What's this device...It's clicking - JeepForum.com
post #1 of 22 Old 10-09-2009, 06:23 AM Thread Starter
89WhyJ
My father has a 2006 TJ. He emailed me this morning asking about a device attached to the passenger side of the engine block, just ahead of the oil filter. Its about 5 or 6 inches is diameter, with about 3 or 4 wires coming out of the front side of it. The top is oval with 2 torx screws holding the top plate down.The whole thing is about 8 - 10 inches high. He is concerned because right now it is making a lot of hard clicking sound after you start the engine. It goes away after about 10 minutes. He says you can feel the clicking if you put your hand on it.
Anyone know what this thing is? I live in VA and he is in NC, so I can't really look at it myself.
89WhyJ is offline
post #2 of 22 Old 10-09-2009, 06:29 AM
Dirtrider5490
He isn't anywhere near winston-salem is he? be happy to help out a fellow jeeper, I'm also a tech.
97 TJ, 4 banger, 5 speed, 2.5" RC lift, 1.75" BDS coil spacers up front, Tuffy center console, Hurst T-handle, 33x10.50 boggers, docked front bumper with 10k winch, rear warn bumper, No sway bars, Hella 500FFs on the windshield,
Originally Posted by comptiger5000 View Post
Most cars punish you for imperfect maintenance with a slightly shortened life, while Jeeps tend to get pissed and explode in your face.
Dirtrider5490 is offline
post #3 of 22 Old 10-09-2009, 06:39 AM Thread Starter
89WhyJ
I really appreciate it. He's in New Bern though. Quite a ways from Winston-Salem.
89WhyJ is offline
post #4 of 22 Old 10-09-2009, 07:20 AM
txboy72
got any pics?
05 Unlimited, RE 4.5, 4.5 springs, adjustable front and rear track bar, 33x12.5 MT Baja Claw Radial, 15x8 MT Classic Locks, 4.88's, Tom Woods rear cv and sye kit superwinch, RRC front bumper, rear bumper with tire carrier, rocker guards, home made 1.5 seat risers
txboy72 is offline
post #5 of 22 Old 10-09-2009, 07:24 AM
NotURMailman
NotURMailman's Avatar
Any chance he would know how to take and send a digital picture? (If he's anything like my parents that's a "no"! )
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #6 of 22 Old 10-09-2009, 07:26 AM Thread Starter
89WhyJ
Originally Posted by txboy72 View Post
got any pics?
Unfortunately no, he's in an all day meeting at work.
89WhyJ is offline
post #7 of 22 Old 10-09-2009, 07:31 AM
Best4x4
Sounds like where the cam/crank position sensor goes to me. That's where the "dizzy" distributor used to go on the older ignition systems vs the distributorless ignition system found on an 06.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #8 of 22 Old 10-09-2009, 07:40 AM Thread Starter
89WhyJ
Originally Posted by Best4x4 View Post
Sounds like where the crank position sensor goes to me. That's where the "dizzy" distributor used to go on the older ignition systems vs the distributorless ignition system found on an 06.
Thanks for the insight. If that's the case, do you have any idea what would cause the clicking sound?
89WhyJ is offline
post #9 of 22 Old 10-09-2009, 08:26 AM
Hesher420
Not the crank pos. sensor. The cam pos. sensor. The crank sensor isat the back of the engine, top-side, just in front of the transmission.
The CAM position sensor is in the oil filter region.
EDIT:If you look on Autozone.com at how to replace a cam sensor, it has pics, let us know if that is it.
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #10 of 22 Old 10-09-2009, 01:35 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
There's a TSB out on those for failing. Take it to a dealer to have it checked...
Knuckelhead is offline
post #11 of 22 Old 10-09-2009, 02:26 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
That doesn't sound like a CKP to me, and where the distributor use to be is now the CPS (camshaft position sensor). CKP (crankshaft position sensor) is on the drivers side at rear of block in the bell housing!
GOLENJEEPTJ is offline
post #12 of 22 Old 10-09-2009, 03:15 PM
mmf
It's the oil pump drive gear/cmp sensor assembly.
Mine made a clicking which eventually grew to a knocking noise. Replaced the entire assembly.
The noise is from the endplay in the shaft, the driven gear on the base of the shaft literally slams up into the housing where the hold down mounts. In the TSB there is measurement betwen the top of the gear and housing that determines replacement.
mmf is offline
post #13 of 22 Old 10-09-2009, 04:17 PM
RubaDub06
Sounds like the CPS to me to. Mine went out earlier this year. I think it cost about $130 from the dealer for the whole assembly and I replaced myself. When mine went out, I couldn't go over 2400 rpms.
When was the last time you got an adrenaline rush at 3 mph?
RubaDub06 is offline
post #14 of 22 Old 10-09-2009, 07:49 PM
Best4x4
I just offered my opinion. It's either a cam/crank sensor.
Best4x4 is offline
post #15 of 22 Old 10-09-2009, 08:13 PM Thread Starter
89WhyJ
Thanks for all the help guys. Sounds serious enough for him to take it in. I appreciate it!
89WhyJ is offline
name that device tato1111 Wrangler General Discussion 2 04-23-2009 06:19 PM
Does my Wrangler X have a cut-off device? gsxr150 TJ Wrangler Technical Forum 8 09-22-2007 01:32 PM
best airdown kit/device????? PatriotCrawler TJ Wrangler Technical Forum 34 04-17-2007 06:57 PM
What is this device? bgmiller YJ Wrangler Technical Forum 15 11-07-2005 06:46 PM
Flotation Device? WranglerEyes YJ Wrangler Technical Forum 3 06-10-2004 06:33 AM
