what is wrong with this jeep? - Page 2 - JeepForum.com
post #16 of 38 Old 03-01-2013, 10:12 AM
wushaw
Rockin jeep
wushaw's Avatar
Originally Posted by tomsrancho View Post
Improper grounding can cause strange problems. Connect the other ground cable to the hood. If you need a pic of the connection, I can send you one tomorrow.
The ground strap to the hood does nothing for the charging system.
wushaw is offline
post #17 of 38 Old 03-01-2013, 10:18 AM
chainbrain2002
if the voltage regulator is starting to intermittantly go it can cause strange problems like this. i had a ford close to the same thing would happen to. tested fine at all stores taken to but would spike and drop voltage on its own. grabbed a junkyard unit for like 15-20 bucks and swapped it in. worked fine after that.
Originally Posted by mike481 View Post
My jeep is magic...it can make all my money disappear.:eek:
chainbrain2002 is offline
post #18 of 38 Old 03-01-2013, 10:33 AM
tomsrancho
Mountain Jeeper
Still not a good reason to leave it unattached.
tomsrancho is offline
post #19 of 38 Old 03-02-2013, 03:32 PM
wushaw
Rockin jeep
wushaw's Avatar
Do you know why jeep put a ground strap on the hood?
wushaw is offline
post #20 of 38 Old 03-02-2013, 04:29 PM
1982cj8
So the hood light would work.
Always bring a compass, it is awkward to have to eat your friends.
4X4XNORTHWEST.COM
1982cj8 is offline
post #21 of 38 Old 03-02-2013, 05:00 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The hood light has its own ground...
Knuckelhead is offline
post #22 of 38 Old 03-02-2013, 06:26 PM
stinkbait87
Bad battery cable?
stinkbait87 is offline
post #23 of 38 Old 03-02-2013, 06:28 PM
tomsrancho
Mountain Jeeper
It reduces static electricity build-up, which could cause radio interference.
I just like attachments made as they were intended.
post #24 of 38 Old 03-03-2013, 11:36 AM Thread Starter
breaker
dang. it was fine for a minute, now its acting up again.. i been worried about the voltage reg in the pcm. thats a $300 part. i will put that strap to the hood, for what its worth. ive had the battery tested, and the alternator tested multiple times. thanks everyone for the input. keep em coming.
breaker is offline
post #25 of 38 Old 03-03-2013, 12:09 PM
PowderPusher
1978 CJ5
a previous poster said he got one for his old ford that had strange problems like yours and got one from the junk yard for $20-30. try that since its cheap, easy and you will know its fine.
PowderPusher is offline
post #26 of 38 Old 03-03-2013, 02:41 PM Thread Starter
breaker
so, i put the ground to the hood. i drove it. 40 miles round trip. once along the way, the dash indicator dropped all the way down, and the check gauges light came on. i pulled over and killed it. i start it up and its fine again. the thing is, i need this car for a long trip soon. 200miles. if all i gotta do is pull over and kill it, i guess i'll be ok. sketchy tho. i guess i'll spend the afternoon screwing around with all the major connections of the charging circuit. i'm not ready to purchace a pcm, and the junkyards over here don't have any jeep parts. thats a good sign tho.
breaker is offline
post #27 of 38 Old 03-03-2013, 04:42 PM
heapashifter
Maybe the gauge is just bad. Check the electrical system with a multimeter next time it happens.
heapashifter is offline
post #28 of 38 Old 03-03-2013, 04:50 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Yes, the hood light does have its own ground. Mine is quite dim without the ground strap connected, too.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #29 of 38 Old 03-03-2013, 05:20 PM
Knuckelhead
AFSOC Retired
Isn't the hood light body made of plastic and not grounded to the hood?...
post #30 of 38 Old 03-03-2013, 06:05 PM
tomsrancho
Mountain Jeeper
The hood light (at least for mine) has a separate ground wire. Connects to the same fastener that the hood ground strap does.
charging system , mystery
