Quantcast what should i avoid with d35 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > what should i avoid with d35
Old 10-01-2007, 01:57 PM   #1
trav_k1234
I know I know, D35's suck. but I need to know what kind of upgrades and terrain I should avoid and keep my 35 out of, until I can afford a D44 in a few centuries.
ΜΟΛΩΝ ΛΑΒΕ
trav_k1234 is offline   Reply With Quote
Old 10-01-2007, 02:00 PM   #2
fordfreak$
Honestly, with stock tires I wouldn't worry at all. Keep it from bouncing and jerking in the rocks. Other then that, let her have it.
2000 TJ, Clayton and Ford 60's
BOFA Racing
fordfreak$ is offline   Reply With Quote
Old 10-01-2007, 02:02 PM   #3
trav_k1234
Well i am also wanting to get 31's and ditch the GSA's
ΜΟΛΩΝ ΛΑΒΕ
Old 10-01-2007, 02:11 PM   #4
JeepinYahoo
1977 CJ5
At absolute MAX 31", no rocks, light mud, snow and sand should be ok though. Also avoid using a lot of gas/stupid pedal.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline   Reply With Quote
Old 10-01-2007, 02:11 PM   #5
kingvm
kingvm's Avatar
2005 WK
The main thing to avoid is the rightmost pedal. You will be fine with 31's and an open or limited slip diff as long as you don't try to get over up things with high rpms. I have found that anything I could not get up/over at 1200-1500 rpms probably should be bypassed anyway.
I actually ran my D35 locked on 31's for 2+ years and the only breakage was when I forgot rule 1. With open or limited slip carriers there is less stress so don't let the horror stories prevent you from using the jeep.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline   Reply With Quote
Old 10-01-2007, 02:11 PM   #6
fordfreak$
WEll just be nice to the skinny pedal in the rocks and other high traction areas. Avoid bouncing and jerking at all times. Don't forget about the stellar d30 up fornt as well. 31's though will still leave you with a good amount of freedom to do what you will. I think actual "rock Crawling" is the only area you will need to worry about. Use common sense on steep uphills and technical areas. If it's smooth hammer down!!!!
BOFA Racing
Old 10-01-2007, 04:25 PM   #7
lupinsea
Things that tend to break D35's:
  • Large tires (33"+)
  • Heavy throttle input
  • LOCKERS
  • Spinning / hopping tires suddengly grabbing traction
As people have been saying, be easy on the gas and if the tires start hopping or spinning back off, pick a different line, or winch through.
While the D35 is has a higher failure rate due to its nature as a weaker axle they can be wheeled "ok" so long as they aren't pushed much. I've talked to many people who've been wheel'n them for years without problems. They also tend to drive them a bit easier. I've been running mine for 3 years now on many wheel'n runs without significant problems.
HD 27 spline alloy axleshafts are available. Talke to Randy's Ring and Pinion or other suppliers for the Yukon Axle and Gear's HD D35 27 spline shafts. They provide a ~20% upgrade in stregth. I still wouldn't run a locker with these shafts but the give a little extra piece of mind for those with LSDs.
Avoid lunch box lockers. These replace just the spider gears in the diff and do not address the axleshafts.
Super35 upgrades (with lockers) are fine as they replace not only the whole diff but also the axleshafts. Yields an axle as strong as a D44 I believe, and guys have successfully run 35" tires with lockers on the SuperD35 upgarded axles.
The D35 IS weak but that doesn' mean you can't enjoy wheel'n your Jeep. Just be careful. I am.
- Jay
lupinsea is offline   Reply With Quote
Old 10-01-2007, 04:45 PM   #8
jeepnurse
jeepnurse's Avatar
I've been running 35s on my locked D35 for a few months now, no problem. But I know when to take it easy, and I'm lucky if I get in any rough stuff more than about once a month.
04TJ 4.0 rc 4" susp lift, jks 1.25" bl, 1" front spacers, brown dog mml, aa sye, tw ds, 35" mtrs, rock crawler front bumper, barnes 4x4 rear bumper and tire carrier, ar wheels, 8.8 with lockright, jeeperman sliders, warn m8000, jks quicker discos
95ZJ 4.0 rusty's 3" susp lift, 2" front spacers, 33" mtrs, addcos front and rear, black diamond front track bar, jks rear track bar, jks quicker discos, trimmed fenders
It just goes to show you can't always tell the depth of the well by the length of the handle on the pump.
jeepnurse is offline   Reply With Quote
Old 10-01-2007, 04:54 PM   #9
bman9089
You get what you pay for
bman9089's Avatar
Also keep in mind the sheer amount of people running D35s. Yes, the axle is weaker. There's no argument there. But if twice as many people are running 35s, than 44s, then you will hear twice as many bad stories.
Heavy torque is what causes so much stress on the axle. If you don't try to crawl up things you shouldn't, and take it easy on the axle, you won't have problems. Keep it within reason and you should be alright. Just always keep in mind what you are sitting on and baby it for now. You can still enjoy your jeep. And at 31s, I don't think you have too much to worry about. 33 + is when you need to be careful, and pay attention to how you wheel/drive.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
† Christian Jeep Club †
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline   Reply With Quote
Old 10-01-2007, 05:01 PM   #10
McLovin
1991 XJ Cherokee
http://www.youtube.com/watch?v=WSaBWo5qVaw This guy has been running stuff like this on 33's locked for 4 years without a problem. This was the first shaft he has broke.
I wheel in the sand 90% of the time and the mud 10% of the time. Knock on wood, but I haven't had any problems other then one set of spider gears going bad. Some guys seem to run them forever without many issues and others seem to break them turning a corner. I'd like to upgrade to a super 35 kit or a dana 44, but it hard for me to replace something I have never broke.
McLovin is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
