what kind of plastic is the power steering pump reservoir made of - JeepForum.com
post #1 of 6 Old 10-23-2006, 06:32 PM Thread Starter
farinspace
im looking to get some epoxy glue to reattach the low pressure hose elbow back to the reservoir as it snapped off (i dont know why i thought i could remove the hose off the spout, but i tried and the plastic snapped at the elbow of the reservoir)
ive go this 5min epoxy, works on ABS, acrylic, fiberglass, glass, pvc, steel, styrene, vinyl and wood. full strength in 4 hours rated up to 250 degrees F.
Tried it once with a different epoxy and the thing epoxy melted (what a mess that was, had to use kitty litter).
Need to know what type of plastice it is and if the above product as mentioned would work, is the temp rating ok?
98 TJ, 4.0L I6, 5sp, 4.88 Alloy Gears, D30[Aussie Locker]/D44[Detroit TrueTrac]
33" Toyo Open Country MT, 2" BB Lift + 1" Eng./Body Lift, TW SYE + Drive Shaft
farinspace is offline
post #2 of 6 Old 10-23-2006, 06:34 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
that would work, heat range is more then hot enough as split loom only good up to 200 degrees, and i believe its abs or pvc
RnEmOvr is offline
post #3 of 6 Old 10-23-2006, 07:50 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The reservoir is a glass filled resin and I wouldn't glue it back on. It will fail at the most inopportune time and you will suffer greatly. Go get a new reservoir. The old one unclips and slides off. Reverse and repeat to install the new one.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 6 Old 10-24-2006, 09:39 AM
Dcomf
I did a little work on the PS pump and read the stories of people breaking the fitting off. Just hit the hose and fitting with a little PB Blaster or such a minute before you plan to remove it and it slides right off, eliminates having to twist and fight hoses.
Dcomf is offline
post #5 of 6 Old 10-24-2006, 10:31 AM
Futhy
Most likely it is a glass filled nylon. Using glue to fix it would work ok for a temporary fix (driving it to and from the parts store to pick up a replacement part) but I wouldn't trust it beyond that.
Futhy is offline
post #6 of 6 Old 10-25-2006, 04:16 AM
Kiwi_TJ
Replace it!!
This is my advice speaking from experience. I have just been on a trip with a guy in our club who had glued the broken elbow back in. Needless to say it failed, luckily at the end of the trip, and we had to fix it overnight, with epoxy, and limp back to town.
He has now fixed it properly.
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
Should I get a power steering pump w/ or w/o reservoir built on? BWFBezerk TJ Wrangler Technical Forum 6 09-03-2009 03:55 PM
Power steering pump reservoir pressure? UnsanePyro TJ Wrangler Technical Forum 4 02-29-2008 09:37 AM
97 TJ Power Steering Pump AND reservoir Buckeye97TJ TJ Wrangler Technical Forum 6 04-02-2006 08:37 PM
Power steering reservoir MuddYJ YJ Wrangler Technical Forum 4 01-28-2006 07:01 PM
Power Steering Reservoir cj5mudman4x4 TJ Wrangler Technical Forum 2 07-15-2003 10:02 PM
