What lift is required for HP30/Ford 8.8 swap? - JeepForum.com
post #1 of 9 Old 08-13-2010, 06:47 PM Thread Starter
2GPS4ME
So far the only owners who have swapped already have a 4" lift or more. I do not intend on going more than 2" suspension/1.25" body, and that is long in the future. (Currently OEM height, possibly a small spacer lift in the near future)
My primary concern is the front driveshaft clearance on the HP30 and fuel tank clearance on the 8.8.
Narrow Road Jeep Garage
Owner, Operator
2GPS4ME is offline
post #2 of 9 Old 08-15-2010, 09:06 AM
gixxerphil
bump
Originally Posted by elephantrider View Post
can you get a good pic of your muff set up ?
gixxerphil is offline
post #3 of 9 Old 08-15-2010, 09:51 AM
pfifer
For the front HP 30 you should be good with clearance for the drive shaft as stock XJs have no problem fitting the HP 30. As for the rear 8.8 someone else will have to chime in.....
pfifer is offline
post #4 of 9 Old 08-15-2010, 10:15 AM
Mainejeepin
HP 30 and 8.8 here with 2.5 suspension lift and 1.25 body lift. Only issue I've come across is related to the Truss on the 8.8 and not at all with the axle. I clear the Gas tank with plenty of space and the front drive shaft has had 0 issues in the 3ish months I've had it.
Mainejeepin is offline
post #5 of 9 Old 08-15-2010, 10:18 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
I know people with no lift and they don't have problems.
Bob Lee Swagger
TheBoogieman is offline
post #6 of 9 Old 08-15-2010, 11:33 AM
marcus01tj
u will have plenty of clearance on the 8.8 and fuel tank as long as u dont move the axle back
marcus01tj is offline
post #7 of 9 Old 08-15-2010, 12:15 PM Thread Starter
2GPS4ME
Bob Lee Swagger
You know it!
Originally Posted by marcus01tj View Post
...as long as u done move the axle back
Well, I 'done haven't moved'd' the axle back yet, so it appears I will be proceeding toward the 2 axle swap. Now, that $$$ problem....
Owner, Operator
2GPS4ME is offline
post #8 of 9 Old 08-15-2010, 07:12 PM
marcus01tj
fixed it for u sorry for posting in your thread :flipoff2:
post #9 of 9 Old 08-15-2010, 11:29 PM Thread Starter
2GPS4ME
Wow, someone needs some thicker skin.
Owner, Operator
2GPS4ME is offline
1.5-2" lift with a Ford 8.8 swap? smartshot TJ Wrangler Technical Forum 7 08-05-2010 07:33 PM
hp30 swap questions globalnomad TJ Wrangler Technical Forum 9 02-14-2010 10:30 PM
Is suspension lift required to swap in a HP Dana 30? TJ_ITmgr TJ Wrangler Technical Forum 3 09-11-2009 01:18 PM
HP30 swap finished Polaris TJ Wrangler Technical Forum 3 03-15-2007 08:19 PM
ford 8.8 swap & Lift questions Stormtrooper TJ Wrangler Technical Forum 9 06-03-2004 08:43 AM
