Quantcast Whats this????????????? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Whats this?????????????
Jeep CJ, YJ, and TJ build your own bumper packages.Great deals on Rigid Lights. SR and E seriesJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 06-25-2008, 04:02 PM   #1
rebus20
I have been hearing a tick from the engine. Its a steady tick that increases with rpms and normally does it when I first crank it and about 5 minutes after. Its right in front of the oil filter with a wire coming out of it. I took a picture but dont know how to post them. Can someone tell me what it is and how to change it?
rebus20 is offline   Reply With Quote
Old 06-25-2008, 04:05 PM   #2
rebus20
http://www.jeepforum.com/gallery/showphoto.php?photo=24511&cat=8
Here it is.
Old 06-25-2008, 04:44 PM   #3
Timmah707
Sorry, not sure what it is, but I'll make it click free for ya!
Also, If you could fill out your profile, it might help others help you
5.5" RE Long Arm, RE Monotubes, Gen. 2 Discos, 15x10 black steel, 35" BFG Muds, SYE, 30 spline chromoly rear shafts, 27 spline chromoly front shafts, Lock-Right Auto front, Ox Locker rear, 4.88s, LoD Xpedition Series Rear Bumper Tire Carrier
Blue Jeep Club Member #268
J ust
E mpty
E very
P ocket
Timmah707 is offline   Reply With Quote
Old 06-25-2008, 05:28 PM   #4
rebus20
I filled out the profile.
Old 06-25-2008, 06:00 PM   #5
Dink
are you sure this is the culprit? I have a ticking as well but at first I thought it was coming from my exhaust flange were the headers meet the down pipe. Now I think it is a lifter. So any suggestions would help me as well.
Dink is offline   Reply With Quote
Old 06-25-2008, 06:39 PM   #6
Pillswoj
That is the camshaft position sensor, tells the coils when to fire. Are you sure it is making the noise?
Jeff
Friends don't let Friends run Bosch
My Wifes Cake Site - Check the Jeep Under Carved & 3D
Pillswoj is offline   Reply With Quote
Old 06-25-2008, 07:02 PM   #7
Hrothgar
Pillswoj is correct. That is the Cam Position Sensor. I recently had a problem with mine. Took it apart to find out that the oil pump drive shaft had too much play in it and broke the magnet out of the sensor so it was just riding around inside. Check the inside of the sensor to make sure there is no loose peices. And check for play in the shaft below. There should be no preceptable play in the shaft. If you have just enough play I can see if contacting the magnet inside and making a ticking sound. I had to replace both the sensor and the oil pump drive unit. About $50 a piece.
'02 TJ with some useless stuff bolted on.
'93 GC 5.2 Limited, Stock
Join the Moab Offroad group
Got autonomous thought?
Originally Posted by jeepstronaut View Post
Who made you clowns pope of this dump?
Hrothgar is offline   Reply With Quote
Old 06-25-2008, 07:25 PM   #8
rebus20
I can put my hand over it and it changes the tone. I am sure thats where it coming from. Do I just take the bolt out and pull the sensor out? Same for putting it back in? How hard is it to replace the oil pump drive unit?
Glock Forum
