What kind of lift is this? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What kind of lift is this?
New rockridge 4wd sales rep!!!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 05-05-2011, 05:48 PM   #1
inkryptic
Hey, guys. I've done some searching around, but the descriptions I've found aren't giving me the warm-fuzzy. I need new struts, and I'm trying to determine what my current lift is from. PO did it.
Struts are ProComp ES3000
Is this the normal bump stop, or is that a spacer?
Same here for the body mount.. is that a spacer, or normal?
And here's one showing the distance from the ground to the far back corner of the rear fender flare...26"
Appreciate any help!
inK
inkryptic is offline   Reply With Quote Quick reply to this message
Unread 05-05-2011, 05:53 PM   #2
thirdeye
The body mount is stock, no body lift. What are you referring to as the strut? The shock? More info or pics would help us tell you the size lift
2004 4.0L I6 TJ BUILD:
[url]http://www.jeepforum.com/forum/f22/history-thirdeye-1233347/[/url]
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline   Reply With Quote Quick reply to this message
Unread 05-05-2011, 06:02 PM   #3
RockMonster
take a picture of the control arms, cant tell by just the shocks and springs.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++++++
RockMonster is offline   Reply With Quote Quick reply to this message
Unread 05-05-2011, 06:17 PM   #4
inkryptic
Do these help? It's dark out there, so I just shot some pics w/ the flash. If I missed what you need, let me know.
Err.. yeah. Shocks. Struts on my dd. For clarity.. I think when you have struts there is no upper control arm? Is that the only difference?
Lower Control Arm:
Upper Control Arm:
Unread 05-05-2011, 06:25 PM   #5
cj847
Most likely a pro comp 2" spring lift. If you look on the shock you should be able to find a PN. Look it up on here to find out the length. then buy the brand you want in that length.
http://www.procompusa.com/productlis...t=90&ptid=3306
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline   Reply With Quote Quick reply to this message
Unread 05-05-2011, 06:30 PM   #6
RockMonster
control arms are stock, so most likely Pro comp lift springs and shocks.
Unread 05-05-2011, 06:57 PM   #7
inkryptic
excellent... thanks much, guys.
Unread 05-05-2011, 08:30 PM   #8
thirdeye
I think struts are only on independent suspensions...
Unread 05-05-2011, 08:39 PM   #9
biffgnar
biffgnar's Avatar
Search ORI struts. Some interesting looking jeep builds (solid axle) have used them.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 05-05-2011, 09:04 PM   #10
RogueSpear2023
You may want to measure the spring height that would give us a good estimate of how much lift. Why do yo need to replace the shocks? If it rides rough that may be numerous things or are they leaking?
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2011, 05:20 AM   #11
inkryptic
It rides very rough, and the back right one just clanks around on every bump. I feel like I have nearly no suspension at all. I'm planning on new springs and shocks. I'm open to replacing other suspension components while I'm at it...any suggestions? This is all on road. I'm going for stance and ride comfort.
Last edited by inkryptic; 05-06-2011 at 06:12 AM.. Reason: stupid iPhone auto-correct...
