What side is up? OME spring(Pic) - JeepForum.com
post #1 of 7 Old 08-06-2010, 01:45 AM Thread Starter
inglisleslie
What side is up? They say the smaller end goes up top but i cant tell any size difference? Anybody know?
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #2 of 7 Old 08-06-2010, 01:54 AM
MrRage
The tag on the spring points down. Tt least thats what I've noticed.
MrRage is offline
post #3 of 7 Old 08-06-2010, 02:05 AM
ElementX
That looks like a rear spring. I think rear springs are the same on either end. If you want to be absolutely sure, just measure the diameter of the coil ends.
The front springs have a smaller diameter coil at the top.
'98 TJ Sport
ElementX is offline
post #4 of 7 Old 08-06-2010, 02:06 AM Thread Starter
inglisleslie
it is rear
/l ,[ ______],
()_) ()_)--O-)_)
post #5 of 7 Old 08-06-2010, 02:08 AM Thread Starter
inglisleslie
what do you guys think about spacer? I dont like the looks of it...should it go above the OEM stopper that was in the spring cup
/l ,[ ______],
()_) ()_)--O-)_)
post #6 of 7 Old 08-06-2010, 08:02 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
spacer looks fine. pictures suck bad tho, cant see jack.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 7 Old 08-06-2010, 11:59 AM Thread Starter
inglisleslie
its my back up cell phones camera...i dont own a point and shoot...i want a dslr!
/l ,[ ______],
()_) ()_)--O-)_)
ome , old man emu , direction , tj , wrangler , spring , coil
Front driver side spring falling out... thejafe TJ Wrangler Technical Forum 34 05-08-2010 10:09 AM
Passenger side spring continues to rotate itself CCJ TJ Wrangler Technical Forum 13 12-08-2009 09:16 PM
Leaf spring (frame side) nut size? FreemasonJeeper YJ Wrangler Technical Forum 4 07-07-2009 11:02 AM
No passenger side coil spring retainer? Brandon97TJ TJ Wrangler Technical Forum 7 11-12-2008 08:35 PM
Driver's side spring retaining clamp necessary? planman TJ Wrangler Technical Forum 3 03-26-2007 04:31 PM
