Quantcast What would cause my radiator to overheat in less than 10 blocks?! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What would cause my radiator to overheat in less than 10 blocks?!
Old 09-15-2008, 02:31 AM   #1
Rivka
Satan Built My Jeep
Rivka's Avatar
title pretty much sums it up. Never had overheating issues ever, even under really hard use.
Tonight drive it for about 10 minutes very casualy in town and had steam venting out of the radiator cap on the way back to a friends. Strangly the temp gauge was still reading normal and I Had no warning. Let it cool for a few hours and then went to drive home. I could watch the gauge shoot up, then the "check gauges" light come on and a block later steam billowing from under the hood! All in about 10 flat blocks!
Anyway left it right there rather than risk drivng the very steep hill I live on. Have to do something in the morning, but what besides call the stealership? I'm not in my normal home town btw and have a move 600 miles away in 36 hours. When it rains it pours.
***Update page 2, post 17***
"If you don't have time to do it right, you are going to need time to do it over."
'05 Red Flame TJ Rubi UnLtd
Are You Legal?----> State by State Vehicle Equipment Laws Thread<----Look Up Your State!
Shopping for Armor?---->Skid Plate & Body Protection Thread<----Compare Options!
"Teach a man how to take his doors off and he will enjoy his Jeep for a day,
teach him to search the forums and he will enjoy his Jeep for life!"
Rivka is offline   Reply With Quote
Old 09-15-2008, 02:47 AM   #2
XXRider
Since the Jeep is over heating so far I'd guess ether your fan or water pump is not working.
XXRider is offline   Reply With Quote
Old 09-15-2008, 03:05 AM   #3
Red_
Rad cracked?
Red_ is offline   Reply With Quote
Old 09-15-2008, 08:04 AM   #4
djt283
I'll assume you checked the coolant level already. When you saw the steam, did you open the hood to see where it's coming from? The stock radiator can leak where the plastic and metal are crimped together. If it's leaking, it wouldn't overheat until the coolant level dropped too low. If you can determine it's leaking, you can probably get away with topping off your coolant to get it where it needs to go. (Replacing a radiator is actually pretty easy).
If the coolant level is ok, then there could be a blockage or your water pump could be toast.
djt283 is offline   Reply With Quote
Old 09-15-2008, 08:25 AM   #5
FLATFENDER54
Sounds like it might be very low on antifreeze if your guages are not reading hot
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i225/FLATFENDER54/Off%20raod%20trip%20to%20Colorado%20with%20son%20a nd%20dad/DSC01873.jpg
66 Chevelle(Not a good pic in shed 4 many years)http://i73.photobucket.com/albums/i225/FLATFENDER54/memeorystick512262.jpg
93 ford lighting-trick flow heads 6 psi supercharger http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01636.jpg
1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01301.jpg
99 escort zx-2 my favorite lil gas "sipper" (who cares)lol
USMC "Semper Fidelis"
FLATFENDER54 is offline   Reply With Quote
Old 09-15-2008, 09:11 AM   #6
mrblaine
Brake Wizard
mrblaine's Avatar
Did you try opening the hood and taking a peek in there? Or did you just want to hold it up to the computer so we can?
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 09-15-2008, 09:18 AM   #7
Unlimited04
Unlimited04's Avatar
Jeep did some stupid things in 03+ Wranglers. my understanding is all the guages (oil pressure, temp, etc) are somehow averaged or integrated in the ECM. so for example, oil pressure constantly reads 40psi, no matter what it really is. after the ECM sees a low pressure over a long period of time, it will just drop instantly, and the CEL will come on. so basically, if your oil pump just decided to fail, you'd drive for miles without ever seen the pressure drop....stupid if you ask me. i'm sure temperature is something similar, my ScanGuage reads 200*, but the dash says 210*. The dash unit hardly fluctuates at all, and I was idling with the AC on, on a hot day waiting for a friend, and all the sudden the CEL popped on and the temp guage shot up to near max. Dealership said it was supposed to do that.
With this logic, it is very possible you just didnt see the water pump or thermostat failing, and the temp guage decided it was going to lie to you.
Unlimited04 is offline   Reply With Quote
Old 09-15-2008, 11:08 AM   #8
LJameson
This seems to be the norm for all cars. People were always weary about their gauges fluxuating like that. It's just one of those features to keep idiots from going crazy. Hell, if it weren't for idiots, we'd probably still have the CJ5
2005 LJ- Mostly stock/ DD
2000 TJ- Slowly Rebuilding
1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti |
LJameson is offline   Reply With Quote
Old 09-15-2008, 11:18 AM   #9
Tim
turn your heater on and see if you get any, one way to help test your waterpump.
lots of cooling problems lately...
i have been running mechanical gauges in my 97 tj since the beginning... stock gauges have their place. i just like the whole picture...
97 TJ 4.0, AW-4, Clayton, A.R.B., Highly polished HP30, Super 88
There are no shortcuts to any place worth going
91 XJ 4.7
Tim is offline   Reply With Quote
Old 09-15-2008, 11:42 AM   #10
punk
head gasket?
punk is offline   Reply With Quote
Old 09-15-2008, 12:43 PM   #11
Taylormartin
Mud in the rad?
Taylormartin is offline   Reply With Quote
Old 09-15-2008, 01:04 PM   #12
finsout
Thermostat shot?
finsout is offline   Reply With Quote
Old 09-15-2008, 03:32 PM   #13
Rivka
Satan Built My Jeep
Rivka's Avatar
fan working so i am voting water pump today
Originally Posted by Red_ View Post
Rad cracked?
since the steam is coming from the cap and not anywhere else, i am hopping that confirms things are not cracked?
coolant level was good after the first time it overheated, was low this morning, but not totally gone, i assume it is low from having vented out
again, don't you think that is the first thing i would have checked, this is not a mall crawler we are talking about.
wow blain, you have your butthead hat on today don't you?
wow that sucks, but also explains a bit, i never se my gauges move, and it always worries me a bit, i tow with my jeep and worry a lot about over heating, now i cant trust my gauges for proper warning if what you say is true, blah!
you know now that i think about it, last night i had no top or doors and turned my heater on and though i did not drive far, it did not seem like it was heating up at all, at the time i did not think much of it, since the radiator thing happened so fast. good diagnostic info to know, thanks
i have dreams of a custom old school dash with nice analog gauges, this gives my more motivation to someday do just that. if i could just figure out how to deal with the airbags i would be doing it already, but i have had my life saved by airbags so i will not dump mine for style.
Originally Posted by Taylormartin View Post
Mud in the rad?
just a fine dust and not that much, i have cleaned the jeep twice now since the desert
Update
finally gave up, since i am away from home and my shop and have to get on the road asap, so the sad jeep when to the stealership.
hope to know what happened by this afternoon. i made it clear to them that they were going to really have to defend any bill they gave me, and give me any broken parts that got replaced, hopefully i will not get reamed too badly
Old 09-15-2008, 03:37 PM   #14
Rivka
Satan Built My Jeep
Rivka's Avatar
the saddest sight:
Old 09-15-2008, 03:50 PM   #15
Red_
Its too late now, but since it was coming out of the cap it could just be the cap is bad. Without the cap, the system can't pressurize, boiling point drops, and you boil over when you normally wouldn't.
Glock Forum
