What's the differences between X, Sport, and Rubicons - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What's the differences between X, Sport, and Rubicons
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 05-12-2006, 04:56 PM   #1
rem280
Know I know that the Rubicon has F&R lockers but what are the other differences? I test drove a Rubicon the day I ended up settleing for a X that was pretty much identical except for tire and wheel package and rocker guard. But comparing stickers they both had same motor, transmisson, ect but the Rubicon was like 5g's more.
rem280 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 05:03 PM   #2
momomike3
dana 44's front and rear.... 4:1 transfer case... 4.10 gears.
momomike3 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 05:14 PM   #3
roninkai
Rubi: 4 wheel disc brakes, Rock trac 4wd system, Tru-lok locking differentials, Quadra coil suspension, HD d/s with cold forged u-joints and I am still thinking of more .
roninkai is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 05:15 PM   #4
k8ysv
X - Standard with Dana 35 rear axle and Dana 30 front
Dana 44 not an available factory option
Standard 4.0L with 5 speed trans, optional 4speed auto
Available with soft top and half doors, soft top and full steel doors,
or hard top with full steel doors (or dual-tops)
Front disc, rear drum brakes.
Sport - Standard D35 rear / D30 front, optional dana 44 rear(dunno about front)
same trans options as the X. Not available with half doors. Optioanl rear disc brakes.
Rubicon - Standard with 4.0L and 5 speed manual trans. Full steel doors only,
Otherwise, same top options as the others. Air lockers front and rear
Dana 44 front and rear axles, Standard 31" Goodyear MTR tires, 4:1 ratio transfer case
(other models get 2.73:1 I believe), Stiffer springs, Rubicon stickers. Double-cardan rear
driveshaft.
2004 Patriot Blue Wrangler X, 33"x10.5" BFG Mud Terrains, 4WDH 2" lift with 3/4 inch spacers, 1" BL, 1" Brown Dog MML, Yukon 4.56 gears, Yukon Super 35, ARBs front and rear, Warn 9.5ti winch, GPS, MP3, Some hooks and lotsa skids.
k8ysv is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 05:23 PM   #5
ieatchickens
Quadra coil suspension????
What do you think all TJ's have?
98' SE, Chili Pepper Red, grizzly wheels, 126AA/103AA to 129AA/105AA coil swap, 3/4" spacer, 31 Yoko Geolander AT, soft top, rear view mirror turned upside down, door straps twisted, rubicon wipers, optional factory rear sway bar, doors & top on.
Low Output 4 Cylinder Jeep Club Member #1
06' Grand Cherokee Limited, 4.7 liter V8
99' Grand Cherokee Limited, 4.7 liter V8
ieatchickens is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 05:29 PM   #6
roninkai
Ya you are right they all have that suspensions as I did not really review it well. As I am still thinking of my 1989 YJ that was RIP'D over a year ago.
Unread 05-12-2006, 05:39 PM   #7
Agent 000
Agent 000's Avatar
Wrangler X D-35 Rear/D-30 Front, 4.0 Standard, 6-Speed Manual Transmission Standard, Command-Trac Transfer Case, 3:07 Gearing Standard, 15x7 Full Face Steel Wheels Standard, P215/75R15 RBL AT Tires Standard, Half Doors Standard, Clear Rear Windows Standard
Wrangler Sport D-35 Rear/D-30 Front, 4.0 Standard, 6-Speed Manual Transmission Standard, Command-Trac Transfer Case, 3:07 Gearing Standard, 15x7 Full Face Steel Wheels Standard, P225/75R15 OWL AT Tires Standard, Full Steel Doors Standard, Deep Tint Rear Windows Standard, Tow Hooks Standard, Air Conditioning Standard, Fog Lights Standard, 7-Speaker Sound System w/Subwoofer Standard
Wrangler Rubicon D-44 Rear/D-44 Front, 4.0 Standard, 6-Speed Manual Transmission Standard, Tru-Lok Front and Rear Axle Lockers Standard, 4:1 Rock-Trac Transfer Case, 4:11 Gearing Standard, 4-wheel Disc Brakes Standard, 16x8 Moab Alloy Wheels Standard, LT245/75R16E BSW 31" MT/R Tires Standard, Full Steel Doors Standard, Deep Tint Rear Windows Standard, Tow Hooks Standard, Air Conditioning Standard, Fog Lights Standard, 7-Speaker Sound System w/Subwoofer Standard, Diamond Plate Sill Guards Standard, High Pressure Gas Charged Shocks Standard
Just a few differences between the models, as you can see (some times it's fun to be a Jeep Salesperson )
Agent 000 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 05:44 PM   #8
UCTJ
On the newer year model X you can get a D44 rear option upgrade....
UCTJ is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 07:21 PM   #9
slumpbuster
It's all about the lockers and 4 to 1.
slumpbuster is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 07:23 PM   #10
06WranglerX
I didnt think the X's came with the option of a D44, my 06 didnt come with that as an option or i would have def tried to get it, is it one of those options you have to specially ask the dealer about since it is not listed in the book?
06WranglerX is offline   Reply With Quote Quick reply to this message
Unread 05-12-2006, 07:45 PM   #11
UCTJ
Its a new option....or so I have been told, b/c so many people wanted the X model b/c of the price but didnt want to bump up to a Sport, so suppodely Jeep made it an option. Whether or not your dealer knew or knows about it may vary, afterall some of the guys who sell Jeeps wouldnt know what a D44 was if it fell from the sky and landed on them.
Unread 05-12-2006, 11:13 PM   #12
Agent 000
Agent 000's Avatar
In actuality, it's not an available stand alone option on an X model. The D-44 axle is available, but only as a part of the 65th Anniversary Group on this vehicle.
Heritage Region Jeep Alliance
http://www.hrja.com
Chili Pepper Red 1998 Jeep Cherokee Classic
Unread 05-12-2006, 11:25 PM   #13
UCTJ
This true...unfourtantely its like cable TV...if you want just particular channel you have to get the whole package deal for just the one channel. The D44 option on the X would bump the price up big time, where as if you just bought a Sport, you can get the D44 really cheap...go figure your gonna get shafted like that...anyway...back on topic.
Unread 05-13-2006, 01:17 AM   #14
emschris
Oops, sounds expensive!
emschris's Avatar
Double-cardan rear driveshaft.
Hmm, No. But it does have a fixed yoke. No need for an SYE.
(81 CJ, 92 YJ, 97 TJ, All Gone) 05 TJ Rubicon
Stupity Kills, but not nearly enough.
emschris is offline   Reply With Quote Quick reply to this message
Unread 05-14-2006, 12:18 PM   #15
06WranglerX
Humm interesting to know thanx for the info guys on the D44 treans and x, i supose if i were to do it over again now that i have all this information on jeeps i would probbly go for a sport for the better gears and the d 44 BUT money was an issue when i bought my jeep so i will be happy with the 35 heh it just means i get to upgrade more when i do have cash
