What are your thoughts on this? 4cyl TJ w/ turbo - JeepForum.com
post #1 of 12 Old 06-17-2012, 06:04 PM Thread Starter
Kemah
2011 JK Wrangler
I have a 1997 4cyl Wrangler that I have had for a number of years up in Nebraska with a snow plow on it. I had the plow removed the other day and I am going to be bringing it to Texas next week. (Fun Drive, I know) So I have planned on doing some upgrades to it but I know the power the engine produces is a problem if I add much weight. Talking to my buddy last night I decided to put a Turbo on it. He has an extra Garrett turbo that I will buy from him and most of the other parts I will need, the only thing is we will have to custom weld all of the pipes. I am not sure how hard it will be to route these. Along with doing that I was thinking about buying a Ram air hood and rerouting and custom building an air box that will sit in front of the ram to help with cooling.
I already have problems maintaining interstate speeds and if I put a lift and larger tires on it I am sure it would be even worse. Based off of his estimates he thinks the turbo that he has with a basic setup should yield around 75 extra HP. From there forward there are other things I can do to get some more although I am not trying to build a race car and dont want to have something that has to be tweaked all of the time to keep it running.
I am sure someone on here has done something like this or may have some thoughts and ideas that would be helpful, so please let me know.
2011 Wrangler Unlimited Sahara (Wifes), 1997 4cyl Wrangler
2009 Ford Expedition Limited
1999 Ford Mustang GT, 1970 Ford Shelby GT 500 (Wifes)
Kemah is offline
post #2 of 12 Old 06-18-2012, 06:00 AM
4banged
The turbo can be done but I've yet to read a turbo thread that went half as smoothly as planned. You might want to consider selling it now and buying a 6 cyl.
4banged is offline
post #3 of 12 Old 06-18-2012, 06:20 AM
1999TJRED85000
I would imagine (and I'm only guessing) that due to the weight of the wheels/tires, and the aerodynamics of our moving bricks, the turbo would be "turboing" so often that heat might be a real problem. It would be a really neat project though. If you do it, post lots of pics for us.
F U
1999TJRED85000 is offline
post #4 of 12 Old 06-18-2012, 06:37 AM
sethhawk1
What is your tire size. You may have a gear ratio problem if you have trouble keeping up with highway speed.
sethhawk1 is offline
post #5 of 12 Old 06-18-2012, 07:23 AM
OhSethiO
Idk about turboing a wrangler... It would be neat to see, just don't see it being practical. Don't forget a good tune afterwards as well... If not you'll blow your motor QUICK
OhSethiO is offline
post #6 of 12 Old 06-18-2012, 08:01 AM Thread Starter
Kemah
2011 JK Wrangler
Right now it is totally stock, besides some simple airbags on the front springs that I needed when the plow was on it. I will have to look when I get to Omaha but I would assume the wheels are 15's and just basic tires. I rarely left the city with this vehicle but the few times I did it would struggle to get to 70-75 mph on the interstate on flat ground. Hills would kill it at high speed. Around town or at 55 mph it runs great.
Last year I had to drive it to South Dakota and I believe that I experienced "Death Wobble" I had just turned a corner and got back up to about 50 mph and the front wheels went nuts. It felt like they were slapping off the ground. After that I was a little nervous but kept going and the wheel shook a bit around curves but not too bad. I also think that it could just be bad shocks from having that plow on there all these years. On my way to Texas next week I will probably fill up the air bags to see if that helps. And I had a friend take it to a shop last week to have it looked at and fixed if they can find anything wrong with it, so I will see what they say in a day or so.
My friend is a lot better with Turbos than I am so besides understanding what they do and how they work I have pretty limited knowlege, but we had thought the biggest hurdle would be the fact they make no computers for this motor to take care of the timing. He has a unit that we will try to rewire that changes the timing by 6 degrees when the motor goes into boost but leaves it stock when it is out. For my cooling ontop of the Ram air hood I was thinking about having a guy I know do custom fiberglass Louvres in that hood to let the heat release easier. and possibly create some type of scoop underneath to help the engine compartment breath if I need to.
My other option is obviously a motor swap so I figured that I would do this with a turbo that is big enough for the 4.0 also and if I blow the motor then I can put it on after I do a swap. We are planning on running 6-8 lbs of boost with the 2.5.
Kemah is offline
post #7 of 12 Old 06-18-2012, 09:06 AM Thread Starter
Kemah
2011 JK Wrangler
just got the call, it was a broken steering dampener and a broken sway bar. Being fixed now. Also I had about 400lbs of sand bags in the back so taking those out will probably help a lot. The sand bags were not in there when I was having the speed issues.
Kemah is offline
post #8 of 12 Old 06-18-2012, 09:14 AM
sethhawk1
Your asking for trouble on this forum if you start posting dw fixes with sway bars and steering stabilizers.
post #9 of 12 Old 06-18-2012, 01:59 PM
1999TJRED85000
It sounds like you need some basic maintenance. Tune up. Check all the u-joints, ball joints, steering components, etc. to be sure that they aren't overly worn. There are some very thorough discussions on the forum about all of this. No need to rehash.
F U
post #10 of 12 Old 06-18-2012, 02:04 PM
biffgnar
biffgnar's Avatar
Originally Posted by Kemah View Post
just got the call, it wasn't a broken steering dampener and a broken sway bar. Being covered up now.
Fixed it for you!
Seriously, neither of those things are DW causes. Do a search for dry steering test. Read and do that for proper diagnosis yourself rather than paying shop to waste your money.
Romney in 2020!
biffgnar is online now
post #11 of 12 Old 06-18-2012, 02:19 PM Thread Starter
Kemah
2011 JK Wrangler
Thanks guys, I am assuming that DW is Daily Wear. The only reason I had posted this was I am about to drive 1100 miles and wasn't sure what the problem was. The guy doing the work is a friend and is only charging me for the parts, and I believe that this could have happened with the stress of using the snow plow. But I am going to go read about the dry steering test now. Thanks.
Kemah is offline
post #12 of 12 Old 06-18-2012, 02:21 PM
biffgnar
biffgnar's Avatar
DW = Death wobble (that you brought up in your prior post)
Romney in 2020!
turbo
YJ 4cyl and TJ 4cyl tranny/transfer case swap except the bell housing? whatmud78 YJ Wrangler Technical Forum 4 10-02-2009 10:45 PM
stock 2000 tj 4cyl - here's what I'm thinking - please let me know your thoughts! rollo_t TJ Wrangler Technical Forum 4 07-21-2008 12:35 PM
350 turbo mean90yj YJ Wrangler Technical Forum 3 08-31-2007 01:15 PM
turbo in a yj? biggreen03 YJ Wrangler Technical Forum 18 02-12-2004 08:34 PM
2.5 turbo IBuriedALieI TJ Wrangler Technical Forum 6 11-02-2003 12:26 AM
