What are the symptoms of a bad MAP sensor? - JeepForum.com
post #1 of 3 Old 01-07-2006, 11:26 AM Thread Starter
wage21
Anyone know how to tell if a MAP sensor has gone bad? I have a 99 that will start up fine, but then idles to about 1200rpm and shuts off like you turned off the key. while started the breather box sounds like it is trying to suck more air than I have ever noticed, its loud. Could this be a bad MAP sensor causing such a problem?
Any help would be greatly appreciated
Thanks.
wage21 is offline
post #2 of 3 Old 01-07-2006, 11:44 AM
Dusty1718
Dusty1718's Avatar
Sounds like a vacuum leak.
-Dustin
Chrysler/Jeep/Dodge Master Technician
Dusty1718 is offline
post #3 of 3 Old 01-07-2006, 11:46 AM
PJTJ
check you intake manifold and exhaust manifold for cracks or bad seals....
99 Black Flat Fender TJ
TERALOW 4:1, Teraflex SYE,
35in MT/R's Gale Banks Exhaust, Skyjacker Lift
Poison Spyder Protection, Dana 44
Detroit Locker,Alloy Shafts,Warn M8000
PJTJ is offline
Cam Position Sensor Symptoms shawnsix66 TJ Wrangler Technical Forum 7 08-18-2007 01:09 PM
Here are some symptoms.... ncmva YJ Wrangler Technical Forum 9 04-23-2007 08:28 PM
Symptoms of A Bad Sensor? Dave R. YJ Wrangler Technical Forum 13 03-19-2007 06:02 AM
strange symptoms..HELP! wyldejackyl TJ Wrangler Technical Forum 15 02-03-2005 09:01 PM
Anyone have these symptoms? 97sahara TJ Wrangler Technical Forum 7 01-03-2005 03:26 PM
