What is the right way to remove a control arm bracket? - JeepForum.com
post #1 of 5 Old 12-20-2011, 09:21 PM Thread Starter
Smitty98TJ
So the other day i hit a ditch going a little too fast and bent my driver front lower control arm bracket, i was goint to just bend it back but found some cracks in the metal where the bracket bent and i'm not going to risk anything so i bought a new bracket from Rubicon Express, i just don't know how to go about removing the old bracket, will heat from a torch warp the axle? How should i go about doing ths? Here's some pics
CA bracket.jpg   CA BRacket 2.jpg   CA Bracket 3.jpg   CA Bracket 4.jpg   CA Bracket 5.jpg
http://www.jeepforum.com/forum/f22/1998-tj-sport-build-1097517/
Smitty98TJ is offline
post #2 of 5 Old 12-20-2011, 09:23 PM Thread Starter
Smitty98TJ
Pics are HUGE. sorry about that
post #3 of 5 Old 12-20-2011, 09:33 PM
StvDiego
I'd get a BFH, beat it back in place, weld it and weld on Currie mini-skids, otherwise;
Get a cutting wheel on your grinder, cut off as much as you can (mini/die grinders work well in close quarters), then grind the rest off leaving about 1/8". Switch to a flapper wheel, get a smooth, clean surface, weld on new bracket. Do not weld too long in one place and let the tube cool between welds
Then the add Currie mini-skids or fab your own and help prevent this in the future
StvDiego is offline
post #4 of 5 Old 12-21-2011, 03:26 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
plasma cutter
oxy-fuel torch
cut off wheel on a grinder
in that order of easy removal. finish up with a flap wheel to get the tube smooth in either case.
ratmonkey is offline
post #5 of 5 Old 12-21-2011, 03:18 PM Thread Starter
Smitty98TJ
Thanks guys
axle , control arm , control arm brackets , rubicon express
Upper control arm bracket...GONE!!! bdc961 TJ Wrangler Technical Forum 16 10-20-2010 09:43 AM
Is it ok to remove the transfer case linkage body bracket and drive? chaznad TJ Wrangler Technical Forum 2 10-25-2009 12:10 PM
New Control Arm Bracket? IH8ROADZ TJ Wrangler Technical Forum 15 09-21-2009 07:57 AM
Control Arm Bracket gatornut30 TJ Wrangler Technical Forum 12 11-27-2005 05:31 PM
Cant remove TSB body bracket because of LINE-X job, got PICS so u can see chaznad TJ Wrangler Technical Forum 9 09-25-2005 07:24 PM
