What's this and why is it so angry? - Page 6 - JeepForum.com
post #76 of 82 Old 03-23-2010, 06:13 AM
SwissK31
If the cam position sensor gear went bad, good chance you'll have to replace the cam also...IMO
I took it off to take a look at it and it had a little wear on the gears but nothing real bad. It's making the same noise as the op, so i figure i might as well replace it now be for I do any real harm to the engine. Why do you think that I would have to replace the camshaft as well?
SwissK31 is offline
post #77 of 82 Old 03-23-2010, 07:32 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
There's a TSB for your year of 4.0L. As the cam position sensor gear goes bad, so does the drive gear which is part of the camshaft...
Knuckelhead is offline
post #78 of 82 Old 03-23-2010, 08:47 AM
roadkill
I thought the TSB was for 05s only
roadkill is offline
post #79 of 82 Old 03-23-2010, 08:54 AM
Sxinc
Im sitting in training and bursted out laughin cause of the sound.
Originally Posted by StvDiego View Post
Running a straight pipe on your Jeep would be like boinking your best friends hot mom.
Feels hot and wild when you first start it up but after awhile it's just noise
Sxinc is offline
post #80 of 82 Old 03-23-2010, 01:16 PM
Knuckelhead
AFSOC Retired
One thing to remember about TSB's, they may come out in one year and address that year. That doesn't mean that they don't address to following years also. Just like the TSB's for the #3 injector insulator and the 7 blade fan and fan clutch. When I was at Moab in 06, there was an 06 Rubicon with the cam position sensor shaft snapped off...
post #81 of 82 Old 03-23-2010, 01:26 PM
iceman8
My 06' was making the sound upon cold start up, started about 17K miles. I pulled the cap off the beast and could see what looked like a tiny bit of oil around the upper part of the shaft. Must be getting lube, off I went on a 1400 mile road trip. Noise never returned until just yesterday. Minor, but it's there again. My build date is March 2006 FWIW. At some point I plan to pull it and look at the internals, just to be sure.
iceman8 is offline
post #82 of 82 Old 03-23-2010, 05:09 PM
SwissK31
I just looked at my build sheet and it said was built in September of 05. Do you think Jeep will cover this, I no longer have a warranty on it. Where do i go to look at the TSB? Is there a link or something i can look at or do I have to call the dealer to find out?
SwissK31 is offline
Angry Sparrows Hitmanx800 TJ Wrangler Technical Forum 10 04-26-2012 08:36 PM
Angry Swallows jepmn03 TJ Wrangler Technical Forum 19 03-02-2009 11:09 PM
A little angry please help!! xulcuz TJ Wrangler Technical Forum 13 06-22-2007 09:09 AM
Uh oh, angry sparrow is on to me jzmtl TJ Wrangler Technical Forum 8 06-11-2006 06:56 PM
Angry Sparrows still there!!! jeepaholictj TJ Wrangler Technical Forum 1 06-07-2006 10:06 AM
