What size is my lift - JeepForum.com
post #1 of 4 Old 10-05-2010, 08:06 PM Thread Starter
jharvey615
Ok I did some measuring and this is what I got front springs look to be about 16 inch from top pad to cup and the rears 13 inch as for the body lift it looks like the biggest mount under the driver's door is 2/ 1/2 but you can not get the tape measure all the way to the top so 3inch body? from the bottom of the body under the door I have 28 inches to the ground the po had 37s on before I got it. I am wanting to ditch the bd lift but do not have the factory bolts now trying to decide is it wort it to buy a one inch bd so I can have a LOCG and still keep a little clearance for a TT and a slip yoke eliminator? I do not know how to post pics in this thread but have some in my gallery if anyone cares to look.
jharvey615 is offline
post #2 of 4 Old 10-05-2010, 08:17 PM
ohtenwillys
looks like just a 3" body lift
ohtenwillys is offline
post #3 of 4 Old 10-09-2010, 02:45 PM
bchjeep
37" with just a 3" body lift... and no modification to the axles or driveshafts?
2015 Jeep Grand Cherokee with Altitude package
SOLD - 2001 Jeep TJ
bchjeep is offline
post #4 of 4 Old 10-09-2010, 03:22 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Sounds like a 4 inch suspension. Stock springs are about 12 inches in front, also you have a 3 inch body as well so you have about 7 inches.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
Lower Control Arm bolt size? Has TuffCounty lift but I believe bolts are stock size. SolidBrass TJ Wrangler Technical Forum 10 11-09-2010 09:00 PM
What size of body lift with a 4" suspension lift? Jeeplady13 TJ Wrangler Technical Forum 14 03-06-2010 02:14 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
Opinion about tire size vs. Lift kit size awol09 TJ Wrangler Technical Forum 25 09-29-2008 06:17 PM
What size lift? neon3kgt YJ Wrangler Technical Forum 13 05-15-2007 11:08 AM
