what OME spring rate should i get? - JeepForum.com
post #1 of 3 Old 04-26-2005, 08:38 AM Thread Starter
paroxysym
2007 WK
i know they have 3 different spring ratings(soft, medium, heavy) so what should i get? im a bit of a tankass, well im a big dude at 6'5 and 320. i also lug around a few friends as well. will the soft springs sag more with this weight? im also planning on a winch as well for the front. so what do you recommend? i usually have 4 people in the jeep plus so gear. i also have a soft-top. so what do you suggest?
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #2 of 3 Old 04-26-2005, 08:46 AM
TJinWV
TJinWV's Avatar
I went with heavy front and back. More lift for the bux. You (and I) may get some front-end sag with the winch and soft top, though. I don't have mine installed yet. But I do have 3/4" spacers to balance things back out if I need 'em.
Dan - TJinWV <>< |
2002 TJ, 2" OME lift, ARBs
TJinWV is offline
post #3 of 3 Old 04-26-2005, 11:20 AM
TJ_with_Tusks
go with the heavy, for sure. I ordered mine, got the LJ (unlimited) heavy springs. they are even stiffer than the HD TJ springs. I am running a soft top now, but will be putting on rock bumpers front and rear, and a winch on the front. Soft springs and usually for stock jeeps with softtops, mostly on road driving. I went through Dirk at DPGoffroad.com. He recommended my setup.
04' Columbia TJ
33" BFG AT's, OME HD lift, front airbag suspension, teralow 4:1 kit & supershort shaft kit, TW CV shaft, 4.10 gears, JKS body lift, track bars and quicker disconects, Warn 9.5ti, warn front bumper, garvin wilderness rack, and solid cast aluminum tusks,
TJ_with_Tusks is offline
Spring Rate Spring Info Thread mississippi_xj YJ Wrangler Technical Forum 32 07-11-2013 03:37 AM
RE Spring Rate BYuen TJ Wrangler Technical Forum 1 01-20-2008 11:36 AM
RE Spring rate? chefdab TJ Wrangler Technical Forum 4 01-03-2008 12:01 PM
Spring rate for RE 4.5 XD 4bangerYJ YJ Wrangler Technical Forum 4 04-12-2005 07:46 PM
Spring Rate Rufies97XJ TJ Wrangler Technical Forum 0 01-20-2004 11:55 AM
