Quantcast What makes your TJ squeak? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What makes your TJ squeak?
Old 12-07-2007, 01:49 PM   #1
djt283
This is just a thought but after weeks of trying I've finally eliminated MOST of the squeaking noises my TJ makes. The noises weren't that annoying, but once I started looking for the cause they drove me crazy. I'm not talking about anything mechanically wrong. Nothing to do with brakes or axles. All I'm talking about is those little noises when a bushing or something needs to be lubricated. Ever happen to you?
I'm sure every TJ owner has had one noise or another that was hard/impossible to locate. Since you can't exactly tie a friend to the frame and let him listen while you drive around, just thought that some input from other people might not be a bad idea. The squeaks that drove me crazy just might be the same that are bothering you now, and vice versa. Just thought it might be a good idea to get a "master list" of sorts to help everyone know what spots to spray down every now and then. (And please, nothing about brake pads)
Anyway, my main culprets were:
1) Contral Arm joints
2) Bracket that connects Transmission to the skid plate
3) Engine mount bushings
djt283 is offline   Reply With Quote
Old 12-07-2007, 01:54 PM   #2
BlackBellamy
Fat chicks!
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline   Reply With Quote
Old 12-07-2007, 01:56 PM   #3
ieatchickens
The grommet were the steering wheel goes through the firewall can give a nice squeak when it's gets real cold and you crank the steering wheel. Dab a little white grease and she is good as new for another couple of years.
98' SE, Chili Pepper Red, grizzly wheels, 126AA/103AA to 129AA/105AA coil swap, 3/4" spacer, 31 Yoko Geolander AT, soft top, rear view mirror turned upside down, door straps twisted, rubicon wipers, optional factory rear sway bar, doors & top on.
Low Output 4 Cylinder Jeep Club Member #1
06' Grand Cherokee Limited, 4.7 liter V8
99' Grand Cherokee Limited, 4.7 liter V8
ieatchickens is offline   Reply With Quote
Old 12-07-2007, 01:57 PM   #4
BYuen
Wahoowa
BYuen's Avatar
1) Hi-lift in the back
2) Control arms
3) Sports cage
4) Steering components
5) Loose spare
There are some more, but I haven't quite isolated them yet
White 01 TJ Sport 4.0 NV3550
BYuen is offline   Reply With Quote
Old 12-07-2007, 02:02 PM   #5
Spacecom
Junior Member
Spacecom's Avatar
Originally Posted by ieatchickens
The grommet were the steering wheel goes through the firewall can give a nice squeak when it's gets real cold and you crank the steering wheel. Dab a little white grease and she is good as new for another couploe of years.
So, that is where that dang squeak is coming from!
Great Idea for a thread...
Spacecom is offline   Reply With Quote
Old 12-07-2007, 02:12 PM   #6
ieatchickens
Discovered that one a similar thread a couple of years ago. Every time I turned the steering wheel in the winter I thought there was a goose stuck in the dash board. Didn't care much for the honk sounding sqeak.
Old 12-07-2007, 03:10 PM   #7
wdw
I used hockey pucks to tighten up my spare.
'97 TJ Sport, 4.0 5 speed, Jeeperman Rock Skidz, JKS Quicker Disconnects, 2 inch BDS lift kit, Branik Motorsports Aluminum Control Arms, 32X11.5 BFG ATS, 15x10 Eagle Alloy Wheels, Detroit True Tracs with 4.56 Gears .. both axles, Best Top High Rock Rear Bumper
I also own a lifited Golf Cart: www.buggiesgonewild.com
wdw is offline   Reply With Quote
Old 12-07-2007, 04:48 PM   #8
ptowntj
Control Arms after wheeling...everytime.
04TJ 3.5 RE Extreme Duty Long Arm, ARB F&R, 4:88's, Cromo shafts, 35 MTRS, Rokmen Armor.
TJ's gone. See you on the trail in my Toyota :).
ptowntj is offline   Reply With Quote
Old 12-07-2007, 04:52 PM   #9
CHRRRIS
Don't even know, but I gots lots of them!
For the control arms, do you guys just re-grease them and the squeak goes away? I've got BDS front lowers, the rest are stock.
It's easier to go down a hill than up it but the view is much better at the top.
-Henry Ward Beecher
Current - '98 Black Z28 with some goodies
Previous - '97 Gun Metal Blue TJ
Northern Illinois Extreme Jeep Club
www.ExtremeJeepClub.com
CHRRRIS is offline   Reply With Quote
Old 12-07-2007, 05:01 PM   #10
Spacecom
Junior Member
Spacecom's Avatar
That is exactly the sound... I couldn't think of a way to describe it, but a goose it is... Going out right now to ring it's neck...
I've got Teraflex lower flex arms all the way around and they have grease fittings that I lube every time I do an oil change... But on stock, I'd probably just give them a squirt of WD-40...
Anyone do something that would last longer?
Old 12-07-2007, 05:05 PM   #11
RLD831
Maybe it's the wrong place to ask, but i think my rear trackbar is the cause of my squeaking noise, would not having a cv bracket for it cause this? I have a RE adj trackbar, a Ford 8.8, Tera ESS, and TW drive shaft.
Black 2001 Wrangler SE, stats in profile
RLD831 is offline   Reply With Quote
Old 12-07-2007, 05:11 PM   #12
Rubi22
x2 on the grommet for the steering column.
also, after a few on/offs my DS door started squeaking. luckily a little WD-40 and pipe
Rubi22 is offline   Reply With Quote
Old 12-07-2007, 08:24 PM   #13
truckin88
What did you do for this, I think this is the one I have now.
2006 Wrangler X, 6 speed manual 4.0 I6, BFG T/A's 31x10.50x15 on Promcomp )97 Soft 8 Steelies, stock sunrider soft top, KC Replacement fogs, westin step bars (yeah I know).
RED JEEP CLUB MEMBER #442
truckin88 is offline   Reply With Quote
Old 12-07-2007, 08:29 PM   #14
skyjacked94xj
Damn passenger seat wiggling and squeeking
DAILY DRIVER
1996 Cherokee Classic
4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit
CLASSIC TOY
1968 Chevy C-10 short bed
Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list
Project
1988 Pontiac Trans Am GTA
350 TPI | WS6 | 48k original miles | Flame Red Metallic
SOLD: 94 cherokee | Lifted | Locked
SOLD: 97 TJ | 33's | 4.56's | :(
Searching for an Ls-1 Rx-7 project....
skyjacked94xj is offline   Reply With Quote
Old 12-07-2007, 08:34 PM   #15
benny36
Please tell me how to get to that grommet, that noise drives me crazy.
I also just started to get a new squeak, I think its the serpentine belt
99 TJ Low Output Model
benny36 is offline   Reply With Quote
Glock Forum
