What is the normal oil pressure? - JeepForum.com
post #1 of 6 Old 06-14-2011, 05:34 PM Thread Starter
Badcompany
I was to curious to know what the normal oil pressure should be for the 4.0. My oil pressure at idle is at the line between o and 40. While driving my pressure is at 40 to 45. Is this normal or there a serious problem going on here? I changed my oil switch. I just wanted to know if this is normal or not. Thank you.
Badcompany is offline
post #2 of 6 Old 06-14-2011, 05:39 PM
chris142
Put a mechanical gauge on it and get back to us.
chris142 is offline
post #3 of 6 Old 06-14-2011, 05:39 PM
durango-bob
2006 WK
Zero can be a problem, but otherwise sounds about right.
durango-bob is offline
post #4 of 6 Old 06-14-2011, 05:52 PM
Robert J. yates
13psi at idle is factory spec. Your guage may not be correct or else the oil pressure sender is possibly fragged and needs to be replaced. If you truely had zero... you would get a check guages light.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #5 of 6 Old 06-14-2011, 05:52 PM
SolidBrass
10 @ 1000 RPM is normal. Nothing to worry about. (Zero is a problem) Jeeps have an 'honest' gauge that tells you what really is happening. Other vehicles don't and just tell you 'everything's fine' all the time to keep know-nothings from getting worried, in truth oil pressure changes with RPM's.
I like the baby version the best
Why Jeeps are Better.
SolidBrass is offline
post #6 of 6 Old 06-14-2011, 06:08 PM Thread Starter
Badcompany
Thanks for the replies. I will have to pick up a mechanical gauge to test the true pressure since the gauge in the jeep is digital. It's my first jeep, just use to those v8's.
Normal oil pressure? scottbr TJ Wrangler Technical Forum 9 09-13-2010 09:53 PM
What is normal fuel pressure? Davpmars YJ Wrangler Technical Forum 5 12-29-2009 01:49 PM
oil pressure normal?? claytonandson TJ Wrangler Technical Forum 11 07-30-2009 08:29 PM
What is normal oil pressure? Pontiac Freak YJ Wrangler Technical Forum 2 03-14-2006 09:39 AM
Normal Oil pressure? ctstevo YJ Wrangler Technical Forum 1 10-22-2004 05:57 PM
