What is my lift? - JeepForum.com
post #1 of 3 Old 06-03-2012, 12:37 PM Thread Starter
H2O5O
What is my lift?
I bought my Jeep a few months ago and I want to replace the shock absorbers. I do not know what the lift is and the previous owner does not know either. The current shock absorbers are rusted but they are or were white with yellow boots. The tires are Mud Dawg with about 50% tread left on them. The distance from the top of the front tire to the fender is 6 1/2 inches. The distance form the top of the rear tire to the fender is 7 inches. The distance from the stock step to the ground is 21 inches. The springs are black. Thank you in advance for any knowledge on the subject.
H2O5O is offline
post #2 of 3 Old 06-03-2012, 12:40 PM
dreed
dreed is offline
post #3 of 3 Old 06-03-2012, 05:59 PM Thread Starter
H2O5O
They are 12 inches in the rear and 16 inches in the front. According to that chart you attached, I have a 4 inch lift. Thank you for your help.
H2O5O is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
time to lift my 91 yj what is a good cheap lift and what 1" body lift drenter17 YJ Wrangler Technical Forum 34 06-23-2012 02:45 PM
Body lift questions: Most complete kit, 1/2 or 1" lift, alum vs poly Fargo TJ Wrangler Technical Forum 25 11-07-2011 07:41 AM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 06:04 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 08:13 PM
