What's really the point? - JeepForum.com
post #1 of 17 Old 09-14-2006, 12:04 PM Thread Starter
ToothpickJ
Ok, I know that if you add a 1-2" body lift that you can fit bigger size tires on to a stock suspension Jeep, but what's the point of going any bigger than a 2" body lift?
The reason I ask is, I seen a fellow wrangler going down the road today with at least a 3 inch lift with stock tires/rims. I am going to assume he has other offroad tires/wheels to go off roading...but...it looked half assed...
Is a body lift that much cheaper or better than a 2 inch RE BB?
I have also heard that body lifts can mess up something, sorry that is so vague but I can't remember what it is it can mess up. Is there any truth to it?
ToothpickJ is offline
post #2 of 17 Old 09-14-2006, 12:06 PM
woody-77
Vulcan FTW
woody-77's Avatar
2007 FSJ Cherokee
My brother in law has a 2" body lift and 6" suspension lift....he has 37" tires....the 2" body lift is useful on his Jeep and actually looks fine.
I would go with a REBB over a body lift anyday.
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5
Thread deleted by Jerry Bransford
Reason: This was beyond human decency... posting about someone's girlfriend is ****ed up.
woody-77 is offline
post #3 of 17 Old 09-14-2006, 12:10 PM
Ryuu600
well first off the BL requires you to relocate your 4wd shift bracket because on the TJ it is located on the body. This can make for a level of insecurity as to the reliability of the shifter. I had a 97 TJ in '96 when they were first release that was raised with a 3" BL by the dealer and the way they did the shifter move was horrible, sometimes it would not shift at all and others it would shift into 4wd but not back into 2wd.
The other bad side of excessive BL is the increased possibility of the body bolts shearing in a rollover or accident. Although this is a rare occurence there are documented cases of it happening.
The major retarded part of this is that you don't gain any ground clearence from the lift itself. You only gain extra clearance from the tire size increase whereas with a suspension lift, even a BB, you receive extra clearance from both the tires and the lift.
Alot of Dealers will use the BL to make there "special editions" of the Wrangler so they can get the looks without the cost.
/l ,[____],
l---L –0lllllll0-
()_) ()_)--o-)_)
'06 TJ X Blue w/dark khaki top, 4.0L, 6 spd, 3.73, 30x9.5R15 Wrangler GS-As mounted on Ravine wheels, Soft-top w/half doors, 4 100w ProComp Offroad lights(2 bumper, 2 windshied), Cobra 29 LTD w/4' Firestik, Custom rear storage box.
Ryuu600 is offline
post #4 of 17 Old 09-14-2006, 12:34 PM Thread Starter
ToothpickJ
That's basically what I was coming at but didn't want to say it...you really do not gain clearance from a BL, so I was wondering what the point was.
post #5 of 17 Old 09-14-2006, 12:37 PM
bobbert350
bobbert350's Avatar
well the body lift helps u put bigger tires on without getting a bigger supension lift and putting more stress on the car...body lifts are good but if i wouldnt recoment getting one unless u already have a lift or are getting a lift...and if ur not getting a lift and want a little bigger tire get one other than that o well
bobbert350 is offline
post #6 of 17 Old 09-14-2006, 12:57 PM
mdm
Farm Wheeler
A BL is needed for some of the "belly-up" skids and to install some of the gas tank skids that give more clearance under the tank. These are a couple of good reasons for installing a BL.
mdm is offline
post #7 of 17 Old 09-14-2006, 01:15 PM
Ryuu600
yeah but if you are installing that kind of underbody protection you are doing enough hardcore wheeling that you have more than just a 3" BL on your rig.
/l ,[____],
l---L –0lllllll0-
()_) ()_)--o-)_)
Ryuu600 is offline
post #8 of 17 Old 09-14-2006, 01:27 PM
Spectre66
The previous owner of my 99 put a 3" body lift on it and I'm here to tell you, it created some problems with the shifters... current plans are to take it back down to a 1" or 1.25" BL
Spectre66 is offline
post #9 of 17 Old 09-14-2006, 01:34 PM
mdm
Farm Wheeler
A 1" BL will cover these things.
mdm is offline
post #10 of 17 Old 09-14-2006, 01:38 PM
Ryuu600
Yeah I know, but the question was about doing a 3" lift and the point of that mod.
Anyway. More often then not this is someone that wants the look but will never wheel the jeep.
/l ,[____],
l---L –0lllllll0-
()_) ()_)--o-)_)
Ryuu600 is offline
post #11 of 17 Old 09-14-2006, 01:44 PM Thread Starter
ToothpickJ
SO...basically all anyone would ever really need is a 1" BL because of shifter problems on anything taller than that? And that 1" is just in case you are wanting to put skid plates on before you get into any heavy suspension modding...even though I wouldn't consider an RE BB a heavy suspension mod.
post #12 of 17 Old 09-14-2006, 01:52 PM
mdm
Farm Wheeler
Agreed. My point is that 1" of BL will do what you need. I've seen several Jeeps with a 3" BL. A lot of them were installed by dealers (mostly used car dealers) to make the Jeep look hot and get some sucker to stop and look at it. There was a thread on this forum a while back where a guy was asking for opinions on a used Jeep for sale. He provided a link to the dealers web site. Every one of the Jeeps shown on that site had a 3" BL. The web site even stated that a "lift" and 31" tires were installed on every Jeep they brought to the lot to get it ready for you. It's good eye candy if you don't know what you are looking at.
On the other hand there is a fellow in Germany that has posted here a few times. In his country the law states that any modifications made to the vehicle has to be done using parts/methods approved by the goverment. From what he said this makes suspension lifts limited in the number of types available and very expensive. But BLs were approved and a lot cheaper. Guess what you do there if you want to run bigger tires?
mdm is offline
post #13 of 17 Old 09-14-2006, 02:00 PM
mdm
Farm Wheeler
There are two types of skids that frequently require a BL in order to install them.
A "belly-up" or "tummy tuck" skid is a skid that replaces the stock transfer case skid. They increase the clearance under the transfer case by raising the transfer case and also provide a much cleaner/smoother skid than the stock skid. The BL provides the room necessary above the transfer case to allow it to be raised.
There are a couple of gas tank skids that replace the stock skid and raise the tank up to provide more clearance under the tank. Some year models require a BL in order to install these replacement skids.
These are the only times a BL is required to install new skids.
mdm is offline
post #14 of 17 Old 09-14-2006, 04:41 PM
fried_gold
fried_gold's Avatar
Most people don't need more than 1", but it's not because of shifter problems, those can be fixed, it's simply because that 1" is usually enough for what they need. When you install new things sometimes they just need a little more wiggle room, and a 1" BL gives you that.
Some other reasons to need a 1" BL:
If you install bigger tires but they rub the fenders a little, you can do a BL to lift the fenders up an inch. People can often get away with running tires that are a little too big for their lift this way.
If you have driveline vibrations and put in a motor mount lift to fix the vibes, the motor is lifted one inch so the body needs to be raised as well or the hood will hit the motor when you close it.
fried_gold is offline
post #15 of 17 Old 09-14-2006, 10:30 PM
folkxrock
folkxrock's Avatar
I think a good rule here is this - the production of a part does not make it necessary. I would classify the 3in. body lift in with the item I will describe below.
Take the tards running around with a 6ft wing on the back of a civic. Do you think they need "extra downforce" to keep the rear wheels hooked up? No, the part is just in the latest edition of "popular rice burning" and they are retarded.
Good uses for a 3in. body lift
1) extra clearance to wash the under side of the body
2) extra place to sit (or misplace) nuts and bolts when you are working on the Jeep (the big dumb looking space on between the frame and body).
3) Extra hand hold if you are acting out a scene from "The A Team".
Please feel free to add your own suggestions to this list.
2011 Call of Duty Rubicon Trying to keep it bone stock - see how long this lasts...
2006 Rubicon - SOLD RE 3.5 Coils, RE Ext. Rear SB Links, RE SS Brake Lines
JKS CV Track Bar Bracket, JKS Upper and Lower Arms,(Front & Rear), JKS Trackbars, JKS Disconnects, Currie Shock Ext. Brackets, OME Shocks, OME Steering Stabilizer , Custom CV Driveshaft, MT Classic II 15x8's, BFG MT's 33x12.5's, Jeeperman Skidz
folkxrock is offline
What's the point? triplej1954 YJ Wrangler Technical Forum 29 02-11-2010 10:14 PM
5-point in a TJ mpyusko TJ Wrangler Technical Forum 35 12-18-2007 04:06 PM
tow point rob1525 TJ Wrangler Technical Forum 12 03-21-2007 11:02 AM
At What Point............... LowCash TJ Wrangler Technical Forum 1 11-24-2006 09:12 AM
Tow Point.... mudbugII YJ Wrangler Technical Forum 11 12-19-2005 05:58 PM
