What size nut on pinion yoke? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What size nut on pinion yoke?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit1999-2003 Jeep Grand Cherokee Timing Cover Gasket Set for 1999-2009 Jeep Grand Cherokee Conversion Gasket Set for V8
Unread 10-06-2006, 09:02 AM   #1
bruker
Anyone here who recently had their pinion yoke off remember what size the nut is? I'm going to be replacing the seal soon and I want to make sure I have the correct size. Thanks!
bruker is offline   Reply With Quote Quick reply to this message
Unread 10-06-2006, 09:48 AM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's been a while but I'm pretty sure that it's 1 1/8".
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 10-06-2006, 10:47 AM   #3
DaOne
Yes...1 1/8".
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 12:08 PM   #4
heyman14
Anyone know the pinion nut size on front axel on 2005 4.0 wrangler?
heyman14 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 02:32 PM   #5
chris142
Originally Posted by heyman14 View Post
anyone know the pinion nut size on front axel on 2005 4.0 wrangler?
1-1/8
chris142 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 05:15 PM   #6
BigRodney
It's not just any nut though. It's a specific pinion nut. It supposed to be replaced every time it is removed and you can't use a hardware store but.
BigRodney is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 05:21 PM   #7
munroejp
I've changed out 4 pinion seals on jeeps and have re-used the same nut each time. Marked it and re-torqued it and have never had any issues?
munroejp is online now   Reply With Quote Quick reply to this message
Unread 03-02-2015, 05:38 PM   #8
biffgnar
biffgnar's Avatar
So do many others, but technically it is a single use nut.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 05:51 PM   #9
munroejp
I get it just don't think it's anything to get paranoid about. Technically there are torque specs for everything as well but many suggest "snug, one grunt, two grunts, etc..." when asked about torque specs.
Unread 03-02-2015, 06:33 PM   #10
rchase559
I've seen this question asked many times on multiple forums and nearly every response is wrong. The nut is a 3/4"-16 and uses a 1 1/8" socket.
Yes I know that the socket size is what most people are looking for but that's not what they ask.
rchase559 is offline   Reply With Quote Quick reply to this message
