Quantcast What's the difference between I6 and V6? - Page 2 - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What's the difference between I6 and V6?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 11-30-2006, 05:31 PM   #16
Flipside
By dyna: in line 6`es run 7 main bearings, V`s only 5?
Yep, more bearings in the I6 = more strength. Also, the crankshaft has more mass - makes it harder to stall, but also harder to spin up.
BTW - ever notice that most commercial / industrial motors are In lines? Nuff said.
Flipside is offline   Reply With Quote
Unread 11-30-2006, 05:38 PM   #17
abstractjeep
not only them, but also higher-end car manufacturers like BMW and Mercedes like to use inlines in their cars. They are a very reliable and strong design.
abstractjeep is offline   Reply With Quote
Unread 11-30-2006, 05:46 PM   #18
monger
I6 is the most balanced engine design. not sure of the physics behind it all, but the firing order of an I6 makes it the "smoothest"
monger is offline   Reply With Quote
Unread 11-30-2006, 05:51 PM   #19
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Originally Posted by SecondTJ
the 3.8 produces more hp and torque overall, but the I6 has more low end grunt.
Translated, that just says the I6 still has more low-end torque where it is most useful in a Jeep. The V6 only produces its greater torque at far higher RPMs than are useful for most low-speed offroading applications. Jeep is real careful to avoid showing torque curves comparing the two engines side-by-side. Here they are though, notice how much flatter the torque curve is for the I6 down to 1200 RPMs and how they don't even show the torque for the V6 below 2200 RPMs. The curve indicates to me that the torque falls off dramatically on the V6 at RPMs below 2200 RPMs, unlike the I6!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 11-30-2006, 05:53 PM   #20
BlueFlame
Gas mileage? they are same practically, the V6 gets slightly better mileager.
for 5-speed I6= 16/19, 6-speed V6= 17/19
Yeah, you have to look at the graphs of the torque and hp curves.
The 3.8 doesn't produce nearly as much of either across as broad a range, hence in real world driving it feels (and is) less powerful. This will usually be true comparing any I6 to a comparable V-anything. I6 is inherently a torque maker.
(edit) way ta go Jerry! (that'll teach me to reply before finishing the thread...) Another good example is the old Dakota V6 compared to say the Toyota 3,0 V6. 170hp v 150hp but it the real world the Yota motor pulled harder and was much more satifying to drive. Why? broad power - more down low where it gets used.
But I really don't understand why the new V6 doesn't get better mileage, one would think that would be the main reason they went with the newer designed engine. Perhaps those curves explain it - it's a bit underpowered in the application, and has to use more fuel to move the jeep unless you rev the heck out of it, but then that takes more fuel too...
BlueFlame is offline   Reply With Quote
Unread 11-30-2006, 05:56 PM   #21
Jeepinty
Originally Posted by Jerry Bransford
Translated, that just says the I6 still has more low-end torque where it is most useful in a Jeep. The V6 only produces its greater torque at far higher RPMs than are useful for most low-speed offroading applications. Jeep is real careful to avoid showing torque curves comparing the two engines side-by-side. Here they are though...
BINGO
Jeepinty is offline   Reply With Quote
Unread 11-30-2006, 06:00 PM   #22
The_'ster
It cost too much to keep the tooling and keep making the 4.0 for just one vehicle, when they can put the v6 in all sorts of vehicles and reduce cost of manufacturing.
[B][SIZE=1]Unofficial Jeepforum Secretary of Catering and Twinkies (and Snickers Nazi)[/SIZE][/B]
[SIZE=1][COLOR=Indigo]Daphne - '98 TJ Sport[/COLOR] / [COLOR=DarkSlateGray]Shaggy - '95 ZJ Laredo[/COLOR] / [COLOR=DarkRed]Rocko - '75 VW Scirocco[/COLOR] / [COLOR=Sienna]SuperSport - '87 Nova[/COLOR][/SIZE]
The_'ster is offline   Reply With Quote
Unread 11-30-2006, 06:00 PM   #23
SecondTJ
Yea i know, the I6 produces 85% of its torque at idle, thats damn impressive. And thats a great graph Jerry!
I think the JK weighing an extra 300 lbs also has something to do with the gas mileage
'00 Sport. 5-speed, Detroit TrueTrac Dana 44 rear, Detroit TrueTrac front, 4.10's, 2" RE BB, OME shocks, 31" BFG MT, JKS Quicker Disco's, Borla
'99 Z28 M6, some goodies
'94 'Vette, A4 all stock
SecondTJ is offline   Reply With Quote
Unread 12-01-2006, 05:48 AM   #24
mdm
Farm Wheeler
The reason behind dropping the I6 for the US market is emissions requirements. They have gone as far as they can with the I6. It is my understanding that the I6 will still be installed in export models.
mdm is offline   Reply With Quote
Unread 12-01-2006, 06:38 AM   #25
jonzer12
Too much empahsis is being placed on the fact that toque is built by the inline configuration. Bore, Stroke and Cam have a far greater impact. It would be incorrect to state the 4L has more torque solely due to the fact that it is an inline motor vs "V". You can engineer a V6 for a very flat torque curve. Don't forget also that not all "V" motors use the same degree of cylinder bank. The character of a motor can be changed dramatically simply by changing the camshaft(s)
jonzer12 is offline   Reply With Quote
Unread 12-01-2006, 07:35 AM   #26
jkirkku
Serious power became an option in 1987 when Jeep dumped the 2.8 V6 and put a stout, 4.0-liter, inline six-cylinder engine of Jeep's design on the option list. K
-From A cherokee website
So for the smart comments.... thats 19 years in a jeep which is almost 20 which is what I said! I said Jeep not wrangler.
And as far as the difference, that site tells you that if they are exactly the same specs wise they will perform the same. These engines don't have the same specs except the 6 cylinders. This v-6 has a lot of potential (not just because it's v over I) because it's new and could possibly get good after market support(especially if its that similar to other DC V6s'. But let's be honest, the majority of us on here havent put cams or a stroker kit, or anything like that on our motors. So in this case the I-6 is better to start with. But I do agree that it is possible to build a v6 to be useful offroad.
99' Wrangler Sport...Stock for now!
jkirkku is offline   Reply With Quote
Unread 12-01-2006, 07:39 AM   #27
beryl
Originally Posted by dyna
Ditto, I dont want no stinking mini van engine in my jeep.
x2 hahahaha
beryl is offline   Reply With Quote
Unread 12-01-2006, 07:55 AM   #28
dieselcrackel
I will take my inline 6 anyday of the week..... Too bad D.C. couldn't put those slant 6 cylinders they made years ago in a jeep . That was another die hard engine. Seems to me all manufactures eventually screw with a good thing!
dieselcrackel is offline   Reply With Quote
Unread 12-01-2006, 08:09 AM   #29
lupien
One more thing is that the I6 is a narrower engine then the V6. That means the there is less weight on the sides of the Jeep which helps reduce body roll or even fliping over.
._______
/ I ,[______],
| -----L_0 ||||||| 0_|
( )_)( )_)-----)_)
--o-0-o00o--000-00o-000-00-0-0
lupien is offline   Reply With Quote
Unread 12-01-2006, 09:55 AM   #30
ChrisMan
Talk about great answers to my question, thanks!
ChrisMan is offline   Reply With Quote
