What is "normal" engine idle speed for a 2.5? - JeepForum.com
post #1 of 14 Old 09-11-2007, 05:41 AM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
Need help with my 2.5 high idle
What is the "normal" engine idle speed for a 2.5? I just read about 100 threads and couldnt find an answer.
thx
*EDIT* this question has been answered- but rather than start a new thread, I just changed the thread name (i think) and added some more questions below
+GRAVES+ is offline
post #2 of 14 Old 09-11-2007, 07:12 AM
duglas25
duglas25's Avatar
I would like to know too.. mine seems like it idles low and rough, but the set screw is IMPOSSIBLE to get too and I am not sure if it is too low or normal
2007 Rubicon Unlimited
SRT8 6.1L Swap Auto
RE 4.5" Long Arm
37" Cooper STT MT 17" Rims
Currie G2 D60 Rear, ARB 5.13
Mopar bumpers rear DVD, LockPick, MyGig, Sirius,
Full Soft Doors
TMD Hood
2005 Inifinti G35 4 Door 6MT
Stillen Stage 3 Supercharger
duglas25 is offline
post #3 of 14 Old 09-11-2007, 07:17 AM
crawl1n
Mine idles smoothly around 750 RPM. Been that way since I bought it with 48k miles on it. It now has 143k miles on it.
97 TJ SE HP44 ARB, 9" Detroit, 5.13, 36x12.5 TSL's, RE 4.5" Superflex, JKS 1.25" BL, Goferit 1" MML
06 Jetta TDI for daily driving duties
crawl1n is offline
post #4 of 14 Old 09-11-2007, 08:48 AM
Roughneck
Roughneck's Avatar
Yeah, around 700-800 rpms is good for most any engine, and it should be smooth. It shouldn't have to go near 1000 to get smooth though.
2006 Rubicon Unlimited
Wranglers lead the way. I mean, Rangers lead the way!
Roughneck is offline
post #5 of 14 Old 09-11-2007, 10:15 AM
Nikos
x2..............
2000 tj 2.5l 4.56 dana 30 aussie locker /super35 ARB, 35s maxxis crawlers, RE3.5sf, RE monotubes, 1"BL, currie anti-rock, currie steering, or-fab cage,ARB bull bar, warn m8000
Nikos is offline
post #6 of 14 Old 09-11-2007, 10:48 AM
Curlee
US Army 19D
Curlee's Avatar
Mine stayed right around 650 to 700 from what I remember, and wasnt rough.
My LS2 Wrangler build
Wheelers for the wounded Great cause, check it out
A democracy is nothing more than mob rule, where fifty-one percent of the people may take away the rights of the other forty-nine.
- Thomas Jefferson
Curlee is offline
post #7 of 14 Old 09-11-2007, 11:06 AM
EvilM0nkey
EvilM0nkey's Avatar
Base idle speed
For future reference the idle speed is listed under the hood of most 1995 and newer vehicles on the emissions sticker.
EvilM0nkey is offline
post #8 of 14 Old 09-11-2007, 12:33 PM
danceswithglock
Yep, mine idles around 700-800 too.
,[____l,
_-o||||o-_
()_)ŻŻ )_
Low Output 4 Cylinder Jeep Club #108
Red Jeep Club Member #406
danceswithglock is offline
post #9 of 14 Old 09-11-2007, 12:35 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
i'd say about 700 for me.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #10 of 14 Old 09-11-2007, 04:03 PM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
Thanks for the 411. I thought for sure this would be in the FAQs on this site, but it isnt.
Mine been idling about 850-900 & it seems "just" a bit high. I was zipping thru the parking garage last night & I didnt even have my foot on the gas pedal
Would cleaning out the throttle body or (*suggestions here*) help bring it down?
+GRAVES+ is offline
post #11 of 14 Old 09-12-2007, 10:37 AM
Roughneck
Roughneck's Avatar
If there is a laquer buildup in or around the venturi's (if they're even still called that), then it needs cleaning. I don't think the idle speed is adjustable, so if it is fast I think a sensor is telling the computer to speed it up. Technology is great haha.
I washed the engine in a 1990 truck that I keep around, and I got a sensor wet. The engine "idled" at 3000 rpms for days until it dried out. Luckily it's a manual trans.
cheers, LT
post #12 of 14 Old 09-12-2007, 11:03 AM
HowIRoll
HowIRoll's Avatar
1000 when it first starts or when you are coasting to a stop in neutral and 750 at idle when sitting, it kind of bumps up and down about 25 rpms or so
Check out my build thread:
http://longhornfabshop.com/
HowIRoll is offline
post #13 of 14 Old 09-12-2007, 03:27 PM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
yeah mine is about 850-900... as I said it seemed "just a bit high". I'll spray out the throttle body & see what happens.
+GRAVES+ is offline
post #14 of 14 Old 09-19-2007, 03:22 PM Thread Starter
+GRAVES+
Corporate Whore
+GRAVES+'s Avatar
Ok I was looking at another thread about the 2.5 idle speed. Please correct me if I am mistaken. If the idle is high, the IAC might be bad and if the idle is erratic, its possibly the TPS. I also read I should check the codes to see if my O2 sensor is bad, as that also might effect the idle.
My idle is not erratic, but seems to be about 100+ rpm faster than i think it should. On a flat surface, I can zip around in second gear without even touching the gas pedal. I sprayed out the throttle body & it seemed to help a little.... but not much.
So to narrow it down, possibly a bad IAC or O2 sensor? Any other suggestions?
thanks
+GRAVES+ is offline
Engine "Lopes" at highway speed. ElvisV04290 YJ Wrangler Technical Forum 10 11-12-2009 02:42 PM
Driveshaft binding? or "normal" breakage GMC7000 TJ Wrangler Technical Forum 17 06-07-2009 10:55 PM
"Thunking" noise when turning right... normal? timdhawk YJ Wrangler Technical Forum 11 11-08-2007 09:39 AM
Is this "Normal" -> Rear D35 "Wet"? SuperWade2 TJ Wrangler Technical Forum 14 04-14-2007 11:37 AM
What's normal for oil "seepage/blowby/leak" etc? Achped TJ Wrangler Technical Forum 2 03-29-2006 07:03 PM
