What oil filters? - JeepForum.com
post #1 of 84 Old 10-01-2008, 10:06 AM Thread Starter
SDDAVE
What oil filters?
Im thinking about ordering an Amsoil oil filter with my next oil order. I use Amsoil Series 3000 HD Diesel Oil right now. Any one here using the Amsoil filters? If not what filters do you use? I have a 2004 Rubicon, and so far have been using the factory oil filter.
SDDAVE is offline
post #2 of 84 Old 10-01-2008, 10:17 AM
newracer
Napa gold, I forget the part # but there is one that is slightly larger than factory
newracer is offline
post #3 of 84 Old 10-01-2008, 10:27 AM
Terrain Twister
Why are you using oil formulated for Diesels? It doesn't have everything in it the gas motor needs just like oil for gas motors doesn't have everything in it a Diesel needs.
At that point where it's too much to list!
Terrain Twister is offline
post #4 of 84 Old 10-01-2008, 10:37 AM
Loose Screws
Loose Screws's Avatar
Originally Posted by Terrain Twister View Post
Why are you using oil formulated for Diesel's? It doesn't have everything in it the gas motor needs just like oil for gas motors doesn't have everything in it a Diesel needs.
I was thinking the same thing but for filters WIX makes a great filter.
2000 TJ, 4.0l, 5 speed NV3550, Interco Trxus 35x12.50, Skyjacker Long Arm 4" lift
Loose Screws is offline
post #5 of 84 Old 10-01-2008, 10:41 AM
rubiwannabe
napa 1550 gold..ford 5.0 filter..ive been using for yrs..no probs.
rubiwannabe is offline
post #6 of 84 Old 10-01-2008, 10:48 AM
Rowingfish87
wix and purelator (sp) make geat filters. the napa race filter or w/e its called is a relabeled wix filter. i use wix.
2002 Sahara 4.0L/NV3550/NP231/D30/D44
35x12.50x15 MTRs
RC 2.5" Lift & 1"BL
1998 Dodge Ram 2500 4x4 CTD
Rowingfish87 is offline
post #7 of 84 Old 10-01-2008, 10:50 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That is true, engine oils formulated for diesel and gasoline engines are very different and they should not be used in the other type of engine.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #8 of 84 Old 10-01-2008, 10:50 AM Thread Starter
SDDAVE
According to Amsoil you can use their diesel oils in gas engines. See diesel oils have to be of a higher quality than regular oil. This is due to the fact that diesel engines have to be built to much tighter tollerances than gas engines.Diesel engines opperate under much higher loads and / or stresses. So I figure if its good enough for my Cummins its good enough for my Jeep. The series 3000 is their best diesel oil.
SDDAVE is offline
post #9 of 84 Old 10-01-2008, 10:56 AM
snakehunter
I either buy the Mobile 1 filter or the Mopar filter at Wally World depending on what's in stock...
2000 Sahara RE 4.5, Alloy USA front Axles (D30) w/Aussie locker, Superior Super 35, 4.56 gears, OME Shocks, Centric Front Discs w/EBC Yellow pads, AtoZ Fab Rocker Guards,Goodyear MT/R 33x12.5x15 on 15x8 Rock Crawler 51's, other minor stuff...
/ | [____],
1---L-OlllllllO-
()_)()_)----)_) White Jeep Club Member #111
snakehunter is offline
post #10 of 84 Old 10-01-2008, 11:08 AM
Terrain Twister
Sorry SDDAVE, but if Amsoil told you that I'd have a hard time using any of their products. Diesels (and yes, my tow rig is one) require completely different formulations than gas. The formulations for diesels will gum up and vice versa. This is because the oils are designed to 'carry off' the contaminants of the fuel being used. Those additives react just the opposite when used with a motor that runs a different fuel. Gas oils are also designed to be operated and hold together better under higher RPM's where Diesels are just the opposite and hold together better under low RPM loads.
All that being said, I will reserve judgment as all the new vehicles these days are becoming more and more of multiple fuel vehicles. So maybe what they say is true but they would definitely have to prove it to me first and not with my vehicle!
post #11 of 84 Old 10-01-2008, 12:01 PM
newracer
That's the one I was thinking of.
newracer is offline
post #12 of 84 Old 10-01-2008, 12:07 PM
john NC
john NC's Avatar
wix or purolator pure one
john NC is offline
post #13 of 84 Old 10-01-2008, 12:14 PM
Terrain Twister
Back on track, I second the Purolator Pure One. If it's the one I'm thinking of, it has a better single pass filtering efficiency than most others do at multi pass.
post #14 of 84 Old 10-01-2008, 12:26 PM
Jerry Bransford
Administrator
My top three choices of good oil filters for the money include Wix, AC-Delco Duraguard, and Purolator PureOne. There are other good ones but those three are easy for me to remember when I'm buying them for my TJ. I have no trouble remembering to avoid Fram's poor quality (IMHO) oil filters.
Getting
post #15 of 84 Old 10-01-2008, 12:37 PM
Zombi
I just installed a Purolator Pure One Premium.
Only difference between the premium and the regular is that the premium has a gritty texture on the whole outside which makes things SOO much easier when it comes to taking it off.
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
Air filters bassin JK Wrangler Technical Forum 8 01-28-2010 05:57 AM
Best OEM Air filters? defleppardsg TJ Wrangler Technical Forum 7 01-28-2009 01:37 AM
K & N air filters tigers34 JK Wrangler Technical Forum 16 07-24-2008 06:59 AM
K&n air & oil filters... 2442george JK Wrangler Technical Forum 22 02-28-2008 11:41 AM
Do k & n filters stop as much dirt as paper filters ? magnum629 TJ Wrangler Technical Forum 7 12-17-2006 03:06 PM
