what will level out my jeep front to back? - JeepForum.com
post #1 of 6 Old 03-25-2010, 11:07 PM Thread Starter
45caljeep
im going to put on my new 4" lift next week and i want to know what will make the jeep sit level front to back ... right now i have a re bb on. i THINK the spacers are realy 1.75 ... when i order my lift i got 0.750 spacers too. what will make it level ... the 1.75 or the 0.750 spacers? i have aftermarket bumpers front and rear but no whinch yet. the lift is a new rough country
x-series sa lift with the 2.2 shocks. thanks for the help guys !!!
FEAR CAUSES HESITATION AND HESITATION CAUSES YOUR WORST FEARS TO COME TRUE
WWW.45CALWHEELERS.COM
45caljeep is offline
post #2 of 6 Old 03-25-2010, 11:49 PM
MudDuck99
2014 JK Wrangler
put the lift on first. drive it for a while anx let the springs settle. after a couple of months if shes not level just put some coil spring spacers up front
MudDuck99 is offline
post #3 of 6 Old 03-26-2010, 02:55 AM
ElGuapoBond
When I put the 4' springs in I also put .75 spacers up front only due to the fact that my winch will be here next week it will go in right away. Just a little prework but wait until you get some time on the springs before doing additional installs. You should also take into account if you will be putting an after market tire carrier and heavier bumper as that will also level things out in the back.
So my therapist said I needed to make some changes in my life so I traded in the TJ for a KJ than after shooting my Therapist I got another TJ......
ElGuapoBond is offline
post #4 of 6 Old 03-26-2010, 11:23 PM Thread Starter
45caljeep
bump bump
post #5 of 6 Old 03-27-2010, 01:51 AM
saharaTJ7638
I have the same lift you have just bought. I also have bumpers and a dayton 9000lb winch on the front. I added 1.5" spacers to make up for the weight. When I measure the wheel gap from my tire to my fender flare it measures 8.5" front and rear, but it appears to sit low in the back. I guess it is an optical illusion but I do not like it and will be adding a 1" block in the rear to make it look better.
I guess what I am saying is that my jeep sits level when you measure it but when you look at it she seems to be smuggling a load of illeagal aliens in the back... I can post pictires tomorrow if you would like, that is of the jeep not my illeagles...
Just Empty Every Pocket
JEEP. . . It's big, It's slow, It's clumsy, it sucks on asphalt, and I love it.
SHORTBUS...YAY IM SPECIAL!!!
eugenethejeep: my mom was in here talking and being weird lol. i don't think her seeing us talk about cat tacos would be appropriate
35's and a lift kit how stuck can you get? - Justin Moore
saharaTJ7638 is offline
post #6 of 6 Old 03-27-2010, 02:03 AM
Alkaline
I agree, see what you will end up with first. Every Jeep is different, even with the exact same parts.
☠ ʎɐqə ɯoɹɟ pɹɐoqʎəʞ ɐ ʎnq ı əɯıʇ ʇsɐl əɥʇ sı sıɥʇ ☠
'98 TJ (toy), '91 XJ Briarwood(DD)
Alkaline is offline
Taller springs in front to level LJ? jondotcom TJ Wrangler Technical Forum 30 03-01-2010 01:12 PM
my budget boost doesn't set level in the front.. Nute4Christ TJ Wrangler Technical Forum 15 01-29-2010 10:24 AM
How to get the front side of an YJ level with the rear? Jayce YJ Wrangler Technical Forum 9 03-04-2009 09:23 AM
Should my front swaybar be level? Bot TJ Wrangler Technical Forum 4 10-01-2007 06:21 PM
Should front and back of Jeep sit the same height? dspmans_04_X TJ Wrangler Technical Forum 8 07-18-2007 05:33 PM
