What siaze D-rings fit LoD front Bumper? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What siaze D-rings fit LoD front Bumper?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!
Unread 12-13-2007, 09:37 PM   #1
jthompsn
Does anyone know what size D-rings fit the LoD front Bumper, is it 5/8 or 3/4?
Thanks!!!
2002 TJ Sahara, 4.0 I6, auto, d30/d35 with 3.73's, 33x12.5 bfg mt's, ome 2" lift and steering stabilizer, 1.25" JKS BL, JKS 1" MML, A to Z Fab ww2ww Rocker Guards, Teraflex adj front trac bar, AEM brute force intake, Magnaflow cat-back exhaust, optima yellow top, LoD front bumper with guard, LoD rear bumper with tire carrier, Delta Sky Bar, Delta Xenon Quad Bar H4 Headlamp conversion, Hi-lift...
jthompsn is offline   Reply With Quote
Unread 12-13-2007, 10:24 PM   #2
BYuen
3/4" is the biggest you can run.
http://www.jeepforum.com/forum/showt...17#post4536217
BYuen is offline   Reply With Quote
Unread 12-13-2007, 10:25 PM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
3/4" seems to be pretty standard, all mine are 3/4".
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 12-14-2007, 06:46 AM   #4
jthompsn
Thanks for the thread link, I ran into the same problem this summer with my rear LoD bumper. I ordered 3/4 D-rings from ARB and they were too big for the hole. So, I picked up some 5/8's and they worked fine but rattle around a little on the bumpier stuff.
Unread 12-18-2007, 10:08 AM   #5
BYuen
For future reference, the LoD front bumpers will fit a 3/4" shackle with a 7/8" pin diameter. I had to take a drill and grind the powder coat along along with a very tiny amount of metal off on the inside loop of the shackle mounts. They fit snug and don't rattle.
7-ton WLL and 70,000 lb break strength Trail Duty Shackles: 15 bucks a pair!
