Quantcast What kind of motor oil you guys using? - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What kind of motor oil you guys using?
Old 08-04-2009, 01:39 AM   #46
officerholbrook
Mobile ! 5w-30 and mopar filter from wallyworld. Although it apparently (according to the shop) ruined my new engine (rounded off two lobes of the cam and also ruined the lifters). Waiting till about 1500 miles till I make the switch from the regular stuff.
A good friend of mine once told me, "It's better to have it and not need it than to need it and not have it".
officerholbrook is offline   Reply With Quote
Old 08-04-2009, 01:40 AM   #47
southtxdstroyer
mobil 5000 with a mopar filter
did my second oil change about a week ago
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant, 'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honor.
open your eyes www.infowars.com
southtxdstroyer is offline   Reply With Quote
Old 08-04-2009, 08:11 AM   #48
Philly60
I use Mobile 1 10w30 full synthetic had to use a Fram filter though...
Philly60 is offline   Reply With Quote
Old 08-04-2009, 08:30 AM   #49
KentuckyTJ
10w-30 Castrol GTX w/ Wix 51085 filter............can't be beat
KentuckyTJ is offline   Reply With Quote
Old 08-04-2009, 08:47 AM   #50
JDePietro
After tearing apart engines for a year or so it seemed to me that the engines running a synthetic were at the very least the cleaner of those I have dealt with. To many variables to say without a doubt but that was one of the reasons I have used synthetic when its time for an oil change. Reason number two is it lasts longer. If you ever have a chance to measure the viscosity jump on it and compare syn with "other" after 3000 miles the difference is not vast but note worthy. For my rides Mobil 1 synthetic has been the ticket and with every other oil change I add a bottle of Lucas Synthetic oil treatment. After chaning my tranny fluid with Amsoil I am curious if their oil line is any better than Mobil, I sure did like how it smoothed out the 1st to 2nd shift.
I also use a K&N oil filter, and the only real reason for this is due to the magnet on the bottom. After my third oil change while using this combo I have found less and less shavings and grime in my oil.
Just my .02
/l ,[____],
l---L -[]lllllll[]-
()_)-()_)-o-)_)
Google me.
JDePietro is offline   Reply With Quote
Old 08-04-2009, 08:53 AM   #51
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Originally Posted by JDePietro View Post
... and with every other oil change I add a bottle of Lucas Synthetic oil treatment...
Check this link on Lucas out, which is just one of many reasons I will NEVER EVER add any additives to my engine oil. http://www.bobistheoilguy.com/images/lucas/lucas.htm
The vast majority of the additives are little more than kerosene or snake oil anyway.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 08-04-2009, 08:56 AM   #52
southtxdstroyer
mobil 5000 is dino oil and is good for -you guessed it- 5000 miles or 6 months
plus its only $11 for a gallon at walmart
how does synthetic compare to that?
Old 08-05-2009, 09:39 AM   #53
JDePietro
Thanks again Jerry for the informative link.
I have two sorta question(s)/critique(s).
If the Lucas oil foamed up as much as his test did wouldn't it start to come out of the valve cover or worse yet effect the emmisions? You would have to lose oil at a pretty ridiculous rate if that was the case. Of the many oil changes I have done to my Jeep I have yet to notice or see any discoloration that would indicate any sort of foaming and yes I have done them while the oil was still scalding hot.
Ratio makes a difference, I would not adivise nor add myself a whole case of Lucas straight. Mixing 5:1 or even 5 1/2:1/2 is what is recomended and what I follow.
All things said I have just changed my oil and am running just pure Mobil 1 10w30 and just for S&G I'll do it again next time.
/l ,[____],
l---L -[]lllllll[]-
()_)-()_)-o-)_)
Google me.
Old 08-05-2009, 09:44 AM   #54
tjchuck
Mobil-1 5W-30 full synthetic
tjchuck is offline   Reply With Quote
Old 08-05-2009, 11:06 AM   #55
ArchStanton
My Jeep had Amsoil and now has Penzoil 10-30 full synthetic with a Mobil 1 filter. I just bought three-oil-changes worth of Mobil 1 10-30 synthetic and Mobil 1 filters. Pep Boys has five quarts of Mobil 1 10-30 synthetic with a Mobil 1 filter for $30, which is a pretty good deal.
ArchStanton is offline   Reply With Quote
Old 08-05-2009, 11:22 AM   #56
Jeepster83
ever since i was very little i remember my dad using Havoline non-synthetic engine oil. hes been a professional ASE certified master tech for years and he still uses it in his personal vehicles. and ever since ive had a vehicle of my own ive used nothing else. never had any problems and now my Jeep is on 6k miles and is due for another change. my Jeep gets 10w-30 every change.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications.
Jeepster83 is offline   Reply With Quote
Old 08-05-2009, 12:38 PM   #57
jweaver321
Mobil 10w30
jweaver321 is offline   Reply With Quote
Old 08-05-2009, 01:28 PM   #58
jazzman31
2010 JK Wrangler
Royal Purple 5-30W and a Reusable Oil Filter.
Just wash the filter out after every 7,500miles.. I can run almost 12,000-13,000 miles between oil changes. Done the visocity test and with my oil filter its like the oil is brand new.
Oil never expires its what the oil gets went running through the engine that wears it out. If you can filter that oil then oil should last forever.
All in theory.
jazzman31 is offline   Reply With Quote
Old 08-05-2009, 01:51 PM   #59
Robert J. yates
Originally Posted by Elwoodblues37 View Post
I just had my 4.0 rebuilt. I was told by the shop that falling zinc (zddp) levels in oils is
Killing motors with solid lifter cams. They recommended a racing oil with high zinc. Anyone else here anything on this.
Other than using racing oil (which I don't know what that means), your shop is correct.....see my post here:
http://www.jeepforum.com/forum/f9/ran-without-oil-help-830992-post7704840/#post7704840
FWIW...I use a good synthetic (Royal Purple 10w30) in my rig with a Comp Cams zinc additive. I used to run Rotella 15w40 which is a diesel formula but then they dropped the zinc content in it last year. That is when I switched to the RP and additive. I am also getting better milage with the 10w30.
Robert J. yates is offline   Reply With Quote
Old 08-05-2009, 01:55 PM   #60
RJV
10w-30 mobil1 syn w/ a mopar filter
RJV is offline   Reply With Quote
Glock Forum
