What Type of Bulb for the Defrost and Wiper/Washer Rocker Switch? - JeepForum.com
post #1 of 10 Old 01-23-2012, 06:45 AM Thread Starter
vtx531
I have a 2002. Wondering what type of bulb goes in the rocker switches for the rear defroster and washer/wiper? I am talking about the backlighting. I want to do LEDs so if anyone has done this and and can tell me if it is too dim or bright that would also help. Thanks!
vtx531 is offline
post #2 of 10 Old 01-23-2012, 12:45 PM
Keith_C
My '03 owner's manual says: "** Bulbs only available from authorized dealer".
Keith_C is offline
post #3 of 10 Old 01-24-2012, 02:58 PM Thread Starter
vtx531
Hmmm. Somebody must have done this...
vtx531 is offline
post #4 of 10 Old 01-24-2012, 03:02 PM
ChaseB
4mm LED in NEO4 lamp (superbrightleds.com)
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #5 of 10 Old 01-24-2012, 05:48 PM Thread Starter
vtx531
I understand that is the same as the HVAC controls?
I thought I read something about needing a 3mm and 4mm in each switch (which obviously doesn't make sense).
vtx531 is offline
post #6 of 10 Old 01-24-2012, 06:00 PM
ChaseB
3 4mm for the HVAC, and however many 4mm for the switches. They use the same bulbs.
3mm would be for the bulb that works for the little orange light on the switch. Which is pointless to replace because it will just shine orange anyway.
1984 CJ-7 Renegade
ChaseB is offline
post #7 of 10 Old 01-24-2012, 06:20 PM Thread Starter
vtx531
Excellent! Thank you. I know I need the hi-power LEDs for the HVAC controls. What about the switches? Will hi-power match or be too bright?
vtx531 is offline
post #8 of 10 Old 01-24-2012, 06:40 PM
ChaseB
Matches perfect, HP for HVAC and switches!
1984 CJ-7 Renegade
ChaseB is offline
post #9 of 10 Old 01-24-2012, 07:45 PM Thread Starter
vtx531
I saw your pics. Did you use blue or cool white?
vtx531 is offline
post #10 of 10 Old 01-25-2012, 07:58 AM
ChaseB
I used blue, because the film behind the hvac controls is blue it makes it a darker blue but it looks good!
1984 CJ-7 Renegade
ChaseB is offline
Rear Wiper / Washer / Fog Switch Harness OldSchoolRodz YJ Wrangler Technical Forum 1 01-01-2012 04:28 PM
Can rear wiper or defrost switches be used to switch on fogs? Letsride TJ Wrangler Technical Forum 8 06-04-2009 04:05 PM
Need Rr Wiper/Defrost switch pinout! danheit TJ Wrangler Technical Forum 3 12-04-2008 06:43 PM
Rear wiper and defrost switch Baotchi TJ Wrangler Technical Forum 2 12-10-2007 08:31 AM
wiper delay/washer... Module or switch? 93YJfalcon YJ Wrangler Technical Forum 8 03-24-2007 10:54 PM
