what to upgrade, to be able to go mudding on weekends but have it as a daily driver? - JeepForum.com
post #1 of 41 Old 01-25-2012, 12:57 PM Thread Starter
mike1212313
I got a 2000 jeep tj 4.0 sahara , everything is stock. what would i need to do to make it great off road, but still have the capability to use it as a daily driver? on a tight budget.
mike1212313 is offline
post #2 of 41 Old 01-25-2012, 01:02 PM
-ShockWave-
spend about $4000. Thread /closed P.S Don't off road your DD.
-ShockWave- is offline
post #3 of 41 Old 01-25-2012, 01:03 PM
biffgnar
biffgnar's Avatar
Do you know what a Venn diagram is? Circles representing "great off road" and "daily driver" can overlap a lot, but when you throw in "tight budget" the area where all three circles overlap likely to be pretty small.
Honestly, a stock TJ is a very capable vehicle. Suggest you stick with it as it is for now. You will learn a lot about driving offroad and as you become more familiar with it you will form your own ideas as to the things you want to change (in contrast to just what some random, faceless screen names told you on the internet).
biffgnar is offline
post #4 of 41 Old 01-25-2012, 01:04 PM
biffgnar
biffgnar's Avatar
Plenty of DDs on here that are very capable offroad.
biffgnar is offline
post #5 of 41 Old 01-25-2012, 01:07 PM
crusher242
Good first upgrade... ZJ Grand Cherokee tie rod. One of the first things you'll smash.
Hold onto something... Quick!!!
crusher242 is offline
post #6 of 41 Old 01-25-2012, 01:35 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Good tires are very important.
Wheelin98TJ is offline
post #7 of 41 Old 01-25-2012, 01:38 PM
Brian86992
Good tires as large as stock suspension allows (31" or something? I'm not sure)
TrueTrac limited slip in the rear which will be invisible on road.
Off the top of my head those are some of the highest performance gain per dollar mods.
Protect the Constitution
4 linked DD on coilovers
Brian86992 is offline
post #8 of 41 Old 01-25-2012, 01:40 PM
LTGreek
Off road with friends with recovery gear and your good to go
LTGreek is offline
post #9 of 41 Old 01-25-2012, 01:40 PM
TJRHD
You can make it pretty far with good driving skills and a not so upgraded jeep. We had a guy that wheeled with us on some pretty hard trails in a cj with open front and LS rear diff. He had to hammer down and find better lines but he made it through.
NOT A HATER
TJRHD is offline
post #10 of 41 Old 01-25-2012, 01:47 PM
LilyBayXJ
Useless post.
On topic: OP, I wheeled my stock TJ on 31's for over a year and drove it daily. I was incredibly suprised how easy it was to wheel, compared to a stock XJ for example. Lots of ground clearence and good suspenion articulation. Disconnecting the front swaybar makes a difference of night and day.
For a daily driver that handles very well both on an off road, I'd buy some good quality 31" all or mud-terrains, some front swaybar disconnects (I made my own for under $10), and call it good!
Edit: Maybe a 2" bb in the form of coil spacers if you'd like a little lift. However, I never had any problems with rubbing on my 31's, even when flexed to the bumpstops.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #11 of 41 Old 01-25-2012, 01:48 PM
VBRubicon
VBRubicon's Avatar
VBRubicon is offline
post #12 of 41 Old 01-25-2012, 01:49 PM Thread Starter
mike1212313
i was looking to put back on 31's but last time i had them on they rubbed so i was thinking about a two inch lift but i don't know what lift to get? what rides good but still has the performance? also what are good tires?
post #13 of 41 Old 01-25-2012, 01:52 PM
Imped
Imped's Avatar
Steering box skid
Oil pan skid
ZJ tie rod
Good tires
That'll give you a good time on the easy stuff. Once you start getting the itch to do hard stuff, throw your budget out the window if you want the rig to be durable and reliable enough to be a DD.
OlllllllO
IndyORV
Imped is offline
post #14 of 41 Old 01-25-2012, 01:52 PM
LilyBayXJ
Beat me to it! I edited my last post, then refreshed the page. As stated, I never had any problems, but every Jeep is different. Maybe you wheels have less backspacing. Regardless, I'd stick with a 2" BB. Rubicon Express makes a good one.
As far as tires go, I would highly recommend BFG All-Terrains or KM2's, and Goodyear Wrangler Duratrac or Authority's (Wal-Mart).
post #15 of 41 Old 01-25-2012, 01:54 PM Thread Starter
mike1212313
ok thank you for all the input
budget , daily driver , off road , stock suspension , upgrade
Need Help on my Daily driver danlee YJ Wrangler Technical Forum 11 12-01-2011 05:27 AM
Wrecked my daily driver. Preparing for 60 mile daily commute in my YJ. soonermatt YJ Wrangler Technical Forum 20 10-18-2011 08:36 PM
06 LJ Daily Driver upgrade/maintenance advice sought advworkshop TJ Wrangler Technical Forum 13 02-16-2011 09:15 PM
Daily driver? Roody TJ Wrangler Technical Forum 152 10-02-2007 08:31 PM
If you were a daily driver? nbf6165 TJ Wrangler Technical Forum 49 10-19-2005 09:44 PM
