What size bumpstops do i need with bb and 33s - JeepForum.com
post #1 of 9 Old 05-08-2009, 11:14 PM Thread Starter
trick pony
Ive got a 2in bb and 33s. Will i need extended bumpstops for the back and front and what size should i get...2 inch or 3 inch.
trick pony is offline
post #2 of 9 Old 05-09-2009, 12:22 AM
mudb8
want it rite or rite now?
mudb8's Avatar
minimum of 2" up front, the rear depends only on the shock length to prevent them from bottoming out.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #3 of 9 Old 05-09-2009, 03:30 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
My BB came with them.
TheBoogieman is offline
post #4 of 9 Old 05-09-2009, 04:19 AM
Trombino
Trombino's Avatar
1978 CJ7
The RE BB I had came with them as well -- 2" bumpstop extensions for the rear. I didn't extend the front ones.
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline
post #5 of 9 Old 05-09-2009, 07:05 AM Thread Starter
trick pony
I peiced my kit together. I have skyjacker hydro shocks for up to a 2.5 inch lift i think
post #6 of 9 Old 05-09-2009, 07:13 AM Thread Starter
trick pony
I have the added weight of a winch going up front so i suspect 3 up front and 2 out back would not be a bad idea...right
post #7 of 9 Old 05-09-2009, 07:32 AM
emev0l
Flex the suspension of the jeep until the 33s are almost hitting the fender, measure the distance between the bump stop and bump stop pad on the axle, that's how much bump stop you need.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #8 of 9 Old 05-09-2009, 09:25 PM
mudb8
mudb8's Avatar
weight doesn't affect bump stop length...
33's and 2.5" lift, lift height is irrelevent... 2" bumpstops fully articulated with 25.5" long shocks...
mudb8 is offline
post #9 of 9 Old 05-09-2009, 09:29 PM
CO_crawler
Interesting. I am considering a 2.5 ome kit with 33's. I dont want a BL but would consider a MML and maybe a tcase drop.
CO_Crawler
Crawlin Slow Some Where in CO
CO_crawler is offline
bumpstops, shock length, and tires size. help me iron out the fuzzy points.. mudb8 TJ Wrangler Technical Forum 382 02-01-2016 09:39 PM
where to buy bumpstops 472cid TJ Wrangler Technical Forum 4 07-19-2009 08:45 AM
Bumpstops ?? nevadamike TJ Wrangler Technical Forum 16 05-16-2007 07:20 PM
Bumpstops...How Big? 46hemi TJ Wrangler Technical Forum 2 10-04-2006 03:26 PM
where to get bumpstops ellandoh YJ Wrangler Technical Forum 5 02-09-2006 08:27 PM
