What makes it a Rubicon? - Page 2 - JeepForum.com
post #16 of 49 Old 06-18-2010, 11:20 AM
bige2533
Aren't the springs different depending on the options on the X?
bige2533 is offline
post #17 of 49 Old 06-18-2010, 11:25 AM
AZJeepNewbie
For the sake of completeness, I'll also bring up the fact the Rubicon has 1/2" spacers welded to the top of the front bump stop pads to decrease the wheel travel a bit to clear the 31's when they're stuffed.
2005 Rubicon, Currie JJ SA lift with AEV 3" springs.
"Confidence is that feeling you have before you fully understand the situation."
AZJeepNewbie is offline
post #18 of 49 Old 06-18-2010, 11:28 AM
BriansCJ
1994 XJ Cherokee
Springs have different load ratings. Rubicons have the second highest(104,105) next to the LJ(106,105).
A rubicon will sit higher because it has stiffer springs and bigger tires, no lift.
Same principle as if you took new dual top LJ springs and put them on a 97 4cyl with a soft top and 150k miles. The 97 would sit higher.
Rubis also have a different rear driveshaft(flange type) and no ABS. The front driveshaft is also made of bigger u-joints and centering ball i believe.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #19 of 49 Old 06-18-2010, 02:08 PM
ja4man
I was told by both Rough Country and Jeep (DC) the springs in all TJ's (ie; 2003 - 2006) are the EXACT SAME SPRING. Check the part numbers for a 2004 Rubi and 2004 X. Their the same. Where the difference is is in the axles. The D44's front & rear on a Rubi sit 1/2" higher than axles on a Sport or X model.
For example, if you were to buy a 2.5" lift from Rough Country, on the Sport and X models, you will achieve 2.5" of lift, where as on the Rubi, you only get 2.0" lift due to the axles - not the springs.
Oh and as for the OP's question -- You can't appreciate the "specs", until you've wheeled a Rubi off road!
2004 'Quick Silver' Rubicon
ja4man is offline
post #20 of 49 Old 06-18-2010, 02:16 PM
Imped
Imped's Avatar
That's completely incorrect. The axle tube diameter and wall thickness are the exact same on D30, D35, and D44. The spring rates are indeed different.
The only reason a Rubi will yield less suspension lift than a comparable X or Sport is only due to the fact that the stiffer coils have sagged less over time than the softer springs.
OlllllllO
IndyORV
Imped is offline
post #21 of 49 Old 06-18-2010, 02:20 PM
ja4man
So then RC and Jeep both lied to me?
ja4man is offline
post #22 of 49 Old 06-18-2010, 02:36 PM
AZJeepNewbie
Technically he's correct that the axles sit higher on the Rubicon. That's because they're attached to larger diameter wheels.
post #23 of 49 Old 06-18-2010, 02:40 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yep.
Below is from the parts manuals listing all the different springs.
2006:
1998:
Wheelin98TJ is offline
post #24 of 49 Old 06-18-2010, 02:45 PM
ja4man
Interesting. I could see a vendor lying or at least being incorrect, but Jeep (DC) telling me the same thing? Interesting.
ja4man is offline
post #25 of 49 Old 06-18-2010, 02:48 PM
2005X
who at DC, some random call operator or an actual jeep engineer?
2005X is offline
post #26 of 49 Old 06-18-2010, 02:55 PM
Wheelin98TJ
JEEP FREAK
Maybe it was a misunderstanding.
It is possible for both an X model and a Rubicon to have the same part # springs.
You won't find an unaltered 4 banger model with the same springs as a Rubi model, but the 6 cylinder TJs used all sorts of spring combinations.
post #27 of 49 Old 06-18-2010, 03:05 PM
ja4man
I inquired thru (email) Jeep technical owner support from the Jeep site. Someone got back to me a day later stating the springs in my '04 Rubi (4.0 / auto tranny) are the same as a equivalent equipped '04 Sport and X model. My build sheet doesn't list spring p/n or rating.
ja4man is offline
post #28 of 49 Old 06-18-2010, 03:11 PM
2005X
the only way this would be considered truw is do to the fact the rubi comes with slightly larger tires which would slighlty lift the axles higher. technically other than going with HP axles the only way to lift them is by bigger tire size.
2005X is offline
post #29 of 49 Old 06-18-2010, 03:14 PM
solarpower
This.
Hard top, AC, full doors and what they had available usually determines what springs were to go on what vehicles.
But since the actual sizes both in length and diam. are the same amongst all those part numbers it would not be crazy for the factory to use what was on hand...with the exception of the 4 cylinder type.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #30 of 49 Old 06-18-2010, 03:16 PM
ja4man
Isn't RC a vendor here?
Fwiw, my Rubi has full doors, soft top only, AC and auto tranny -- yet neither Jeep nor RC knew this when I questioned the lift (@ RC) and what they told me thru my inquiry at Jeep.
ja4man is offline
rubicon , identification
Who makes the best CV? 60mxer YJ Wrangler Technical Forum 1 05-13-2008 01:21 PM
What makes a rubicon a rubicon? Laxstar46 TJ Wrangler Technical Forum 19 02-05-2008 12:51 PM
06 Rubicon, blower fan makes a high pitched squeal airems TJ Wrangler Technical Forum 1 05-14-2007 08:45 PM
Who Makes a Rubicon D44 Truss? paultyler TJ Wrangler Technical Forum 2 09-28-2006 09:58 PM
What makes rubicon desireable? Smelt_1 TJ Wrangler Technical Forum 45 04-21-2006 12:28 PM
