-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   What size bumpstops do i need with bb and 33s (http://www.jeepforum.com/forum/f9/what-size-bumpstops-do-i-need-bb-33s-773585/)
trick pony 05-08-2009 11:14 PM
Ive got a 2in bb and 33s. Will i need extended bumpstops for the back and front and what size should i get...2 inch or 3 inch.
mudb8 05-09-2009 12:22 AM
minimum of 2" up front, the rear depends only on the shock length to prevent them from bottoming out.
TheBoogieman 05-09-2009 03:30 AM
My BB came with them.
Trombino 05-09-2009 04:19 AM
The RE BB I had came with them as well -- 2" bumpstop extensions for the rear. I didn't extend the front ones.
trick pony 05-09-2009 07:05 AM
I peiced my kit together. I have skyjacker hydro shocks for up to a 2.5 inch lift i think
trick pony 05-09-2009 07:13 AM
I have the added weight of a winch going up front so i suspect 3 up front and 2 out back would not be a bad idea...right
emev0l 05-09-2009 07:32 AM
Flex the suspension of the jeep until the 33s are almost hitting the fender, measure the distance between the bump stop and bump stop pad on the axle, that's how much bump stop you need.
mudb8 05-09-2009 09:25 PM
weight doesn't affect bump stop length...
33's and 2.5" lift, lift height is irrelevent... 2" bumpstops fully articulated with 25.5" long shocks...
http://i268.photobucket.com/albums/j...s/PICT0022.jpg
CO_crawler 05-09-2009 09:29 PM
Interesting. I am considering a 2.5 ome kit with 33's. I dont want a BL but would consider a MML and maybe a tcase drop.
The time now is 11:36 AM.
