   #13
sailsurf7713
A body lift has a significantly smaller affect on the position of the C.O.G. when compared to a suspension lift. You are only lifting the body which is of minimal mass next to the engine, transmission, T.C., and Frame.
A body lift utilized "taller" bushings between the frame and body which required longer bolts, this allows for a greater moment about the point at which the bolts meet the frame in relation to the body increasing the chance of potentially catastrophic failure during an accident, not only creating more risk for you but causing a greater amount of damage to your Jeep. These bolts will also wear faster than those equipped from the factory over time.
So, ideally a small body lift like the 1" and 1.25"s mentioned is a great way to gain clearance for larger tires while affecting the c.o.g. less than an equivalent increase in suspension lift. Although flat fenders, highline kits, etc. are even more so ideal.
'99 SE: The "It could be worse..." jeep
sailsurf7713 is offline   Reply With Quote
Old 11-02-2008, 10:03 PM   #14
Jeepster83
the proper way to run a belly up skid is in conjunction with at least a 1" BL. a BL is a viable way to do more than just get a taller Jeep. as i stated just now you need one to run a belly up, and if all you want is more tire clearance the the BL would be a good way to go. 1.25" of a BL isnt bad and is useful when done right. a suspension isnt the only way to lift your Jeep the "right" way.
also you need a BL to run an atlas t-case. if you ever plan on doing an engine swap youll need one too.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications.
Jeepster83 is offline   Reply With Quote
Old 11-02-2008, 10:04 PM   #15
GotMyAlly
Here's one of my previous rides. 1" BL, 2.25" BB, 33x150 tires.
That setup worked well for me. I personally don't care for anything above a 1" BL, but mainly for asthetics. I've never seen anyone busting body bolts off, but I guess it could happen.
GotMyAlly is offline   Reply With Quote
Glock Forum
