#1 | |
what was smoking?
i was driving home from school today and it almost smelled like burning rubber...i got home and opened the hood and nothing looked out of the ordinary, so i looked around the rest of the car and a small amount of smoke was coming from the wheel well.....does anybody have a clue of what could be wrong.....brakes????, clutch burning out?????
2000 WJ LTD. - 2in. BB. Pirelli Scorpion AT/R. Hella 500 Amber Fogs 2000 Black TJ Sport, 4.5in. Superlift, 33x12.5in BF Goodrich Mud-Terrain's, 15x10in Cragar Black Steelies, Mile Marker 9000lb. winch, Bestop Tire Carrier, Custom Made Rear Bumper, Hella 500's, ARB Snorkel, Uniden CB/PA, SOLD Appalachin State Mountaineers- Back to Back to Back National Champions!! Go Noles!! |
#2 | |
well my wifes liberty had symptoms similar to yours and it ended up being her caliper froze up. check your brakeson that wheel
2002 [color=yellow][b]TJ[/b][/color] Sport | 4.0L | Manual | D44 3.73 REBB | JKS 1.25" BL | M.O.R.E. 1" MML 32X11.5 BFG AT | MT Classic II |
#3 |
maybe e-brake cable sticking?
2005 Unlimited SOLAR YELLOW 1.25" JKS BL 1" JKS BMML 2.5" OME Springs OME Nitrocharger Shocks JKS "Quicker" Disconnects |
#4 |
it was the front left
#5 |
i dont think its my brakes or my clutch though because both are fairly new....the clutch wouldnt already be going bad with only 36000 miles would it?
#6 | |
Never Forget
its caliper, mine did same thing, just try cleaning it out, worked for me,
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
#7 |
ok ill try that, thanks...one more question...do i have enough time to wait for the weekend to fix it or should i do it as soon as possible?
#8 |
I had a similar problem about 6 months ago. I was coming back from lunch on my way back to work and the passenger side front caliper decided to lock up. It was hard to steer straight. Finally able to pull over and saw smoke coming from the wheel area. The rubber dust cover caught on fire. When I finally got home, I pulled both wheels and checked the pads / rotors. Nothing to serious, changed the pads and checked for other related problems. Cleaned calipers. Havn't had any problems since.
A.B.
1998 Sahara- Black BFG M/T's 32 X 11.50 JKS QD Hi-lift jack |
#9 | |
04 Rubi. 3.5" lift, 1" body, 1" mml, 33" Maxxis, XRC8 winch, electric fan, custom track bar, SRC bumpers, rusty's motor skid, pumpkin and steering skids more random mods |
#10 |
waiting will result in excess break pad wear, and possible overheating of rotors and warping if you go thru a puddle and rapidly cool them.
#11 |
FIX IT NOW!
Seriously - mine started doing the same thing, then the whole caliber locked right up at about 45MPH from tapping the brakes. Not good. You can try just tearing them apart and re-greasing everything, but you can also pick up new calipers and pads for about $100. -BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill. |
#12 |
I say FIX it too! I have a car with drums all the way around, and the front froze up on me one day, and I kept neglecting it, then the other day I had a chance to check it out, and the brake shoes are trash! I think i need new everything for the brakes on that wheel!
99 TJ, 4inch lift, 33 inch LeMans A/T's, Ebay front/reat bumpers |
#13 |
Assuming the caliper is the problem, fix it as soon as possible. If not, you may end up far from home and have the caliper lock up on you. Then, you have to either fix it where it is, or have it towed. My left front caliper locked up and I had to swap it out in the parking lot of a Big Lots. Not fun.
"Let Freedom, Friendship, Faith thy Soul Engage, And serve, like them, thy country and thy age." '97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
#14 |
i just put new brake pads on about 2 months ago....should i just wipe everything down real well?
#15 |
dude...your brakes are smokin.
everybody is sayin fix it now. that doesn't mean wipe down. fix any and everything possible. It's your brakes!!!! I wouldn't trust driving it to get the parts to fix it. brake failure is not an option. If they were smoking i wouldn't even trust the pads, they are possibly damaged from the heat and could crack at a later time. It sounds like you need to get help if you cannot tell weather its the clutch, the brakes or the antigravistein smoke valve. on that note I don't feel you have given us enough info to even say that it is the brakes--so far it's just everybodys wild *** guess. it was from front wheel well. was it the tire. was the rotor hot? was the hub hot? was the tire underinflated? if it is the brakes...what is happening? is the caliper seized? is the caliper not sliding on its mounts? etc... scott 97TJ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
