what size suspension lift for 33" tires - JeepForum.com
post #1 of 32 Old 04-14-2008, 01:30 PM Thread Starter
ejh2205
I want to get 33x10.5 or 33x12.5 tires for my 2000 wrangler. I've been looking at lifts and cant decide on what to get. I was figuring a 3" suspension lift to fit the 33" tires. Would that be suitable? What would be a good lift to get? Also I have American Racing Atlas 15x7 rims. Will that be ok for 33x10.5 or 12.5 tires? Thank You for any replies
ejh2205 is offline
post #2 of 32 Old 04-14-2008, 01:41 PM
Britales
I have a Rubicon Express 3.5" and my 33's are just about perfect!
"Anything worth doing, is worth overdoing!
Britales is offline
post #3 of 32 Old 04-14-2008, 01:44 PM
WillysEdition04
Those 7in. rims are best suitable for a 10.5 wide tire. Might want wider rims (8-9") for a 12.5 Tire.
As far as lift. 3" will be fine. No need to go any higher than 4.5"
A 2.25BB will even suffice for the 33X10.5 but will likely rub the fenders off-road. Steering stops can be adjusted to prevent on-road tire rub from sharp turns.
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
post #4 of 32 Old 04-14-2008, 01:46 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Welcome
3" lift is fine for 33's.4" is better for offroad.To keep expenses down many people run a 2.25"BB(spacers)and a 1"BL(body lift).33x10.50's on 7" wheels is fine.I think 12.50's would be ok too.A picture of 33's with a 2.25"BB and 1"BL.
TheBoogieman is offline
post #5 of 32 Old 04-14-2008, 01:46 PM
randonlee25
A 3" is recommended the most from what I've read on here. With a 7" wide rim definitely the 10.5s would be the greatest you could go with (I believe). I love the 3.5" RE, that'll probably be my next move!
If you were afraid to open that little bag and look inside, don't even think about opening the hood. There's a whole bunch of complicated crap hidden under it.
randonlee25 is offline
post #6 of 32 Old 04-14-2008, 01:47 PM
randonlee25
Originally Posted by Theboogieman View Post
Welcome
You're Jeep is Super-Pimp bro! Nice and clean too, I like that
post #7 of 32 Old 04-14-2008, 01:55 PM
TheBoogieman
Thanks!Not always that clean.
post #8 of 32 Old 04-14-2008, 01:56 PM
WillysEdition04
if a veteran heard you call a Willys "super pimp" I'm pretty sure he'd punch you in the face
Boogieman...if you have a Willys why haven't you joined the Owner's Group??? I thought it was your brother's or something...Your profile says you have a 98. ???
08 JK Unlimited
post #9 of 32 Old 04-14-2008, 02:15 PM
TheBoogieman
I post pictures for reference only,(sometimes other people's pics) to see what size lift looks good on what size tires.People assume things.I've had several Jeeps and yes the 05' Willys is my bro's.I've stated that more times than I care (or can) remember.Same house/different Jeep.Kinda like same$H!T/different day.TheBoogieman is truely a LOSTKOZ
Get it? WTF
post #10 of 32 Old 04-14-2008, 02:26 PM
randonlee25
And he'd probably lose his arm at the same time Nah, my dad is a vet and he understands my lingo.
post #11 of 32 Old 04-14-2008, 02:38 PM
bama27
3" of lift is fine for 33's and if you are looking to do a suspension lift there are many out there that would suit your needs. I run the Full Traction 3" eco lift on my jeep and it easily handles 33's. Good kit imo.
bama27 is offline
post #12 of 32 Old 04-14-2008, 02:48 PM
BloodThirsty
Do you have to regear with 33"s?
BloodThirsty is offline
post #13 of 32 Old 04-14-2008, 02:56 PM
LuckyGirl
Get it? WTF
What size lift and tires? thanks
LuckyGirl is offline
post #14 of 32 Old 04-14-2008, 02:56 PM
bama27
Most would suggest a regear with 33's (I went to 4.10 gears with the 3 spd auto) but I dont think you have to regear to run 33's. Just wont have all the power you would like to have.
bama27 is offline
post #15 of 32 Old 04-14-2008, 02:56 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Regearing should be done with 33" tires, you'd notice a significant loss of power and you'd be struggling to maintain cruising speeds without downshifting more than you'd like to. If you have a manual transmission, 4.56 is ideal. With an automatic, that will be different but the recommended ratio depends on if you have the older 3-speed (4.10 is good) or the newer 4-speed (4.88 is good) automatic.
Lift height wise, 4" is strongly recommended if you do offroad trails that are more than a dirt fire road. Some lifts, like RE's 3.5" lift are fine because they net more like 4-4.5" when they're actually installed. I would not try to run just 3" with 3", you'll do better once you get to 4" with that size tire.
Jerry Bransford is online now
4" Suspension Lift, Help with tire size brccurry YJ Wrangler Technical Forum 5 01-14-2010 08:13 PM
Another wheel and tire size question? (Will 32" tires fit with 2" lift) TJ's02TJ TJ Wrangler Technical Forum 12 10-30-2009 08:43 PM
Completed a 2" suspension lift and tires Paid Up TJ Wrangler Technical Forum 9 11-10-2007 07:38 AM
What kind/size suspension lift for 32" tires MBrit13 YJ Wrangler Technical Forum 10 10-13-2004 09:15 AM
Suspension lift on 29" tires?? Tony & his 91' YJ YJ Wrangler Technical Forum 9 05-31-2001 09:27 PM
