Quantcast What " lift for 35s and tube fenders - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What " lift for 35s and tube fenders
Old 01-26-2010, 12:48 PM   #1
MikalCarbine
I just got some 31x10.5r15 tires and I really want to lift to 2.5" so I have some nice flex for the time being but I also don't want to waste money for when I go to 35s with tube fenders if I need to get a higher lift.
What would be a proper lift for 35s with tube fenders? Would 2.5" provide enough useful flex or would I be looking at 3.5-4.5" instead?
MikalCarbine is offline   Reply With Quote
Old 01-26-2010, 12:50 PM   #2
YJteen
2.5 will be plenty with tube fenders. Just spend the $$ to get a quality lift. The OME 2.5 lift is supposedly very good quality and great ride.
95 Rio Grande YJ. Power generously provided by 4 angry squirrels and a 20 gallon squirrel feeder. Sitting on 31x10.5 ATs with AR wheels
Yes I'm 20, Yes I like Jeeps, Yes I do not know everything
Originally Posted by GrandLaredoWJ
You should be fine with the axle setup, just as long as you don't beat on it as hard as you would looking at a Playboy magazine, the d30 and d35 should hold up.
YJteen is offline   Reply With Quote
Old 01-26-2010, 12:53 PM   #3
Austinb86
calling never monday......
Austinb86 is offline   Reply With Quote
Old 01-26-2010, 12:55 PM   #4
YJteen
I forgot he has that how to run 35s explanation permanently on his computer.
Old 01-26-2010, 12:56 PM   #5
MikalCarbine
If thats the case I will definitely spring for a 2.5" OME instead of an RC lift. Any other input? I don't want to get highline tube fenders, just the TNT Gen II tube fenders
Old 01-26-2010, 01:06 PM   #6
never monday
all depends on who's tube fenders you use.
Get Savvy
never monday is offline   Reply With Quote
Old 01-26-2010, 01:09 PM   #7
MikalCarbine
TnT all the way..
Treks Offroad Products - Replacement Tube Fenders
Old 01-26-2010, 01:31 PM   #8
never monday
Originally Posted by MikalCarbine View Post
you can clear 35's with a BB
Get Savvy
Old 01-26-2010, 01:33 PM   #9
Unlimited04
Unlimited04's Avatar
read NM's info:
http://www.jeepforum.com/forum/f9/i-want-run-35s-my-tj-751873/
Unlimited04 is offline   Reply With Quote
Old 01-26-2010, 01:38 PM   #10
MikalCarbine
Thanks for that info, I also emailed TnT customs and asked them a few questions. Looks like I'll be getting an OME 2.5" HD kit for the long run
Old 01-26-2010, 02:21 PM   #11
MikalCarbine
Does anyone know if the rear corners require cutting, therefore providing more clearance to the wheel wells?
Old 01-26-2010, 03:22 PM   #12
never monday
if your on short arms. The rear front edge will need a trim
Get Savvy
Old 01-26-2010, 04:16 PM   #13
Deacon
Purveyor of Funk
Deacon's Avatar
See Metalcloak for options regarding tube fenders that provide high-line or near-highline clearance in a complete package without having to do an actual knife-job high-line. I have their arched tube fenders, which are great, but if I had to do it all over again I would've gone for their Overline fenders (not quite the same level clearance but still enough and I like the look better), but they didn't have them at the time. They're great people to work with, too.
By the way, with the arched fenders you apparently don't have to have any lift at all to fit 35's. One of the guys in the local Jeep club has that setup, and it's pretty slick. Like "never monday" said, though, you may end up needing to trim a small strip from the front edge of the rear openings to keep from rubbing, depending on your particular Jeep's behavior.
Deacon is offline   Reply With Quote
Glock Forum
