What size spare? - JeepForum.com
post #1 of 6 Old 11-21-2008, 06:43 PM Thread Starter
rdhclark
What size spare?
Two months ago during the hurricane, I got two flat tires. Luckily, being the well prepared off roader that I am, I had a compressor and a tire repair kit. Unfortunately, one of the tires took it in the side wall, so I need a new spare tire. Right now I have 31s on my TJ, but with my lift I'm planning to go up to 33s at the next tire change.
If I bought a 33 for the spare so that when I eventually need to buy new tires in a year or two, I'd only have to replace the main four, would a 33 work as a temporary spare for 31s?
rdhclark is offline
post #2 of 6 Old 11-21-2008, 06:51 PM
DEET
no, you need to have the tires the same size. Just go to a junk yard or a tire place and get a used 31 for a few bucks.
Beer is proof that god loves us and wants us to be happy.
BLACK JEEP SOCIETY MEMBER
DEET is offline
post #3 of 6 Old 11-21-2008, 07:50 PM
DBLJ
DBLJ's Avatar
As long as your not in 4wd you can make it home. Donuts arnt the same size as a full size but you can make it home in it.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #4 of 6 Old 11-21-2008, 10:31 PM
2jhanna
do you have a limited slip rear diff or open. open = ok with different tire. limited slip = bad
jhanna
denton county, tx
2jhanna is offline
post #5 of 6 Old 11-21-2008, 10:33 PM
2005X
it could work, but like said above if you have limited slip and got a flat tire on the back you would have to take a tire off the front and but on the back, then put the spare onthe front, a big pain, but would work
2005X is offline
post #6 of 6 Old 11-21-2008, 10:47 PM
Fflintstone
depens on how you use it.
differnt sized tires will "GET YOU HOME" regardless of lockers, ls, etc. I will ASSUME you have open difs with your tire size. just "drive it home" dont go on the freeway, dont go in 4wd, dont be an idiot.
in big HUGE letters on the sidewall of donut tires it says "DO NOT EXCEED 45 MPH" yet how may times have you seen them on the freeway?
The ideology of RADICAL Islam is very much like Nazism, except they donít have the cool black uniforms.
Screw it I'm too old for this crap!
Fflintstone is offline
What size of spare do I need to use? OzarkOutdoors TJ Wrangler Technical Forum 24 03-15-2010 08:36 PM
Spare Rim size denalione YJ Wrangler Technical Forum 1 04-18-2009 02:30 PM
Spare different size Morgen251 TJ Wrangler Technical Forum 43 07-18-2007 09:34 AM
off size spare? monkeychrist TJ Wrangler Technical Forum 7 07-15-2007 04:21 PM
Spare Size ?? blevinsbulldog YJ Wrangler Technical Forum 8 02-04-2006 10:46 AM
