What's the best Tummy Tuck Skid? What CV Shaft to get? Etc? - JeepForum.com
post #1 of 52 Old 06-01-2008, 03:54 PM Thread Starter
jtice
I cant stand it anymore, I Have to get rid of the stock Skid/Scoop.
I dont even have my Jeep lifted yet, want to at least get the stock tires burned off first.
But I am pretty sure I want to go ahead and tummy tuck it.
I ground out on the factory skid continuously, and last week I busted one of the locker pumps all to hell in a creek bed.
Seems that everyone likes the Nth Skid alot.
https://secure.aev-conversions.com/s...ode=NTH14021AA
But I think its the most expensive one out there.
What alternatives are there, and are they even worth looking at?
I also know that there are a few things I need to get and do in order to make this work properly,
but I wanted to check here to make Sure I know every single thing involved in this before I get started.
So far, I think I need a 1" body lift, 1" motor mount lift, and a CV shaft.
So, that leads me to my second main question,
What CV shaft should I get?
BTW, this is for an 05 SWB Rubicon, that will eventually have a 3" spring lift, and JKS adjustable arms all around. With 33" tires.
Thanks
~John
99 Jeep TJ
jtice is offline
post #2 of 52 Old 06-01-2008, 04:01 PM
safarimike
I used an xj front shaft and had it cut down to fit my rear d/s application with sye. A lot cheaper than buying a tom woods imo.
1999 Jeep Wrangler Sport
safarimike is offline
post #3 of 52 Old 06-01-2008, 04:55 PM
rmack
i like the 33 engineering skid. here is a link to it.http://www.offroadtoystore.com/Merch...ory_Code=33eng
rmack is offline
post #4 of 52 Old 06-01-2008, 05:11 PM Thread Starter
jtice
Hm that one is interesting, seems you can take the skid off, and the tranny is still secure.
Though it seems smaller front to back, seems its not covering as much?
Oh BTW, I have a 6 speed manual, and I have a Skid Row oil pan skid that I would like to still use.
~John
99 Jeep TJ
jtice is offline
post #5 of 52 Old 06-01-2008, 05:15 PM
daveshan
Feeding the money pits
daveshan's Avatar
I have an '01 with a 33 engineering skid and my SkidRow engine skid bolted right up to it, made a nice smooth skid from the front to rear.
I highly recommend the 33 engineering skid (and SkidRow) they've taken a beating.
Dave Shannon
Durango, CO
Gone but not forgotten
'56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr
daveshan is offline
post #6 of 52 Old 06-01-2008, 05:36 PM
njsjeep
The Rokmen skid will be available soon. I have their gas tank skid and it is well made.
http://www.rokmen.com/products/skid_...tank_skid.html
I used a Teraflex Belly UP skid on my TJ since I also did a mml/bl and it was available locally and was cheap (craig's list). It adds a lot of clearance and probably wouldn't work without the mml/bl but it appears well made and was easy to install but I did have to make a mounting bracket to reposition the locker pumps.
http://www.quadratec.com/products/16192_001.htm
njsjeep is offline
post #7 of 52 Old 06-01-2008, 08:27 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
JeepMedic used to be the best, but since they are out of business....then i'd look at Rokmen + a long arm Skid Row engine skid plate. its the closest combo to the awesome JeepMedic setup (i love mine!)
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 52 Old 06-01-2008, 09:10 PM
solarpower
Yep love my medic as well.
Clayton makes a nice skid, 33 is nice as well.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #9 of 52 Old 06-01-2008, 10:13 PM
Crashnburn80
Crashnburn80's Avatar
With the Nth skid and stock suspension on a Rubicon you will NOT need a cv driveshaft and rear adjustable UCAs. This is due to Nth's low profile tranny mount. Later when you lift these items would be required. Check out the 'Nth TT' link in my sig for a writeup. The Nth skid is an outstanding piece of workmanship. Depending on the terain you wheel in, the Nth is a far superior design strength wise to 33 Engineering. Anyone who has seen both would not disagree, but if your not on rocks it wouldn't really matter.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #10 of 52 Old 06-01-2008, 10:40 PM Thread Starter
jtice
I figure I should still do a 1" body and motor lift anyway though, correct?
Or is there no reason to, if the Nth Skid doesnt need the body lift?
Yea, I could hold out of the CV shaft till I actually do the lift.
The 33 Engineering one seems very low profile, but doesnt seem to cover as much.
I will definitely be on the rocks also, at the very least, we do alot of stream beds here.
~John
99 Jeep TJ
jtice is offline
post #11 of 52 Old 06-01-2008, 10:44 PM
raskull
raskull's Avatar
http://www.jeepmedicfabrication.com/
Jeepmedic only does local sales now.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #12 of 52 Old 06-02-2008, 09:13 AM
tctrjeep
TeraFlex
We went with a TeraFlex Belly-Up Skid Plate and their ESS (Extreme Short Shaft) SYE. It has worked very well for us. We scored a 702 on a 30-degree ramp this weekend at a show and took 3rd place in the Daily Driver category. Not bad for a 3" lift.
Here is an article covering what we did and why we went with TeraFlex
http://www.commtechreview.net/jeep/teraflex1.htm
Emergency Communications & SAR Project Jeep
We have a new Domain! Find us at:
tctrjeep is offline
post #13 of 52 Old 06-08-2008, 10:41 AM
redsoxski
redsoxski's Avatar
I don't suppose you have a picture of the 33 skid with the Skid Row one. Just curious how they mate up and if its a smooth interface.
redsoxski is offline
post #14 of 52 Old 06-08-2008, 10:56 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I built a custom belly up. I had it between 1/2" and 2" below the frame. It's currently 2" because of my control arm mounts. Rocks were getting caught between them. I also have a MML and a BL but i'm going to try to take the BL off and leave the MML.
I have the early model JB super short and a woody shaft that was rebuilt locally when i damaged it because it was cheaper to do it that way. it did void the woods warranty by having it done locally.
since you have a rubicon you may be able to get by with out having to do a shaft kit.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #15 of 52 Old 06-08-2008, 07:32 PM
daveshan
daveshan's Avatar
I can snap a couple tomorrow, just got in from a long day.
Dave
Dave Shannon
Durango, CO
daveshan is offline
any one got 33 tummy tuck with a oil pan skid? emahan01 TJ Wrangler Technical Forum 15 04-09-2009 03:43 PM
TNT Tummy Tuck/Flat Belly Skid snellav TJ Wrangler Technical Forum 6 03-20-2008 10:55 PM
skid/tummy tuck Heep TJ Wrangler Technical Forum 12 08-22-2007 07:36 PM
confused about the skid row and nth degree tummy tuck minileprechaun TJ Wrangler Technical Forum 7 05-26-2007 10:19 AM
CV shaft length w/ RE 3.5 & tummy tuck? blacktjsport TJ Wrangler Technical Forum 3 11-28-2006 12:12 PM
