What makes it a Rubicon? - Page 3 - JeepForum.com
post #31 of 49 Old 06-18-2010, 03:46 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by ja4man View Post
I inquired thru (email) Jeep technical owner support from the Jeep site. Someone got back to me a day later stating the springs in my '04 Rubi (4.0 / auto tranny) are the same as a equivalent equipped '04 Sport and X model. My build sheet doesn't list spring p/n or rating.
Your build sheet should list the spring codes.
Its usually right after the code that reads "YGFA - 8 Additional Gallons of Gas"
You'll see spring codes like this:
ZAYP - Spring - Left Rear
ZBHP - Spring - Left Front
ZNYP - Spring - Right Rear
ZPHP - Spring - Right Front
This would indicate the 130 springs up front and the 5AA or 105 springs in the rear.
"130" and "105" are the last 3 digits of the part numbers.
You can also find the part # on the spring if the tag is still present.
Wheelin98TJ is offline
post #32 of 49 Old 06-18-2010, 04:18 PM
ja4man
I bought my '04 Rubi in Jan '10. 24,200 miles on the odo. I sent a request to DC for a copy of the build sheet. Here's what I received....
__________________________________________________ ___________
Date: February 4, 2010 12:19:57 PM CST
Thank you for contacting the Chrysler Customer Assistance Center
regarding your Jeep Wrangler Rubicon.
We are pleased to provide vehicle build information per your request and
we apologize for the delay. According to our records, your vehicle was
equipped from the factory with the following:
*P5 Cloth High-Back Bucket Seats
-DV Dark Slate Gray
ADCS Convenience Group
APAS Monotone Paint
AWLS Off Road Group
AWS Smoker's Group
A81P 4.0L Eng (ERH)/4Spd A/T 42RLE (DG6)
BAUS 117 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BRWS 4-Wheel Disc Brakes
CADS High Back Bucket Seats
CAGP Easy Access Passenger Seat
CDBS Reclining Front Seats
CFMS Rear Folding Seat
CGWS Next Generation Front Air Bags**
CKES Front Seat Area Carpet
CKFP Rear Seat/Wheelhouse/Cargo Carpet
CKTS Cargo Tie Down Loops
CLC Front Floor Mats
CLMS Sport Bar w/Full Padding
CUFP Full Length Floor Console
CUKP Removable Ash Tray
DGBS All 4-Speed Automatic Transmissions
DG6 4-Spd. Automatic 42RLE Transmission
DHAP Lock-Up Torque Converter
DHWS 4:1 Rock-Trac HD Part Time 4WD Sys
DJCS 195MM Front Axle
DMFS 4.10 Axle Ratio
DRKS Dana 44/226MM Rear Axle
DSES Tru-Lok Front & Rear Axles
ERH 4.0L I6 Power Tech Engine
GBBS Tinted Windshield Glass
GCBP Front Door Tinted Glass
GCF Full Metal Doors w/Roll-up Windows
GNAS Rear View Day/Night Mirror
GTVS Swing-Away Mirrors
GXX Sentry Key Theft Deterrent System
HAA Air Conditioning
I48S Route 48 - UP, Mira Loma, CA
JAYS Instrument Cluster w/Tach
JCDS 100 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAP Cigar Lighter
JJFS Single Low Note Horn
JJJS 12V Auxiliary Power Outlet
JKAS Locking Glove Box
JKC Add-A-Trunk Lockable Storage
KCRS
KWRS STRIPE/BADGE/MOLDING/COLOR
K5XS STRIPE/BADGE/MOLDING/COLOR
LBBP Courtesy Lamps
LDAP Underhood Lamp
LMAS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MB5S Black Rear Bumper
MCHS Bumper Extensions
MEFS Black Diamond Plate Sill Guards
MFPS Chrome Headlamp Bezels
MFRS Black Front Frame Overlay
MFTS Body Color Grille
MT2S Trail Rated Badge
NAS 50 State Emissions
NBGP Federal Tier 2, Bin 9A Emissions
NBKS EVAP Control System
NF1S 19 Gallon Fuel Tank
PSBA Bright Silver Metallic Clear Coat
QSBS Bright Silver Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RBKS AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCAS Steering Wheel
SDUS Heavy Duty Suspension w/Gas Shocks
SHAS Front Stabilizer Bar
SHCS Front and Rear Stabilizer Bars
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TY3S LT245/75R16E BSW 31" MT/R Tires
TZAP Goodyear Brand Tires
VJXA Black Easy Folding Soft Top
WDYS 16X8.0 "MOAB" Silver Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
XCYS Delete Remote Start System
XEES Fuel Tank Skid Plate Shield
XEFS Transfer Case Skid Plate Shield
XEWS 2 Front & 1 Rear Tow Hooks
XJFS Tethered Fuel Filler Cap
2004 'Quick Silver' Rubicon
ja4man is offline
post #33 of 49 Old 06-18-2010, 04:31 PM
Coils Rule
oops did not mean to post here sorry
Rockcrawlin' is lame.
Coils Rule is offline
post #34 of 49 Old 06-18-2010, 04:40 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by Zen View Post
Nope, inside they are the same...
Most Rubicons were built with more options than the x's were, however.
When I bought mine, I couldn't find one without a 6 disc changer and dual tops.
I would hope so! The X is just an SE with a 4.0. The Rubi is a top model (like a Sport for example) with most everything already included, and with some substantial upgrades not available on a non-Rubi (as mentioned in this thread.)
In the early years of the X, not much was available even as options. In the last years, dealers ordered lots of X's so optioned out they cost nearly as much as Rubis. Poor suckers who bought them knew no better...
Okay, I should search for the answer to this, but since we're kind of on the topic already...what's the deal with the passenger seat tumble feature? Is that an option, or standard? I know it sounds kind of stupid, but I'd like to get rid of it. Could I pick up a non-tumble bracket, perhaps?
WHY on earth for? Just don't tumble it. <slapping forehead> And no, they all tumble, there's no non-tumble base.
I was told by both Rough Country and Jeep (DC) the springs in all TJ's (ie; 2003 - 2006) are the EXACT SAME SPRING. Check the part numbers for a 2004 Rubi and 2004 X. Their the same. Where the difference is is in the axles. The D44's front & rear on a Rubi sit 1/2" higher than axles on a Sport or X model.
For example, if you were to buy a 2.5" lift from Rough Country, on the Sport and X models, you will achieve 2.5" of lift, where as on the Rubi, you only get 2.0" lift due to the axles - not the springs.
You are incorrect about the difference being the axles. The D44 rear in the Rubi is the same housing as the D44 in any other TJ (I.e. the same except for the locker and gear ratio.)
And the statement "the springs in all TJ's (ie; 2003 - 2006) are the EXACT SAME SPRING" is incorrect, and well known to be incorrect.
I inquired thru (email) Jeep technical owner support from the Jeep site. Someone got back to me a day later stating the springs in my '04 Rubi (4.0 / auto tranny) are the same as a equivalent equipped '04 Sport and X model. .
That is correct. But it is NOT what you wrote above. IF an X and a Rubi were equivalent equipped, they'd have the same spring rate. This is not the same as saying all TJs have the exact same spring.
BlueFlame is offline
post #35 of 49 Old 06-18-2010, 04:51 PM
MJBinNM
Originally Posted by AZJeepNewbie View Post
For the sake of completeness, I'll also bring up the fact the Rubicon has 1/2" spacers welded to the top of the front bump stop pads to decrease the wheel travel a bit to clear the 31's when they're stuffed.
Yeah...and it was a PITA to drill and tap them for my bumpstop extensions.
MJBinNM is offline
post #36 of 49 Old 06-18-2010, 05:03 PM
MJBinNM
SCAS Steering Wheel
Rack and Pinion Steering????
MJBinNM is offline
post #37 of 49 Old 06-18-2010, 06:38 PM
ja4man
FWIW - I sent a PM to Rough Country here on JeepForum asking him to explain why he told me what he did. We'll see just how stand-up of a guy / company he / they are.......
ja4man is offline
post #38 of 49 Old 06-18-2010, 06:48 PM
Wheelin98TJ
JEEP FREAK
I don't think its that big of a deal and its not worth judging a company or a person over.
It was a simple misunderstanding and now hopefully everything is clear.
post #39 of 49 Old 06-18-2010, 11:25 PM
ja4man
I disagree. I quoted what was told to me by RC. Some have implied I was mislead. Again, regardless of what some believe was misquoting or misunderstanding on my part, that's not the case. These people are assuming.
Bottom line, I was told the springs are all the same and that it is the height of the D44's that make a difference in net gains when doing a suspension lift. End of story.
ja4man is offline
post #40 of 49 Old 06-18-2010, 11:31 PM
AZJeepNewbie
Absolutely. We make decisions based on what vendors tell us, and I don't blame you for wanting clarification on what was said.
2005 Rubicon, Currie JJ SA lift with AEV 3" springs.
"Confidence is that feeling you have before you fully understand the situation."
AZJeepNewbie is offline
post #41 of 49 Old 06-18-2010, 11:34 PM
Imped
Imped's Avatar
Originally Posted by kennemore_m View Post
I have tried to search but can't find the specifics I am looking for
Your Google-fu is weak.
Jeep Wrangler - Wikipedia, the free encyclopedia
Just thought I'd throw that in there.
OlllllllO
IndyORV
Imped is offline
post #42 of 49 Old 06-18-2010, 11:36 PM
ja4man
Apples and oranges. Jeep said equivalent equipped.
Granted I may have misunderstood Jeep's explanation compared to RC's, but like I replied above, I was told by RC the springs are all the same on TJ Rubi's, Sports and X models. That the part numbers were the same. And that the diff height made the difference. Speaking of apples and oranges, some here claim I am inncorrect but fail to realized I am not incorrect -- It now appears I was misled and or lied to.
ja4man is offline
post #43 of 49 Old 06-18-2010, 11:41 PM
Imped
Imped's Avatar
I'm assuming you meant to say axle tube diameter, since the "diff height" has absolutely nothing to do with the distance between the upper and lower spring mounts and, consequently, lift height, given the same spring. And if you would have simply done a bit more research after being told that Rubis had larger tubes, you'd discover that they are all the same. Research is invaluable.
OlllllllO
IndyORV
Imped is offline
post #44 of 49 Old 06-19-2010, 12:12 AM
ja4man
That is what I assumed as well. I had two phone conversations with RC after meeting three people who had installed the 2.5" Progressive Lift on (2) '05 Rubi's and a '04 like mine. They all informed me when new, they were only able to get 2" of lift. RC first told me these people weren't measuring correctly. Then they told me about the diff height and shock theory. In turn, these same people were adamant they knew the correct results. Matter of fact, two have told me within a year they're now sitting at 1 1/2" of lift and that both had installed flat flares (both are running 33's). One even claims the 2.2 Progressive shocks are terrible in winter weather and was forced to change to another brand shock.
Regardless, I should have returned the lift when I realized I wasn't going to achieve the lift height they claim. Mind you no where did they disclaim different results on Rubicons. I guess that's because they believe the theory they explained to me. Whatever that actually may be?
Lesson learned.
ja4man is offline
post #45 of 49 Old 06-19-2010, 07:13 AM
BadJeep2006
Lift companies don't provide different springs for different models of TJs. It doesn't matter to them whether it's a Rubicon, X, Sahara, or Sport model. The provide a coil spring with "X" amount of advertised lift. "X" is based on a stock vehicle. It does not take into account all the little upgrades we all do that add weight. More weight up top is going to make the springs compress more.
The coil springs you buy are a very important component of any lift. Manufactures vary greatly in quality and ride. Most will tell you OME, or AEV makes the best coil springs. The bottom line to me is you spent $299 on a kit that included shocks, transfer case spacers and shocks. That would have been my first clue I was not getting a failsafe kit that was going to do exactly what I wanted. Good PAIR of coils cost almost 2 hundred bucks alone. Good shocks run another hundred each. You got exactly what you paid for, CHEAP STUFF. Does it work, yes, but it's not going to be perfect.
BadJeep Build: D60 front W/ARB and 5.38 gears, Sterling 10.5 rear W/ARB and 5.38, 3 Link front, 4 link rear, 14" ORI Struts, Atlas II transfer case, A to Z Fab full cage, Genright fenders, A to Z Fab front bumper, and Warn M8000 winch. Thinking stroker in the future.
BadJeep2006 is offline
rubicon , identification
Who makes the best CV? 60mxer YJ Wrangler Technical Forum 1 05-13-2008 01:21 PM
What makes a rubicon a rubicon? Laxstar46 TJ Wrangler Technical Forum 19 02-05-2008 12:51 PM
06 Rubicon, blower fan makes a high pitched squeal airems TJ Wrangler Technical Forum 1 05-14-2007 08:45 PM
Who Makes a Rubicon D44 Truss? paultyler TJ Wrangler Technical Forum 2 09-28-2006 09:58 PM
What makes rubicon desireable? Smelt_1 TJ Wrangler Technical Forum 45 04-21-2006 12:28 PM
