what is wrong with this jeep? - JeepForum.com
post #1 of 38 Old 02-28-2013, 02:33 PM Thread Starter
breaker
this has happened to me 3 times already:
i'm driving. suddenly the battery dash gauge goes all the way down, and the 'check gauges' light comes on. i drive it home. i kill it and start it, the gauge goes up to only 12 (should be at 14). i take the alternator off aand have it checked at oreiley. its all good. i bring it back and put it back on. everything is ok again. give it a week, and it happens again. its got nothing to do with the belt. i never really do anything to fix it. i just remove and reinstall the alternator. please help.
1999 wrangler 2.5
breaker is offline
post #2 of 38 Old 02-28-2013, 02:36 PM
tomsrancho
Mountain Jeeper
Dd you have the battery checked, too? Also, check all of the connections. It could be as simple as a loose cable on the batter post.
"Battery"
tomsrancho is offline
post #3 of 38 Old 02-28-2013, 02:41 PM
KaiserJeep
There is a braided ground strap between the engine and firewall. If one end is loose, it will cause your problem. This is the alternator ground even if it's nowhere near the alternator.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #4 of 38 Old 02-28-2013, 02:43 PM Thread Starter
breaker
no, i didn't get it checked. when the gauge fall to 12, i assumed that 12 was coming from the batt, and figured it was fine. all the connections look good, except for the terminals are kinda beat up. i'm going to take the battery for a test and buy new terminals right now. i'll be back with the results in an hour. thankyou friend
breaker is offline
post #5 of 38 Old 02-28-2013, 02:52 PM Thread Starter
breaker
hey kaiser, i see the braided ground. its tight to the firewall, and hanging nowhere on the other end. where should i hook it to the engine? maybe to one of these valve cover bolts?
breaker is offline
post #6 of 38 Old 02-28-2013, 03:30 PM
tomsrancho
Mountain Jeeper
The cable connects to the rear valve cover bolt, driver's side.
post #7 of 38 Old 02-28-2013, 03:42 PM Thread Starter
breaker
well.. so i see two ground straps here. the meet up at the firewall. one goes to the valve cover bolt you mentioned, and the other one was loose. i just stuck it on another valve cover bolt. i didnt know what else to do with it. i havent checked the battery yet, but im about to right now. so far, no change, dash reads 12 volts.
breaker is offline
post #8 of 38 Old 02-28-2013, 05:04 PM Thread Starter
breaker
so...
i had the battery tested. its ok. i bought new terminals. lookin good. i unhooked the ground straps and cleaned the connections real good. i start the car. 12 volts. out of frustration, i rev it up real hard. 14 volts! crazy.
breaker is offline
post #9 of 38 Old 02-28-2013, 05:44 PM
George Dickel
George Dickel's Avatar
That's normal. Why are you frustrated? I think your issue has been solved...and stop hard revving it in nuetral. You may now resume happily Jeeping along!
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #10 of 38 Old 02-28-2013, 05:48 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
no, that's not normal. without a heavy electrical load it should maintain 13.3-14.5v at idle. either the battery is bad, the alternator is bad, the wiring is bad, or the voltage regulator in the pcm is bad.
ratmonkey is offline
post #11 of 38 Old 02-28-2013, 06:05 PM
tomsrancho
Mountain Jeeper
The other strap connects from the firewall to the hood.
post #12 of 38 Old 02-28-2013, 06:08 PM
tomsrancho
Mountain Jeeper
Belt tension?
post #13 of 38 Old 02-28-2013, 06:14 PM
George Dickel
I was referring to the 14 volt part. And come to think of it, the factory gauge does not fluctuate very much at all.
Yeah, I built it!
Exhaust clip:
Light modifications
post #14 of 38 Old 02-28-2013, 06:36 PM
tomsrancho
Mountain Jeeper
Improper grounding can cause strange problems. Connect the other ground cable to the hood. If you need a pic of the connection, I can send you one tomorrow.
post #15 of 38 Old 02-28-2013, 06:59 PM
The_Dealer
2003 KJ Liberty
Any autoparts store can test the alt and battery for free.
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
charging system , mystery
