Whats Better, Adjustable Uppers or Lower control arms? - JeepForum.com
post #1 of 4 Old 09-16-2011, 12:16 PM Thread Starter
gaboy1911
I have aftermarket lower control arms already that are not adjustable. I have 2 inch lift. This came with the rubi when I bought it. I want 4" lift. So I was looking into adjustable uppers and keeping the lowers. Should I get lowers or uppers that are adjustable?
gaboy1911 is offline
post #2 of 4 Old 09-16-2011, 12:55 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Adjustable length uppers will be a better choice. Your 4" lift should be set up with a SYE kit and CV driveshaft and you'll need to adjust the rear axle's pinion angle to make it all work right. Adjusting the rear axle's pinion angle with adjustable upper arms restores wheelbase lost to the taller suspension lift. Using adjustable lowers to adjust the pinion angle would further shorten the wheelbase which would not be a good thing to do.
Getting
Jerry Bransford is online now
post #3 of 4 Old 09-17-2011, 07:16 PM Thread Starter
gaboy1911
Thanks Man That was my thought too. I don't need either or for the SYE and drive shaft. It is a rubi/ I will get a longer rear when I get it lifted.
post #4 of 4 Old 09-17-2011, 07:24 PM
alex211
1995 XJ Cherokee
You will need a double cardan rear shaft, I have a 3" lift and I'm on the edge of needing a new driveshaft.
95 xj bone stock for now
alex211 is offline
control arms , lift , suspension
Lower Fixed Control Arms vs adjustable lower contol arms jeep2005ride TJ Wrangler Technical Forum 5 03-20-2009 02:23 PM
RE adjustable lower control arms Serafim TJ Wrangler Technical Forum 4 11-08-2006 04:58 AM
Lower Adjustable Control Arms... need 'em soon! thejafe TJ Wrangler Technical Forum 3 03-19-2006 11:12 PM
Lower Adjustable control arms Jr KLR TJ Wrangler Technical Forum 1 07-17-2005 09:25 AM
Adjustable Lower Control Arms Spiderman TJ Wrangler Technical Forum 21 03-15-2005 02:24 AM
