what length shock RC 2.5" w/teraflex bar pin eliminator? - JeepForum.com
post #1 of 5 Old 06-04-2010, 11:32 AM Thread Starter
jalbs
Well the stock bar pin broke and it is a really bad design. I was shocked to see how weak it was. Anyways I have RC 2.5" kit and hate the RC shocks and will need smaller shocks anyways(Due to bar pin eliminator). Any ideas on the length and a popular shock brand that is not stiff.
06 Jeep Rubicon 6spd SWB
2.5" RC SL and 1.25" BL
285/75-16 Mickey Thompson MTZ
Currie HD steering
JKS Front/Rear track bars
JKS quick discos
jalbs is offline
post #2 of 5 Old 06-04-2010, 12:08 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
The brand depends on your budget.
Jeep shock absorber application guide - Quadratec
TheBoogieman is offline
post #3 of 5 Old 06-04-2010, 12:40 PM
-dirt-
I like my Skyjacker Hydros. Designed for 1" - 3" lift. Should work with your set-up, but be sure to chekc the bumpstops!
-dirt- is offline
post #4 of 5 Old 06-04-2010, 11:32 PM
mudb8
want it rite or rite now?
mudb8's Avatar
There's nothing wrong with the stock bar pins. The problem is improper Bumpstops.
since you have a 1.25" BL, use these.... TJ Wrangler Rear Upper Shock Adapter and Relocator | TeraFlex Suspensions
with a 13.5-14.5" collapsed length shock.... the 13.5" collapsed length, 9" travel, OME N67 shock will need about 3/4" bumpstop extensions with the tera relocators and and about 2" bumpstop extension with OME N67L 14.5" collapsed length, 10" travel. The OME bushings are a PITA to deal with when using bar pin eliminator type mounts BTW, due to the bushings and you'll need to loose the metal dust shields.
The collapsed length is the important number to know about the shock length.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #5 of 5 Old 03-03-2013, 02:42 PM
GMBNT42
Curious how you get 3/4" bumpstop with the Teraflex upper TJ relocators. They gain you about an inch(claimed). Stock shocks are 12.2" roughly collapsed. The N67's are 13.2" collasped roughly....thats an inch longer. Technically you wouldn't need to bumpstop at all if you can a full inch from those relocators.
GMBNT42 is offline
teraflex 2.5" coil lift with shock adapters boostedboxer JK Wrangler Technical Forum 6 05-27-2010 08:49 PM
Shock travel/length help for 3.5" lift . . . briguy3030 TJ Wrangler Technical Forum 0 05-13-2010 06:54 AM
What is the Shock Length for roughly 2.5" of Lift Wynne TJ Wrangler Technical Forum 7 01-22-2009 05:18 PM
after 2"spacer lift what shock length? bhorocks TJ Wrangler Technical Forum 1 03-23-2007 10:58 PM
Ideal Skyjacker Shock Length for 2" lift? IslandTJ TJ Wrangler Technical Forum 7 06-19-2006 06:18 PM
