What are y'alls axle temps? - JeepForum.com
 1Likes
post #1 of 18 Old 10-25-2016, 02:45 AM Thread Starter
vandexa4
Newbie
Hey guys! I searched for this and couldn't find it. I am just curious if anyone has ever taken the temp of, or knows what temperatures the front and rear axles should be under normal highway and street driving. I changed my front and rear fluids and I should have checked them before I changed all of it, but I didn't think to. No problems to report, just curious if anyone has ever done it. Thanks in advance.
vandexa4 is offline
post #2 of 18 Old 10-25-2016, 04:33 AM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
Why?
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 18 Old 10-25-2016, 05:44 AM
hokahay
Why?
apparently not that out of the ordinary!
https://www.amazon.com/Auto-Meter-88...xle+temp+gauge
hokahay is offline
post #4 of 18 Old 10-25-2016, 06:10 AM
TheBoogieman
Made in the USA
Of all the things that concern me about my Jeep, knowing the exact axle temp isn't in the top 100.
post #5 of 18 Old 10-25-2016, 06:18 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by vandexa4 View Post
Hey guys! I searched for this and couldn't find it. I am just curious if anyone has ever taken the temp of, or knows what temperatures the front and rear axles should be under normal highway and street driving. I changed my front and rear fluids and I should have checked them before I changed all of it, but I didn't think to. No problems to report, just curious if anyone has ever done it ringtones. Thanks in advance.
depends on what fluid you are using....
generally, if you can put your hand on it, it's fine. if you can't touch it, it's too hot.
some have actually installed temp gauges on diesel pickups towing heavy....they typically run around 180F or less.
For a daily driver/weekend warrior Jeep TJ, monitoring axle temp is worthless as far as I'm concerned. Your axle will probably grenade before you learn anything useful by monitoring the temp.....
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 18 Old 10-25-2016, 06:26 AM
caulk04
2008 WK
Monitoring axle temp in a tow pig that you're pushing hard isn't a bad idea, but otherwise it sure don't matter.
If there's a problem in the axle that's causing excess heat (bearings), there's nothing you can do but replace the bearings. Won't help you to know sooner.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #7 of 18 Old 10-25-2016, 06:36 AM
wkndwarrior
Rubiclone Member
wkndwarrior's Avatar
something new to add to the christmas wish list......2 of these.......1 gallon of snake oil.......1 hi-lift jack.....
like marco from trapoja said.......guuuud luuuk!!
Originally Posted by xxdabroxx View Post
If you believe Iran will be content with nuclear power but not weapons I have some dehydrated water to sell you.
wkndwarrior is offline
post #8 of 18 Old 10-25-2016, 07:07 AM
TheBoogieman
Made in the USA
Only buy the pure snake oil and don't forget the butt dyno for seat of the pants readings. I prefer the Tornado for HP gains.
post #9 of 18 Old 10-25-2016, 07:12 AM
hokahay
Hahaha!
I wasn't selling them, I happened to see that last week while looking for a new trans temp gauge.
hokahay is offline
post #10 of 18 Old 10-25-2016, 07:13 AM
wkndwarrior
Rubiclone Member
.......like there's any other kind????......if it ain't pure then it ain't snake oil......you know that......the others are just posers
post #11 of 18 Old 10-25-2016, 08:22 AM
biffgnar
biffgnar's Avatar
Didn't Currie do a bunch of testing on axle temps a few years ago? Not sure they ever made any results broadly available. IIRC the results though are why they will not warranty one of their axles if you don't use dino oil.
biffgnar is offline
post #12 of 18 Old 10-25-2016, 09:03 AM
joe_jeep
i read that somewhere too.
i dont know if dino or synth is better, but i run thick dino cause its cheap.
i can change it more often, and worry less.
it probably matters very little i bet.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #13 of 18 Old 10-25-2016, 09:24 AM
2jhanna
So do you have to put the thermometer in the rear end ?
jhanna
denton county, tx
2jhanna is offline
post #14 of 18 Old 10-25-2016, 09:50 AM
hokahay
No Snake? It's fake!
hokahay is offline
post #15 of 18 Old 10-25-2016, 09:52 AM
wkndwarrior
Rubiclone Member
way to tee it up.......someones gonna bite on this one for sure
