What makes it a Rubicon? - JeepForum.com
post #1 of 49 Old 06-18-2010, 06:56 AM Thread Starter
kennemore_m
I have tried to search but can't find the specifics I am looking for... Can anyone advise exactly what makes a Wrangler a Rubicon? I am new to the TJ thing having just come over from a YJ and would like to know exactly what is different from my 2006 X model and a Rubicon (transmission, engine, transfer case, axles, brakes, suspension, etc.). What are the real differences?
chatttownjeep
kennemore_m is offline
post #2 of 49 Old 06-18-2010, 07:05 AM
Sundowner
http://www.jeepforum.com/forum/f9/st...ations-452871/
It's a sticky for a reason.
Sundowner is offline
post #3 of 49 Old 06-18-2010, 07:06 AM
firefly21
Highlights:
T case most notably...geared lower
front Dana 44
Rear & Front Locker
31 Mtr and 16 inch Moab wheels
Diamond Plated rocker guard
Decal
Rubicon - 2003-2006
* 4.0L I-6 engine
* Tru-Lok selectable pneumatic lockers, activate in 4-lo and under 10mph, engaged until out of 4-lo or deselected
* Limited slip rear when unlocked
* NV241 Rock-Trac 4:1 transfer case -- fixed yoke
* Heavy-duty driveshafts with 1330 u-joints
* Dana 44 front and rear axles
* 4.11 gears
* Goodyear Wrangler MT/R LT245/75R16 (30.5"x9.6") Tires
* 16x8, five-spoke aluminum wheels
* Diamond plate rocker guards
* Rubicon Lettering on Hood
* Flares are 1" wider than standard TJ flares
* 4-wheel Disc Brakes
firefly21 is offline
post #4 of 49 Old 06-18-2010, 07:09 AM
RubiconRazorbac
RubiconRazorbac's Avatar
Originally Posted by firefly21 View Post
Highlights:
front Dana 44
Rear & Front Locker
Decal
X2. Plus disc brakes on the rear D44.
Look for a #6 in the 6th digit of the VIN.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #5 of 49 Old 06-18-2010, 07:41 AM Thread Starter
kennemore_m
Thanks guys. That's the kind of info I was looking for. So do I understand correctly that the engine and transmission are the same on a Rubicon and my 2006 X model (4.0 L with a 6 speed manual)? A guy driving a Rubicon told me last night that the Rubicon comes with a heavy duty transmission. The only difference I knew of was the transfer case.
chatttownjeep
post #6 of 49 Old 06-18-2010, 07:42 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
No special transmissions for the Rubi models.
Wheelin98TJ is offline
post #7 of 49 Old 06-18-2010, 07:52 AM
Sundowner
The 5- and 6-speeds are both classified as "medium duty" light truck transmissions, if I recall correctly. In a Jeep, that's pretty stout. I want to say the NV3550 is rated (conservatively) at 300 lb/ft capacity...but don't quote me on that. I'm not sure what the rating is on the 6-speed, but I think it would be comparable.
Also, are there not some interior options? Seat movement/height is what comes to mind.
post #8 of 49 Old 06-18-2010, 08:10 AM
Zen
Nope, inside they are the same...
Most Rubicons were built with more options than the x's were, however.
When I bought mine, I couldn't find one without a 6 disc changer and dual tops.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #9 of 49 Old 06-18-2010, 08:16 AM
rob78
There are some pretty important differences, but the engine and tranny aren't a part of them.
rob78 is offline
post #10 of 49 Old 06-18-2010, 08:25 AM
Sundowner
Okay, I should search for the answer to this, but since we're kind of on the topic already...what's the deal with the passenger seat tumble feature? Is that an option, or standard? I know it sounds kind of stupid, but I'd like to get rid of it. Could I pick up a non-tumble bracket, perhaps?
post #11 of 49 Old 06-18-2010, 08:30 AM
TNeustadt
Also 4.10 gears in the axles...
TNeustadt is offline
post #12 of 49 Old 06-18-2010, 10:02 AM
2004sahara
chrome jeep logo in middle of steering wheel.
2004 sahara, 2 inch BDS spring lift, BDS discos, 31bfg at, on ravines.
2004sahara is offline
post #13 of 49 Old 06-18-2010, 10:15 AM
solarpower
That was on all TJ's built after march 2004...Rubicon or not. Before then even the Rubicons had the logo in black...
More bling than I like actually.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #14 of 49 Old 06-18-2010, 10:18 AM
Zen
Are you talking about the front passenger seat? If so, can't you just disconnect the cable that actuates the tumble? Free mod that can be reversed.
-Stick, splash one!
Zen is offline
post #15 of 49 Old 06-18-2010, 10:32 AM
danielbuck
1946 CJ2
since the transfer case has a fixed yoke, does that mean the driveshaft(s) are different too?
danielbuck is offline
rubicon , identification
Who makes the best CV? 60mxer YJ Wrangler Technical Forum 1 05-13-2008 01:21 PM
What makes a rubicon a rubicon? Laxstar46 TJ Wrangler Technical Forum 19 02-05-2008 12:51 PM
06 Rubicon, blower fan makes a high pitched squeal airems TJ Wrangler Technical Forum 1 05-14-2007 08:45 PM
Who Makes a Rubicon D44 Truss? paultyler TJ Wrangler Technical Forum 2 09-28-2006 09:58 PM
What makes rubicon desireable? Smelt_1 TJ Wrangler Technical Forum 45 04-21-2006 12:28 PM
