what might be causing this ticking? - JeepForum.com
post #1 of 4 Old 04-11-2013, 07:26 PM Thread Starter
griffin84184
https://www.youtube.com/watch?v=icSD...e_gdata_player
2000 2.5l manual TJ se. This has been happening for the last week or so. Some times it goes away when I keep a constant speed, but when I stop, it comes back. It gets faster with rpm's too. The belt looks to be tight and in good shape, no cracks. Also, temperature does not play a factor, it happens whether its 60* or 10*.
Any ideas what could be causing this?
griffin84184 is offline
post #2 of 4 Old 04-12-2013, 07:10 AM Thread Starter
griffin84184
Anybody have any ideas?
post #3 of 4 Old 04-12-2013, 07:24 AM
George Dickel
George Dickel's Avatar
a loose spark plug can tick, so can an injector not seated all the way but it would miss. Check your plugs. An exhaust leak ticks as well. Good luck
Sorry, should have watched video first. I'd say it's a bad idler pully. They're cheap.
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #4 of 4 Old 04-12-2013, 09:04 AM
goofus
Check the exhaust manifold studs. Common for them to snap off and make a very light gap (and tick). Also check vacuum lines- can't remember if there's one on the intake manifold on that engine.
2013 2500HD
2005 Unlimited
2003 Rubicon
2000 SE
1997 XJ
85 FJ-60
goofus is offline
