What size is my gas tank? - JeepForum.com
post #1 of 21 Old 05-13-2011, 04:58 AM Thread Starter
josh_br
2003 WJ
I have a 1997 Wrangler Sport. Does anyone know if it would have the 15 gal. or the 19 gal, or do you know how I would tell (aside from running it low and filling it up)?
Thanks.....looking into a replacement tank after a trail ride where it took a beating....
JB
Josh_Br
2003 WJ (Laredo), 1990 Toyota pickup
Used to have a couple TJ's and ZJ's
josh_br is offline
post #2 of 21 Old 05-13-2011, 05:02 AM
kahjeep
Everything I read said mine would be 19 but when I do the math on approximately how much it costs me to fill it up, it's 15.
I don't know how you accurately find out but I am sure someone on here does.
kahjeep is offline
post #3 of 21 Old 05-13-2011, 05:04 AM
rlkelley
dont know if it would be different but i have a 99 wrangler sport and i have a 15
rlkelley is offline
post #4 of 21 Old 05-13-2011, 05:08 AM Thread Starter
josh_br
2003 WJ
Thanks guys.
A while back I had got the build sheet info from Jeep. I looked for that email last night but couldn't find it. After I did this post I found it, and it turns out I have the 19 gal. tank.
Josh_Br
josh_br is offline
post #5 of 21 Old 05-13-2011, 06:47 AM
Brian86992
Yours is 15. 19 didn't become standard until 1999.
http://www.jeepforum.com/forum/f9/st...ations-452871/
Although mine is 19 my fuel light comes on after using 15 gallons and that's when I fill up so in essence I have a 4 gallon "reserve".
Protect the Constitution
4 linked DD on coilovers
Brian86992 is offline
post #6 of 21 Old 05-13-2011, 07:14 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
If it came with the 4.0L, it also has the 19 gallon fuel tank... IIRC
Knuckelhead is offline
post #7 of 21 Old 05-13-2011, 06:07 PM
kahjeep
That doesn't make sense. I have an '01 and I am telling you it's a 15 gallon tank. There is no way I have 4 more gallons when I am on empty. And mine is the 4L I6
kahjeep is offline
post #8 of 21 Old 05-13-2011, 06:09 PM
biffgnar
biffgnar's Avatar
I'm confused. Why are you doing math based on gas cost to determine how much gas you put in? You realize gas pumps tell you how many gallons you have put in? No math necessary.
biffgnar is online now
post #9 of 21 Old 05-13-2011, 06:15 PM
Knuckelhead
AFSOC Retired
Nope...
post #10 of 21 Old 05-13-2011, 06:42 PM
RubiconRazorbac
RubiconRazorbac's Avatar
I have an '01...
You have a 19 gallon tank.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #11 of 21 Old 05-13-2011, 06:54 PM
kahjeep
Because I didn't look at how many gallons but I remember it cost me $51.00 to fill it up (I had a bit of fuel left) and it was $4.12 a gallon.
On this tank, I am definitely going to pay attention because I want to find out my miles per gallon. So next time I fuel up, I will take a picture of the pump.
I wont keep arguing this, and I want to know for sure. Which I will...soon...as with Jeeps it's not too long before the next fill.
And mine is in kilometers and litres, but I do convert!
kahjeep is offline
post #12 of 21 Old 05-13-2011, 06:56 PM
kahjeep
Yes, LoL I know the pump tells me how many gallons I put in! LoL
kahjeep is offline
post #13 of 21 Old 05-13-2011, 06:59 PM
kahjeep
So when you are on empty you still have four gallons in your tank?
That just seems odd to me. I very well could be wrong but I am feeling stubborn on this one. Sorry, I am female! Laugh.
I guess I am stealing the attention on this thread. Sorry, don't mean to.
kahjeep is offline
post #14 of 21 Old 05-13-2011, 07:20 PM
jbarrett
Hang on just a second boys... I have a '99 TJ, and am pretty sure it doesn't have a 19 gal. tank. Are you saying ALL '99 TJs would have a 19 gal. tank standard? Before reading this I would have bet you a $20 spot I only had a 15 gal. tank...hmmm...
I'm low today, maybe i will run it till she dies and confirm this...
jbarrett is offline
post #15 of 21 Old 05-13-2011, 07:25 PM
Agent620
I have a '99 Sport I6 and have a 19 gal tank. I know because I've filled more than 15 gals, and the manual says I have a 19 gal tank.
Agent620 is offline
How do I tell what size gas tank I have?! JfirEfightErP TJ Wrangler Technical Forum 7 12-10-2009 08:07 PM
What size air tank? Wrangler11 TJ Wrangler Technical Forum 9 12-16-2007 01:49 PM
What size gas tank JeeperAbe TJ Wrangler Technical Forum 8 10-22-2007 11:21 PM
Gas tank size? zworld TJ Wrangler Technical Forum 14 01-04-2007 10:45 AM
gas tank size? Chief F1 Fan YJ Wrangler Technical Forum 3 11-21-2002 12:04 PM
