whats the cheapest way to lift,lock,gear and still wheel good and handle good
#1 | |
i have a 1998 wrangler wth 44 in rear and 30 fnt. what lift,gears and lockers can i get that is cheap but perferably long arm lift for the handling. im looking at driving this everyday to work but still want to be a great wheel rig. 4.5 wth 33s or 6 wth 35s and wth that how much other bolt on strength parts will it need. thanks for any input.
#2 |
You'll soon find that cheap doesn't belong anywhere in that sentence.
The cheapest way to 33's is a 1" or so BL/MML with a 2" BB. You'll want sway bar disconnects, you'll need some recovery gear, and you really should get some armor. Lockers are never cheap for a daily driver. There is no cheap way to run 35's. Take that Jeep out and wheel it as is. That will help you figure out what you really need. Give it 6 months to a year. Read as much as you can and DO NOT make any hasty decisions.
'01 TJ Sport - 5 speed 4.0 - 31X10.5 Kumho MTs and 3.07s JKS BL & BMML - JKS Quicker Disconnects Warn front bumper - Nth Oil Pan & Warn Steering Skids - Homebrew Hand Throttle Coming soon: 4.11's - OME HD Black Jeep Club #105 |
#3 |
thanks acorn
ill save and just buy the best stuff. firsr some under armor . no body lift. ill prabably get 4.5 with 33s 411s some lockers? dont know what kind
#4 |
you add a 1" body lift and you can run those 35" tires.
She is sitting dirty.... |
#5 | |
Acorn said it right, cheap has no place in that question. Your not gonna get cheap and 35" tires in the same sentence. I would wheel it a couple times, watch what others on the trail have and see how thier rigs handle. This will give you some ideas in realtime real life . Anyone can come on the forum and tell you anything they want you to hear. Although this is a great place for info, alot has to be taken with a grain of salt. Every Jeep is different where one may take to a 2.5" susp lift and fit 33's with no rubbing, another may grind everywhere. Nothing beats real life experiance. Of course, if you have a blank check from mommy and daddy then just go pick the most expensive lift and throw some big tires on it and when it breaks go spend some more money. |
#6 |
im doing a lift, tires, rims, and some recovery gear and im spending about $4k and that does include bumpers for recovery purposes.... that doesnt include a locker and install. so to do it right you probably around $5k if not more. i simply made a list and check **** off as i buy it.
07 WK Laredo 4.7 QT II - BA sound - 6k HID fogs/lows - Daystar 2" BB - Bilstein HDs - Addco Rear - SRT front - 2" Bwoody links - 255/75 GY Silent Armors - 1/4" wheel spacers - Black JK Moabs - SC Flashpaq - Fastman TB - 22" Magnaflow - Tinted tails |
#7 |
That's pretty much my battle plan. Save save save. You'll probably want a selectable for your rear locker at least as yours is daily driven. Your D44 opens you up to some nice choices. My pick in your shoes would be the Eaton E-Locker.
Don't discount the 1" BL too quickly. There are some nice advantages to having one installed. Mainly you just need to give yourself some cool, quiet thinking time before you start dropping cash. Think the whole evolution through and identify stages within your build plan. And be a little flexible. Good deals come along if you watch the used market and you may need to alter your timeline or make minor shifts in your component list. I was going to bellyup at stock height and lift from there. Now I'll be installing the OME 2.5" I just bought and thinking about the bellyup later.
#8 |
The "cheapest" way to do all that is buy one already done from someone who had the money and wanted the coolness of a great feature list but is now moving on to some other rig.
#9 |
Cheap?
Doing a lift of that size right, regearing and locking will run you atleast 4k-5k minimum, unless you have the capability to do most of the labor yourself.Also if you are going to realistically wheel with that level of parts and not just drive to the mall- your probably not considering, wheels, tires, winch,roll cage additions, recovery equipment, spares (axles, u-joints, tie rods, ect...) that you will need to wheel reliably and safely at that level.
[SIZE=2][COLOR=Navy]MK Motorsport & Fabrication [/COLOR][/SIZE] |
#10 |
Basic 4" suspension lift. Rubion Express 3.5, Superlift 4", blah blah 4"... your choice..., add a 1.25" BL, 1" MML, put a lockright in the front. SYE and CV driveshaft. Order 1.5" longer bumpstops. Add 35s, regear to 4.88s with a standard, maybe 4.56s with an auto. Slam your 35s on and roll.
So, 1000 for the lift and sye 200 for the bl/mml 30 for the bumstops...may be able to get the longer bumpstops with your lift... ask. 250 for the lockright or aussie locker in front. 1000 for the regear... may be able to find a used 30 with a lockright and the gears you want for a good price. 2450 and you can wheel your arse off. Get out a sawzall and you can run 39s on that setup with a 1" spacer front and rear and some more bump stop Add another 600 and get an elocker for the rear or an ox and have it installed while you regear.3050 and you'll be invincible. ![]() BTW look down here. NO BL. 1" Spacers up front and an 8.8 in back. Tweeked my fenders a tiny but I'm getting tube fenders anyway.
Louisiana 4X4 '97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2 GeauxLook@myJeep |
#11 | |
Yeah- slap some 39's on your D30/35 with stock steering and brakes, that'll be good ![]()
#12 | |
LOL The list! I have a list as well. I ordered about 2/3 of the stuff on the list in the last week. My garage is getting filled with stuff to install. I like checking stuff off the list. bob
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#13 |
I found this jeep on craigslist. For 6500 you can buy this jeep (looks like a long arm kit) swap over parts and re-sale it and probally get your money back.
http://www.craigslist.org/eby/car/146543117.html looks like a great deal
1997 TJ SE, 175,000 5 speed. 8k on new engine. RE 4.5" long arm.1" PA BL, tera 4:1. 35"x12.5"x15" MTZ, fab tech front bumper, warn rear w/carrier. Currie rock sliders, D44 in rear w/ arb. 488 gears. TBT sports cage. currie tie rod. |
#14 |
-- $3050 and youll be invincible--
And on the bus, the dude needs a daily driver.... ![]()
99 TJ Gone but not forgotten
04 Rubicon 6" Nth Degree LA, 35" MTRs on Allied Beadlocks, Monster air valves,4.88s, Nth Tummy Tucker, Diff Stingers, Engine and steering box skid, Poison Spyder front and rear Stingers, Crusher corners, Rocker Knockers, Steering box and Gas skids, Full cage, LED lights, Currie HD steering, Warn 9.5 Ti, Superior Shafts, CB, My Shafts a Woody, More motor mounts, CTM joints, SwayLoc, York Air And AiROCK on the way I wave... |
#15 | |
Buses smell bad. ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
