What kinda gas do you guys use... - JeepForum.com
post #1 of 16 Old 12-05-2004, 10:58 PM Thread Starter
Rocky529
Rocky529's Avatar
I got an '04 Sport and I used to use regular. I noticed knocking coming from the engine so I ran till empty and filled up with Premium. Haven't noticed any knocks... just wondering what you guys use with the 5 speeds.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #2 of 16 Old 12-05-2004, 11:08 PM
GoGo
GoGo's Avatar
You shouldn't have to increasse your octane level to prevent the knock. These aren't high compression motors. I'd take the car in to the shop and tell them it's detonating, and have them fix it (usually by setting the timing). It could also be caused by a lean fuel condition.
Contrary to popular belief, you gain nothing by using a higher than recommended octane (Yes, it will probably help prevent detonation, in this case, but I'd bet your's is a timing issue).
2004 "Electric Lime Green Pearl" Rubicon
Poseur Jeep Club Member # 1
I'd feel safer hunting with Cheney than, going for a drive with Ted Kennedy.
GoGo is offline
post #3 of 16 Old 12-05-2004, 11:27 PM Thread Starter
Rocky529
Rocky529's Avatar
I was using regular since I got the car brand new in August and I really haven't noticed the knock.. it just started recently. I'll change gas stations and go with regular for a while and see what happens.
Rocky529 is offline
post #4 of 16 Old 12-05-2004, 11:30 PM
david.mciver
I am running the mid-grade and have never had a problem running it. The interesting thing for me is I did run 1 tank of premium in it in the past and it got much better gas mileage on that tank. I have been monitoring the last 2 tanks mileage closely on the mid-grade and am getting 15 mpg on it. My next fill up I am going to turn the premium and see if the mileage again improves.
david.mciver is offline
post #5 of 16 Old 12-05-2004, 11:35 PM
franco802
franco802's Avatar
87 octane from chevron.
SOLD
04' X, 5 speed, 4.0L,hardtop,kilby PS armor,Warn rock guards,2"RE BB w/DT3000 shocks, hi-lift jack,15x8 Black crawlers with 31x10.5 Procomp X-Terrains, Hurst short throw shifter Hella 500's offroad AND driving lights . Warn X8000i winch w/ Tomken mounting plate
White Jeep Club member #802
FOLLOW ME TO CERTAIN DEATH JEEP CLUB MEMEBER #21
SoCal Jeep Club Member #4
2006 GTO & 1986 K5 Blazer
franco802 is offline
post #6 of 16 Old 12-05-2004, 11:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Unless something is wrong with your engine like it is pinging from carbon deposits, there is no benefit to running any octane higher than 87.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #7 of 16 Old 12-06-2004, 12:04 AM
AjRagno
And if there is something wrong, you really do need to address the root problem, not apply a band-aid fix.
Carbon build-up will cause detonation. But if you use a higher octane fuel, it won't work for long and you'll even make the problem worse. If your engine is programmed to run 87, the ignition timing will not be advanced enough to burn all of the 89+ octane fuel in the combustion chamber.
If your engine is pinging, the dealer may need to reprogram the computer. I'd make an appointment.
AjRagno is offline
post #8 of 16 Old 12-06-2004, 10:26 AM
ColoradoTJ
ColoradoTJ's Avatar
In Colorado the standard octane is 85, I got horrible knocking when I ran 85, switched to 87 and everything sounds great.
Clint
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline
post #9 of 16 Old 12-06-2004, 10:37 AM
Coils Rule
Mine has pinged on 87 since I bought it in 03. Has been back to the dealer for the problem mulitple times, no fix. I still run 87 cause I am to cheap to run the other stuff, plus fule milage decreases as octane rises.
Coils Rule is offline
post #10 of 16 Old 12-06-2004, 10:38 AM
uglyprimate
factory recomendation is for 87 octane, I don't know anything that would run on 85 octane except a lawn mower or VW bus
uglyprimate is offline
post #11 of 16 Old 12-06-2004, 12:32 PM
FlexyTJ
FlexyTJ's Avatar
wrong. the standard octane rating in CO is 85 (as mentioned earlier). oddly enough, my Jeep runs perfectly fine (no detonation even under heavy sustained load climbing 12,000 foot mountain passes) on the 85 octane swill
Im usually nice and give it our mid grade (87)... unless im feeling especially poor.
MK Motorsport & Fabrication
FlexyTJ is offline
post #12 of 16 Old 12-06-2004, 01:17 PM
Jim Shanks
Jim Shanks's Avatar
I run 89 in mine. The benefit is here in IA it's cheaper than 87. Ethanol and runs fine.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #13 of 16 Old 12-06-2004, 01:53 PM
AudioGuru
AudioGuru's Avatar
Jim
Ditto. 89 w/ 10% ethanol. I guess having all this corn around is good for SOMETHING.
Don't lie. God said so.
AudioGuru is offline
post #14 of 16 Old 12-06-2004, 03:23 PM
tnjeepchik
tnjeepchik's Avatar
I used to run 87 when I first got my 00 TJ Sport 5 speed and it pinged bad, then I switched to Premium and it ran awesome...
tnjeepchik
SNL Celebrity Jeopardy
Sean Connery -"I'll take anal bum cover for a thousand..."
Alex Trebek- "That's an album cover you moron...."
tnjeepchik is offline
post #15 of 16 Old 12-06-2004, 03:58 PM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
I always run super unleaded-93 here in Texas. Anything to help out the lil ol 4banger
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
Some kinda Vacume bypass to get kinda like front locker? 2muchfun YJ Wrangler Technical Forum 14 10-28-2011 11:38 AM
Kinda new to Jeepin Jblood YJ Wrangler Technical Forum 9 12-21-2007 02:06 PM
kinda confused bughunter YJ Wrangler Technical Forum 9 10-16-2006 03:58 PM
Kinda of a How to? Need some help... mferrari TJ Wrangler Technical Forum 19 02-23-2006 08:05 PM
Kinda wierd, but, what do I do now? Mike611 YJ Wrangler Technical Forum 2 02-04-2003 11:11 PM
